Thank you for taking your time and documenting this so well skynet. I searched and searched until falling on this thread. I finished following your directions this afternoon and they worked flawlessly. I now have Home Assistant running on a 120G SSD on a rPi 4. Updated it with a full snapshot and my system and it never ran better.
I’m much more comfortable not having to rely on a SD card for the whe system. Going to clone the SD boot just in case and have it at the ready.
Have been running mine since Christmas and its a great step up from the 3B+ I was running before. I have a small fan on mine with the speed throttled down with a resistor to make it quieter. Over the past few months I have started to overclock it starting with 1.6 Ghz and now running at 1.8Ghz and it hasn’t missed a beat and still runs quite cool
If anyone would like to run Ubuntu on your new RPI4 running from SSD you can read my guide at Ubuntu Bootable SSD for RPI 4
curl -fsSL https://get.docker.com -o get-docker.sh sudo sh get-docker.sh
Prerequisite Installation
apt-get install apparmor-utils avahi-daemon dbus jq network-manager socat -y
and you can run curl -sL https://raw.githubusercontent.com/krdesigns-com/supervised-installer/master/installer.sh | bash -s -- -m raspberrypi4 since currently supervisor is on hold and have a bugs on its scirpts.
Once complete you can check your browser IP:8123
how do you get RPI info??
Using System Monitor and a mini graph card in Lovelace to display the sensors. Here is my code borrowed off someone else
cards:
- cards:
- animate: true
card: null
entities:
- entity: sensor.processor_use
index: 0
graph: line
hour24: true
show:
extrema: true
icon: false
style: |
ha-card {
border-radius: 15px;
transform: scale(0.95);
background-size: 100% 100%;
border-style: dotted;
border-width: 1px;
type: 'custom:mini-graph-card'
- animate: true
card: null
entities:
- entity: sensor.memory_use_percent
index: 0
graph: line
hour24: true
show:
extrema: true
icon: false
style: |
ha-card {
border-width: 1px;
type: horizontal-stack
- cards:
- align: center
animation: auto
attribute: false
background_style: false
card_style: false
charge_entity: false
color: '#9932CC'
decimal: false
delay: 5000
direction: right
entities:
- entity: sensor.swap_use_percent
height: 40px
icon: false
icon_position: 'off'
icon_style: false
indicator: auto
limit_value: false
max: 100
min: 0
minmax_style: false
padding: 4px
rounding: 3px
saturation: 50%
severity: false
show_minmax: false
show_value: true
speed: 1000
tap_action: info
target: false
title: Swap
title_position: inside
title_style:
font-size: 12px
type: 'custom:bar-card'
unit_of_measurement: false
value_style: false
visibility: false
width: 100%
- align: center
animation: auto
attribute: false
card_style: false
color: '#40E0D0'
decimal: false
delay: 5000
direction: right
entities:
height: 40px
icon: false
icon_style: false
indicator: auto
limit_value: false
max: 100
min: 0
minmax_style: false
padding: 4px
rounding: 3px
saturation: 50%
severity: false
show_minmax: false
show_value: true
speed: 1000
tap_action: info
target: false
title: Memory
title_style:
font-size: 12px
value_style: false
visibility: false
width: 100%
- align: center
animation: auto
attribute: false
card_style: false
color: '#1E90FF'
decimal: false
delay: 5000
direction: right
entities:
- entity: sensor.disk_use_home
height: 40px
icon: false
icon_style: false
indicator: auto
limit_value: false
max: 100
min: 0
minmax_style: false
padding: 4px
rounding: 3px
saturation: 50%
severity: false
show_minmax: false
show_value: true
speed: 1000
tap_action: info
target: false
title: Used Space
title_position: left
title_style: false
value_style: false
visibility: false
width: 70%
- align: center
animation: auto
attribute: false
card_style: false
color: '#B22222'
decimal: false
delay: 5000
direction: right
entities:
- entity: sensor.disk_free_home
height: 40px
icon: false
icon_style: false
indicator: auto
limit_value: false
max: 100
min: 0
minmax_style: false
padding: 4px
rounding: 3px
saturation: 50%
severity: false
show_minmax: false
show_value: true
speed: 1000
tap_action: info
