Running a script or command every 5 minutes
Hello community,
I’m trying to run a script or simply a command every 5 minutes, for that purpose I created an automation:
- alias: ping_gw
    platform: time
    minutes: '/5'
    seconds: 00
    service: shell_command.start_ping
Then in configuration.yaml I definied the shell_command:
shell_command:
  start_ping: "pkill ping ; ping 192.168.2.45 > /dev/null &"
But it doesn’t work, could someone advise?
Thank you
Lucas
No one? :roll_eyes:
Have you solved this?
platform: time_pattern
Not
platform: time
Thanks for a reply! My problem was a missing “/” before the number, I found the solution in the documentation. Btw I think that there is a bit wrong description in the documentation. Currently you don’t need to put “*” for other fields in the UI. The documentation still says you must add it.
You did not paste your code so nobody could have guessed that. All I had to go on was the error in the original post.
Then please do your bit as a community member and fix it:
