To answer my interrogation, I made a test and I was actually right. It is NOT equivalent rounding the value before and after. So rounding the value before all computations will make the final value different from the theoretical value
Hi. Can someone guide me in the right direction on how to me to round a value obtained via a webhook through Node Red and mqtt?
In configuration.yaml i have this.
# Brewfather Integration
- platform: mqtt
name: "iSpindel Batterylevel"
state_topic: "brew/ferment/tilt/battery"
unit_of_measurement: "Volt"
I use the calculator node to round the figures on my smart meter readings -
Thank you for response. Can i put the calculator node between the battery and mqtt nodes? I am 100% noob on Node Red, so i am sorry if it is a stupid question
Sure. Try it and see
Hi there everyone, I’ve created a few sensors in HA from some Power Monitors attached to a washing machine and dryer.
It’s working great however I want to scale it by 0.1 so I can get a valid wattage read.
Is there a simple way to do this?
friendly_name: Washing Machine Power
unit_of_measurement: 'W'
value_template: '{{ states.switch.washing_machine_power_meter.attributes.current }}'
dryerpower:
friendly_name: Clothes Dryer Power
value_template: '{{ states.switch.gpo_power_meter.attributes.current }}'
I’m not sure what you mean by this.
Do you want the value to 1 decimal place
value_template: '{{ states.switch.gpo_power_meter.attributes.current | round(1) }}'
Or do you want 10% of the value
value_template: '{{ states.switch.gpo_power_meter.attributes.current * 0.1 }}'
I meant 10% of the value, thank you so much.
I’m trying to round my climate temp to 0.5. So 22.3 becomes 22.5, etc
I thought this would work but this gives me back the same original temp.
Would anyone be able to spot the mistake?
I double the original and round it by (0), (no decimals), then I divide by 2 and round it to one decimal which will always be .0 or .5
sensors:
livingroom_current_temperature_rd:
friendly_name: "Current Temperature Rounded"
unit_of_measurement: °C
value_template: >
{% set rd = state_attr('climate.living_room', 'current_temperature') | round (1) %}
{% set dble = rd * 2 | round(0) %}
{{ dble / 2 | round(1) }}
Figured it out
sensors:
friendly_name: "Current Temperature"
value_template: >
{{ (((state_attr('climate.living_room', 'current_temperature') | float) * 2) | round ) / 2 }}
Now that I have my temperature numbers rounded, how could I make 22.0 shown as 22?
So all .0 numbers loose the decimal point but not the .5 numbers.
22.0 → 22
22.5 → 22.5
23.0 → 23
Etc
You can use the modulo operation (%) for that.
{% set foo = 22.5 %}
{{ (foo | round(1)) if (foo % 1) else foo }}
This gave me a null result
temperature: |
{% set temp = states('sensor.livingroom_current_temperature_rd') %}
<span class="sidetemp">
{{ (temp | rount(1)) if (temp % 1) else temp }}
</span>
Try ‘round’
That didn’t work either.
{{ (temp | round(1)) if (temp % 1) else temp }}
Tried this too:
{% if (temp % 1) %}
{{temp | round(1)}}
{% else %}
{{temp}}
Gives me back true instead of null. haha
this helped me too, thx ya!
You just rounded 3.6 not the calculation, use brackets.
Here vis a quick way to get hh:mm:ss from a count of seconds by (ab)using the time primitives
The example is UPS runtime remaining.
# UPS runtime in hh:mm:ss
# converts run time to seconds since unix epoc 1970-01-01T00:00Z
# it uses this hack to get the locale time offset
# 0 | timestamp_custom('%s') | float
sensors:
server_rack_ups_runtime_mins:
friendly_name: "Server Rack UPS Runtime"
value_template: >-
{{ (states.sensor.server_rack_battery_runtime.state | float - (0 | timestamp_custom('%s') | float)) | timestamp_custom('%X') }}
Instead of {{ (float(states.sensor.1.state) + float(states.sensor.2.state) + float(states.sensor.3.state)) / 3 | round(2) }}
use {{ (float ((states.sensor.1.state + states.sensor.2.state + states.sensor.3.state) / 3) | round(2) }}
