Rpi 5 HA freeze(Hangs)
I have Rpi5 with 4 GB of RAM running on core HA .
The HA is frezing few times a day yet I cannot find th root cause because logs ar not persisitent .
HA is reachabl by ping but Gui is not accessible .( As well as functions do not run)
I replaced the SD card to brand new one - yet same symptom.
I as well replaced the power supply but I see that th power consumption is ~ 3.5W
Any assistance ? Ideas ? will be highly appreciated ?
Current log since reboot
Data from HA
System Information
version core-2025.1.4
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.13.1
os_name Linux
os_version 6.6.62-haos-raspi
arch aarch64
timezone Asia/Jerusalem
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
HACS Data ok
GitHub API Calls Remaining 5000
Installed Version 2.0.5
Stage running
Available Repositories 1575
Downloaded Repositories 31
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 14.2
update_channel stable
supervisor_version supervisor-2024.12.3
agent_version 1.6.0
docker_version 27.2.0
disk_total 28.5 GB
disk_used 9.9 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board rpi5-64
supervisor_api ok
version_api ok
installed_addons File editor (5.8.0), Advanced SSH & Web Terminal (20.0.0), Samba share (12.4.0), Node-RED (19.0.0), TasmoAdmin (0.31.3), Mosquitto broker (6.5.0), FTP (5.1.1), Home Assistant Google Drive Backup (0.112.1), Terminal & SSH (9.16.0), Cloudflared (5.2.7), go2rtc (1.9.8), Tailscale (0.24.0)
Dashboards
dashboards 6
resources 11
views 25
mode storage
Recorder
oldest_recorder_run December 31, 2024 at 4:20 PM
current_recorder_run January 31, 2025 at 10:25 AM
estimated_db_size 2313.50 MiB
database_engine sqlite
database_version 3.47.1
Sonoff
version 3.8.2 (c4b6fda)
cloud_online 1 / 1
local_online 1 / 1
How to Troubleshoot Raspberry Pi Crashing.
