I have tried everything! I have a RPI 3B+ with a Balena Etcher flashed 128gb sd card. The RPi works perfectly well with other software installed upon it and my internet connection is good. Yet, on running of the initial install it just gets into the following loop. Any help would be very appreciated!
22-10-11 11:23:06 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi3-homeassistant&platform=linux%2Farm%2Fv7: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-10-11 11:23:06 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-10-11 11:23:36 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.3
22-10-11 11:23:36 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-homeassistant with tag 2022.10.3.
22-10-11 11:29:12 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi3-homeassistant&platform=linux%2Farm%2Fv7: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-10-11 11:29:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-10-11 11:29:42 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.3
22-10-11 11:29:42 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-homeassistant with tag 2022.10.3.
22-10-11 11:35:18 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.10.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi3-homeassistant&platform=linux%2Farm%2Fv7: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
22-10-11 11:35:18 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-10-11 11:35:48 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-homeassistant:2022.10.3
22-10-11 11:35:48 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-homeassistant with tag 2022.10.3.