target: false
title: Free Space
title_style: false
value_style: false
visibility: false
width: 70%
- align: center
animation: auto
attribute: false
card_style: false
color: '#228B22'
decimal: false
delay: 5000
direction: right
entities:
- entity: sensor.cpu_temperature
height: 40px
icon: false
icon_style: false
indicator: auto
limit_value: false
max: 85
min: 0
minmax_style: false
padding: 4px
rounding: 3px
saturation: 50%
severity: null
show_minmax: false
show_value: true
speed: 1000
tap_action: info
target: false
title: CPU Temp
title_style: false
value_style: false
visibility: false
width: 70%
- align: center
animation: auto
attribute: false
card_style: false
color: '#483D8B'
decimal: false
delay: 5000
direction: right
entities:
- entity: sensor.cpu_speed
height: 40px
icon: false
icon_style: false
indicator: auto
limit_value: false
max: 1800
min: 0
minmax_style: false
padding: 4px
rounding: 3px
saturation: 50%
severity: false
show_minmax: false
show_value: true
speed: 1000
tap_action: info
target: false
title: CPU Speed
title_style: false
value_style: false
visibility: false
width: 70%
- entities:
- entity: input_boolean.restart_hass
- sensor.wan_ip
- sensor.last_boot
- sensor.uptime
- entity: sensor.cert_expiry_bertrum_duckdns_org
- entity: sensor.mariadb_pi4_size
icon: 'mdi:database'
- entity: sensor.ha_current_version
name: HA Current Version
- entity: sensor.hassio_current_version
name: Hassio Current Version
- entity: sensor.hacs
- entity: sensor.potential_breaking_changes
- entity: sensor.rpi_power_status
name: Pi PSU Status
type: entities
title: Raspberry Pi4
type: 'custom:vertical-stack-in-card'
Please have a look at this solution:
Soooo it looks like USB boot isn’t far off. Currently in beta testing if anyone is feeling brave. Would love to see this come to hassOS soon
Sorry this methode does not work, getting mesaages that this is not supported anymore, also i tried to get into home assisten via ip:8123 and nothing happend seems it is not working at all
on. my old raspberry pi3 i had it in venv but i wanted to make it easier and the installation of this should be easy but for somereason… it is or slow on sd card or not easy backup etc.
I would lik e to make easy snapshots because it is a hell to get the files good from my old pi3…
first i want to run this from a ssd and that seems to be impossible…
Minus a couple changes in the install process, this worked perfectly for me to run my rpi 4b off a 500gb USB 3.0 SSD. No SATA adapters, no boot from SD first, just USB 3.0 > USB-C on a Samsung T7 external SSD drive.
As for power, I did toss a 3A power supply on it and also plan to move the USB SSD to a powered USB Hub (just to keep things happy, cool, and powered), also probably toss an ice tower cooler on at some point to; but as of now, it runs 100x better and faster then my SD did — benchmarked at almost 8100. But… as noted, I did have to re-sync all my zigbee devices back into HA after the snapshot restore — Zwave devices weren’t effected though.
Steps:
Basically follow Skeynet01’s guide.
- First create a full Snapshot of your HA (minus DuckDNS & LetsEncrypt)
I personally went with buying another $15 64GB SD Card off amazon to attempt this with, so i had a fullproof backup SD if this all went to hell.
I then Flashed my new 64GB SD (using Apple Pie Baker on OSX) with “Raspberry Pi OS (32-bit) Lite“. It’s on the same link as within the guide (if you dont want to scroll up… its Here also, ENABLE SSH!
The next part of the guide takes you to Toms Hardware Tutorial which has been updated recently to reflect the new USB Boot on RPi4. You wont have to keep an SD in to boot anymore. Ill type out the steps here, since TomsHardware page is one of the most AD-riddled pages I’ve ever seen. Typically I’d support sites like this helping people, but there’s a limit. When the site is so ad-flooded it makes reading the content extremely difficult, i draw the line there… 50+ ads is too much, Tom.
3a) So at this point i had a fresh 32bit RaspberryOS Lite installed on my SD, and a blank MacOS Extended (Journaled) (also known as HFS+) formatted 500GB USB 3.0 SSD.
3b) Before i started doing the updates and such on the SD, i plugged the SSD in.
- If you followed Skynet01’s steps you should have enabled SSH to your SD. So now connect to it. “ssh pi@Your-PI-IP”. The default password is “raspberry” (you’ll want to change that later at some point with “passwd”, but not yet)
Run
sudo apt update
sudo apt full-upgrade
- Next, Edit the /etc/default/rpi-eeprom-update file and change the FIRMWARE_RELEASE_STATUS value from “critical” to “stable.” You can edit the file by typing:
sudo nano /etc/default/rpi-eeprom-update
Then hit CTL+X and then “Y” to save the edit and exit.
- now install the new bootloader by typing:
sudo rpi-eeprom-update -d -a
Now, Reboot
sudo reboot
let the RPi 4 boot up again, then SSH over to it the same way as before.
now check the firmware version to make sure you have the latest one. At the time of writing this, it should say “June 15”, which allows the RPi4 boot from USB
vcgencmd bootloader_version
Now Heres where i had to add a step. I had to run:
sudo rpi-update
You’ll get some warnings etc, just click through them and agree. For some reason i kept getting boot errors regarding start.elf and recovery.elf not being compatible — This fixed that.
No Longer needed after latest update
Now reboot again.
at this point you have a few options; i decided to go with a fresh 32-bit RaspberryOS Lite install on the SSD. I plugged it into my Mac and used “Raspberry Pi Imager” to download and install the OS on the SSD.
Now pop your SD into a computer and copy all the .DAT & .ELF files from the boot folder (on SD remember). I copied these to a folder on my desktop.
Now plug in your SSD and overwrite all the .DAT & .ELF files you took from the SD card. Also, copy over a blank ssh file as well so you can ssh over to the SSD.
Now, plug you SSD into one of the [blue] USB 3.0 slots (leave SD out) and boot up.
This can either be really quick, or take a really long time depending on how big your SSD drive is. For my 500GB drive, it took about 45min to boot up the first time. -
once its booted up, SSH over to it again, and continue to follow Skynet01’s guide above. Skipping over points 3 & 4. No need for the cmdline.txt edit or keeping your SD inserted to boot.
(If for some reason you cant SSH over to the new SSD, make sure you included that blank ssh file in the main boot dir)
Do those updates on your SSD. Then continue with the Docker install and HA etc as listed.
Once you’re all booted up and accessed your HA instance via IP:8123, you can install the SAMBA ADD-ON and copy your saved snapshot into the BACKUP folder and restore.
Everything restored for me fine, except Zigbee devices. I had to set those up again. I’m using the HUSBZB-1 USB for zwave & Zigbee.
This method worked perfectly for me, and I’m running so much faster then i was before on my SD.
Thank you for this update, worked perfectly for me with a samsung T5 portable drive!
PSA: I recently had an issue where the zwave stick (and a spare stick) would start but I couldn’t add any nodes on an Rpi4 using an SSD. After days of diagnosis it turns out that the USB3 ports on the pi seems to put out some interference. It didn’t matter if the stick was in the USB3 or USB2 ports. Using a hub or even a very short USB extension wire solved all of my problems. It only took 2-3" of distance from the port to work.
This is a very valid PSA. I also experienced this issue myself; and it took forever to figure out what the problem was. My problem was with ZHA not Zwave networks dropping devices or going offline constantly on my HUSBZB-1 Stick. A simple USB extension (i moved mine 6ft) fixed the issue.
Here steps how I did it. Debian 64Bit + SSD + RPI4
Finally got the Debian 10 64Bit image running on SSD on a RPi4
https://downloads.raspberrypi.org/raspios_arm64/images/raspios_arm64-2020-05-28/2020-05-27-raspios-buster-arm64.zip
Flash image on a SDCard. Add SDcard and your SSD to your RPi4
You can also add already ssh option and you wifi settings on the /boot/ partition of SDcard
Remove the old dphys version
sudo /etc/init.d/dphys-swapfile stop
sudo apt-get remove --purge dphys-swapfile
Refresh your OS
sudo apt-get update
sudo apt-get full-upgrade
Prepare RPi4 for USB Boot
Refresh your OS with the latest firmware
reboot
Install RPICLONE (For cloning from SDCard to my SSD, my SSD is /dev/sda, yours can be different)
git clone https://github.com/billw2/rpi-clone.git
cd rpi-clone
sudo cp rpi-clone rpi-clone-setup /usr/local/sbin
sudo rpi-clone sda
After RPICLONE is done open a new terminal window
nano /mnt/clone/boot/cmdconfig.txt
Add rootdelay=5 cgroup_memory=1 cgroup_enable=memory to the line and save the file.
