I think would be nice to have a sensor for an network interface sent and received bytes. Maybe publish everything from a xpath expression. eg: “Device/PPP/Interfaces/Interface/Stats”
Every time the integration connects to do router it does a login?
Thanks @andrempo! Do you perhaps have Python skills? I am still looking for contributors for this integration, since I didn’t have much time to work on it. The API should be solid, but the Home Assistant integration needs a lot of love.
It keeps the session open, thus it will just re login when required.
There was just a great contribution from arunpoudel, thus the issues with home/unavailable should be fixed!
It will be merged soon, but in the mean-time you could give this version a try. Extract the custom_components/sagemcom_fast to your custom_components folder.
I wonder if it would make sense to eventually add this integration to Home Assistant core. Are people actually using this integration?
Could you share the first 6 digits (vendor) of the MAC address of your router? I wonder if all Sagemcom F@st routers share the same vendor id, thus we could add auto discover.
Hello, I have a quick question, is reboot working ok for devices? As tried and it does not works for my Sagemcom F@st5360, wonder if the problem is with this model only
I think it would be useful to add a sensor that tracks your external IP from “Device/IP/Interfaces/Interface[1]” (with other subnet, gateway etc in sensor attributes)
Hi Mick, I’m using a router privided by my ISP labeled as Sagemcom FAST3890V2. I saw that FAST3890V3 is supported, so I tried to integrate with HA expecting either to work flawlessly or to see some errors in log viewer . Despite configuring the log for this custom component to critical nothing shows up. I tested another custom component (tuya v2 integration) and I know for sure that logger used to show info from it. Any idea what might be going on?
This is the only line refered to this integration
2021-08-05 00:43:23 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sagemcom_fast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Hi, i managed to install your addon by uploading the files.
since the repo did not work.
and it was all success i see all my devices in the entity. i use Sagemcom F@st 3890V3.
This is SUPER awsome tool! please keep working on this feaure.
First of all, I would like to say: Really good work!
I use a Speedport Pro and had to make a few adjustments.
Firstly, the timeout had to be changed, otherwise errors would keep occurring: init.py line 54:
from: session = aiohttp_client.async_get_clientsession(hass)
to: session = aiohttp_client.async_create_clientsession(hass, timeout=ClientTimeout(20))
and at the beginning of the file: from aiohttp import ClientTimeout
Maybe you could make the timeout adjustable during the setup?
Furthermore, the reboot service did not work, so I adapted the following: init.py line 131:
from client.reboot()
to await client.reboot()
now everything works as it should,
However, I only use the reboot function myself.
Thanks for reporting! What kind of errors did you face with the default time out? In my tests I only faced these errors during login, when I chose the wrong authentication method.
Are you able to do a pull request on GitHub with your changes? Otherwise I will see if I can adapt them in the coming weeks.
