in an entity card everything is fine. that´s weired:
My guess is the button card uses the entity state ?
I am having a rounding up issue:
My code for a template sensor which is W to convert to KW:
sensors:
convert_charge_power:
unique_id: convert_charge_power
friendly_name: "Charge Power KW"
value_template: "{{ states('sensor.wattpilot_charging_energy') | float / 1000 | round(2) }}"
However the result is not rounded at all:
What am I doing wrong?
Will this work ? I think you are rounding the 1000 only
value_template: "{{ (states('sensor.wattpilot_charging_energy') | float / 1000) | round(2) }}"
Have you tried just changing the units in the entity info dialog instead ?
Try this:
sensors:
The order is to do conversions before math. It was rounding the 1000 to two digits not the result
Isn’t that exactly what I said above ?
Yes, I just missed it.
Same for me. I’ve had this happen today out of the blue, but otherwise it has worked ok for me until now
{{ state_attr('sensor.my_sensor')|float|round(4)*100 }}
But today sensor.my_sensor = 0.036855
and instead of getting 3.69
the above code returned 3.6900000000000004
What is going on!? Where is that 0.0000000000000004 coming from?
- You got a typo - an attribute’s name is missing.
- Try to multiply before rounding.
Yes sorry, I simplified the code for easier reading.
The round() and *100 is the problem but only today or for this value, which is strange.
What works right now is this:
(state_attr('sensor.my_sensor','attribute') | float(0) | round(4) * 100 ) | round(2)
But having to round twice is crazy.
I’m struggling to see what’s causing this.
Am I missing something?
Sorry, I missed the fact that
*100|round
is treated as
* (100|round)
Indeed, I just realised the mistake and this fixed it:
((state_attr('sensor.my_sensor','attribute') | float(0) ) *100) | round(2)
}}p/kWh
But I am still confused about the first result
Just a speculation:
rounded value “1.234” * 100 = float value with some epsilon
Many numbers cannot be represented exactly in binary with a fixed number of digits.
I’ve never come across something like this
{{ float("0.036855") }}
= 0.036855
{{ float("0.036855")|round(4) }}
= 0.0369
{{ float("0.036855")|round(4) * 10 }}
= 0.369
Yet somehow
{{ float("0.036855")|round(4) * 100 }}
= 3.6900000000000004
or
{{ float("0.036855")|round(4) * 1000 }}
= 36.900000000000006
but
{{ float("0.036855")|round(4) * 10000 }}
= 369.0
Does anyone know what is going on here?
Do you know how binary works? If so, convert the numbers to binary and see what happens.
I gave you the answer above: When you cast from string to float, it becomes an actual number, but you have a fixed number of bits to represent the number. What might look like a finite decimal expansion in isn’t necessarily possible in binary for the same number.
Some references with illustrative examples:
https://www.uvm.edu/~cbcafier/cs1210/book/03_types_and_literals/representation.html