Exit the terminal
shutdown now
Remove the SDCard and boot from SSD now.
Correct location and timezone
raspi-config
Install Docker
sudo -i
apt-get install software-properties-common -y
apt-get update
apt-get install modemmanager
reboot now
Reason I install modem manager first and reboot, because when do with network-manager my RPi freeze
apt-get install network-manager
apt-get install apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq socat bash curl
curl -fsSL get.docker.com | sh
Install Hass.io
systemctl stop ModemManager
systemctl disable ModemManager
curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s -- -m raspberrypi4
DONE
Thanks for this, used it on raspbian, worked fine.
Hi
I’m trying to install Hassio with docker on a Rpi4 8GB
I’ve been running an external USB3.0 SSD for a while now and also a number of containers but unable to get Hassio working
I’ve followed the instructions on here even installed a fresh OS and still no luck
I’m running Raspberry Pi OS (64 bit)
I’ve installed docker and all the apt-get updates and software
Then run the following command
The error I get is below when running the following script
curl -sL https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh | bash -s -- -m raspberrypi4-64
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds…
[warn]
[info] Creating NetworkManager configuration
[info] Restarting NetworkManager
[info] Install supervisor Docker container
Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 192.168.0.1:53: dial udp 192.168.0.1:53: connect: network is unreachable
The NetworkManager is odd, as sometimes accessing the Rpi4 via remote SSH it drops out when running script and must take over the TCP/IP stack
The WLAN0 interface then has no IP address and unable to access
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether ca:28:44:e9:0f:5e txqueuelen 1000 (Ethernet)
RX packets 406 bytes 95365 (93.1 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 181 bytes 23460 (22.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
So if I run the script from the Rpi4 console/terminal its running local but still fails
The error 192.168.0.1:53 is my gateway and also DNS server. I’ve overwritten this with 8.8.8.8 and still doesn’t work.
I can pull down other docker containers and the Rpi4 has been working fine for months
Its just running this script
Any ideas please
@miniwilliams did a couple rpi’s last few weeks for myself and others.
Didnt saw these issues.
Maybe its something with the hw network layer of your rpi wrong?
can you test if it stable?
Hello, is anybody using Rpi4 1 Gb with Docker and HA?
Mine worked ok for 4 months until yesterday, now it is not responding anymore, CPU is all the time 100%.
Is the Rpi4 1Gb too weak for HA or what could be the problem?
How I am thinking to save the backups from the SSD and redo the whole installation from scratch but this will take a while.
I just updated RaspiOs (I am updating regulary since I have RPI4) and the HA did not started. I am using instalation mensioned in this thread - Home assistant on Docker on Raspbian. Any clue?
Can confirm this. I am using Raspbian Buster, RPI 4 8GB.
Performed sudo apt update and then sudo apt upgrade and then rebooted. Now, I can’t reach my Homeassistant anymore.
If I loock at running containers, there are just one???
pi@raspberrypi:~ $ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
103256927bdd homeassistant/armv7-hassio-observer:2020.10.1 "/init" 8 weeks ago Up 46 minutes 0.0.0.0:4357->80/tcp hassio_observer
I could bet that there should have been more?
Another output (docker cointainer ls):
pi@raspberrypi:~ $ sudo docker container ls
103256927bdd homeassistant/armv7-hassio-observer:2020.10.1 "/init" 8 weeks ago Up 59 minutes 0.0.0.0:4357->80/tcp hassio_observer
Do I need to start from scratch again? Format SSD/reinstall OS/reinstall Hassio? Can I use my full backup?
Something really fishy is going here?
There is an alert about the latest docker. See here https://alerts.home-assistant.io/#docker_2010.markdown
