I have a rains sensor configured with lot of decimals:
sensor.netatmo_regen_sum_rain_24 0.29831595829992
In the frontend, I want to show the value with only 1 digit after the comma.
Can anybody advise me, how to do this?
Thanks,
Albert
Thanks,
Albert
You can use a value template. Here is my config to round down a humidity sensor
platform: mqtt
state_topic: "conservatory"
name: "Conservatory Humidity"
unit_of_measurement: "%"
value_template: '{{ value_json.humidity | round(1) }}'
works perfect - thanky you very much!
I have problem with rounding. For example in HA 0.63.2
{{ (float(states.sensor.1.state) + float(states.sensor.2.state) + float(states.sensor.3.state)) / 3 | round(2) }} is not rounded.
If I exchage valuses with numbers result is also nonrounded:
{{ (float(3) + float(3) + float(4)) / 3 | round(2) }} = 3.3333333333333335 on dev-template page.
What am I doing wrong?
Try surrounding everything to the left of the pipe sign in parents. I think what you do now is rounding the 3 integer only.
that works in template assistant but not when I the value_template in config to that
I’m fairly new to HA so this might be a stupid question but I don’t manage to get the example of @BertrumUK working.
I tried multiple variation in the configuration and customisation file.
This is the code I’m trying to use, anyone any idea what’s wrong?
# MQTT sensors
- platform: mqtt
state_topic: "/sensor1/HUM"
value_template: '{{ value_json.humidity_slaapkamer.value | round(1) }}'
- platform: mqtt
state_topic: "/sensor1/PRES"
name: "Pressure slaapkamer"
- platform: mqtt
state_topic: "/sensor1/TEMP"
value_template: '{{ value_json.temperature_slaapkamer.value | round(1) }}'
What does the yaml you have output as a sensor value ? Anything ?
Can you verify what is being sent by the sensor to the topic “/sensor1/HUM” ?
Sorry, figured it out in the mean time. Needed to be :
value_template: '{{value | round(1) }}'
Awesome !!
I guess your sensor output is not in JSON therefore my config won’t work for you. Glad you got it sorted
I got some strange results from round() function, it gives me 11.520000000000001 value when I recalculate m/s to km/h and round it to 1 decimal place.
value_template: '{{ state_attr("sensor.redfish_pogoda", "wiatr_predkosc") | float * 3.6 | round(1) }}'
Any ideas?
value_template: '{{ state_attr("sensor.redfish_pogoda", "wiatr_predkosc") | (float * 3.6) | round(1) }}'
Hello @BertrumUK and @Sonnstein,
Is there a way to round a state value without having to create a template sensor?
I need to do it for more than 30 sensors and I don’t want to type it down all over…
Another question is: is there a difference using mqtt and template integration for this purpose?
Thank you!
Can you give an example of your sensors ?
Hi @BertrumUK,
They are automatic sensors created after using the utility_meter integration.
That integration is using data from other sensors like your gas and electric sensors - you can round those values down before passing the data onto that integration.
Hi @BertrumUK,
Thanks for the answer. It seems to be working. However, one question, is it only affecting display or is it also affecting precision of the computation? What I mean is by rounding the values at the beginning of the computation (before Integration and Utility_meter), will I loose precision in the final value?
It uses the values of the sensors to create its own value so the original values are still the same.
Fair enough, I understand that but my question is something else. By using a round value for computation, after some time, the final result might differ from a computation using precise value then rounded.
In other words, I feel that:
Round(integration(sensor)) != Integration(round(sensor))
