Started with HA 0.114.4
After reading topic RFXCOM ok with 0.113, nok with 0.114.x i upgraded HA to Beta 0.115.0b9 same issue
Downgraded HA to 0.113.0 same issue
Connect the RFXcom to a windows machine upgrade the firware in the Rfxcom manager i see its working, getting all kind of info in the screen.
Connected the RFXcom to another USB port on the RPI
In the configuration.yaml
Changed configuration too.
Let’s start at the beginning, first connect your rfxtrx to your pi and go to /dev/serial/by-id folder. Look for something like usb-RFXCOM_RFXtrx433_A1Y0NJGR-if00-port0. Make a note of the exact name. Next add the following to configuration.yaml (with the name of your own device of course). Avoid using ttyUSB1 or 0 as this number can change on a restart or unplugging the usb cable.
Now restart home assistant. Next turn on a light or switch by clicking on the remote/wall switch to automatically discover your devices. They should appear after clicking the button, look e.g. in developer tools —> states. Note that a switch can be detected as a light or vice versa. You can change that later.
I sent the RFXcom back for waranty. the power disconnects when you touch the usb cable.
The topic can be closed for now, when i receive a new RFXcom and have issues again it come back on it.
