It’s been a couple of years since anyone asked for router recommendations here.
I am on Verizon FIOS and I am needing to reboot my router at least two or three times a day. This is on the second Verizon router, so I have to wonder if the Verizon router is up to my home network with almost 100 connected devices.
I too am on FIOS. I replaced the FIOS router with a Netgate Appliance. Works great but a steep learning curve to understand the advanced capabilities of the router/firewall.
NOTE 1: I do not have a cable TV package - I stream (I’m a cable cutter). So, I do not need the cable MOCA capabilities that are provided with the FIOS router.
NOTE 2: I use Unifi switches and access points. The FIOS router has built-in WIFI - Netgate does not.
I’m pleased with my setup but I’m reluctant to recommend it because of the effort to setup and manage it.
I have a Firewalla Purple and Aruba InstantOn AP22 Wireless Access Points. It’s a pretty simple install and this setup allows VLAN tagging with separate SSID too. Both are managed through their respective app, though the Aruba InstantOn uses a web portal through the cloud. The Firewalla is highly customizable with VPN both server and client options, built in ad blocking, region and app blocking, and many other options. I have roughly 40 wireless devices and a total of 90 network devices (wired and wireless) and my network is rock solid and stable.
I use the Unifi Dream Machine and 3 access points + a mix of 10 and 1 gbit switches from them, happy with it. My UDM has been a bit unstable lately but support is quick and helpful.
I had unifi USGs for years but had issue where internal usb stick would fail, take down network and I luckily had a second to clone and restore from.
After the third time this happen and 13yr use put opnsense on a server I had laying around and greatest idea ever. Now moving other sites (family) to opnsense on low cost 2 port pc I found
I had a UniFi Dream Machine as well and was starting to get slow and unstable, at times I couldn’t even access the router settings page.
It ended up being the ~100 devices that were on my 6 AP’s and gigabit switch that kept locking the system up. Upgraded to the UDM Pro and it has been rock solid ever since.
I would say if you have a lot of traffic, especially wired security cameras etc go with the UDM Pro for the extra horsepower.
My issue is temperature related, for some reason it runs hotter now than the previous last three years sitting in the exact same spot (yes, I’ve cleaned it) I’ve always been curious though, how is the noise level on the UDMP?
This looks cool even though it does not have an AP or the software:
Yeah, that little bean can sound like a hovercraft sometimes. UDM Pro is really quiet, way quieter than my older EDGEswitch.
I have recently moved the router to my office due new fiber being run so it’s not on my lab server rack, and haven’t heard it at all so far.
After i upgraded my internet line to 1Gb/s i found out my TP link wasn’t up to the job, so now I use an Ubiquity Edge router plus (very cheap).
I also added two ubiquity AP’s
(and still use my TP link on the attic now configured as AP and also as 5 port switch)
Are you sure that’s a router and not a switch? Do you plug in the WAN from your ISP and get local addresses on the other ports? (NAT)?
yes…very sure
I don’t think we’re on the same wavelength…
Where do you connect the WAN from your ISP? It will NOT be a 192.168.x.x IP, it will be a public IP. The router is supposed to perform Network Address Translation (NAT) into a private IP. 192.168.x.x is a private IP address.
As the name implies the EdgeRouter is a router, not a switch.
Where do you connect the WAN that has a public IP address from the ISP?
In one of the ports? Not sure if you can configure all ports for it or if it’s only eth0, but none the less it’s a router.
It is fully unix based, very fast, and highly configurable, supports POE on 2 ports, supports hairpin nat and if you want you can configure it with 2 ISP’s including load sharing
You can choose any of the 5 lan ports, but by default one of them is desginated as wan
Yeah, looks very decent for the price point! I like to have all my gear on a single pane of glass so sticking with the Unifi here
Thanks for the video link. My head is now smoking…
I don’t need that much configuration ability, but 2 ISPs for a fallback sounds tempting.
And I thought my network of 76 WiFi connections and 20 or so Ethernet connections was complex…
Ubiquiti has products for that as well (and probably many other vendors do too), but unless you have outages often I really wouldn’t bother. Pricy and adds complexity.
