I have the exact same wish and situation as you have, @tbrasser, but I’ve yet to come to a good enough solution.
I’ve tried usbip for a while, and while it definitely works, it’s a bit of a hassle and requires higher maintenance than I’d like, as well as being very tied to a single machine for the HA container. Also, each restart of HA implies restarting the Z-wave-network as well, which is slow and unpractical. The same argument would apply to socat/ser2net as well, since it relies on software to make a remote serial device in /dev on the machine running the HA instance.
This means, for instance, that I can’t run HA in a container cluster environment, such as Docker Swarm or Kubernetes as I require a local, machine specific resource, that is /dev/tty[something].
I suppose, I could run usbipd in a privileged sidecar container, and as such would be able to run it in a cluster, with the negative point about this solution being running the sidecar as “privileged”, and having to have strict order on container deployment so that I can mount in /dev/tty[something] into the HA container.
I would wish for a Zwave over MQTT solution or similar that actually worked great also for situations as in your “EDIT3”, @tbrasser. I’m not entirely sure how it could be implemented to still take advantage of all the Z-wave features. I think the computer with the Z-wave-stick would run openzwave, and act as a gateway with an API.
I think perhaps that the solution is coming from SiLabs itself, in the form of Z-Wave 700 with Z/IP (Z-wave to IP), as described here: https://www.silabs.com/products/wireless/mesh-networking/z-wave/700-platform/z-wave-700-gateway-development
This is a UDP wrapper for Z-wave command classes, and handles Z-wave network management, security and has a “mailbox” for battery driven devices.
Apparently, we should be able to buy a “Z-Wave 700 Development Kit” (SLWSTK6050A) for a cool USD 379.
Any thoughts?
