I’ve just come back from a few days away and am checking on the state of my HA. It’s running on a Pi B with a 2GB SD card. I found that it had no space left! The db file is 143M and the log was over 40M. I deleted the log just so I could actually do anything, although it seemed to be running fine. That seems like a big database for a fairly simple setup.
Is 2GB a viable card size? The Pi isn’t doing anything apart from HA. I started with a Hassbian image. Is there anything I can remove from that without affecting functionality?
@PtP Thanks for the link. I’ll try setting the purge to a few days. I really only need history to check if things are working. Not sure I want to get into changing the database.
@ReneTode I do have some bigger cards and I may look at migrating to one of those.
