[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] samba.sh: executing...
[18:02:25] INFO: Hostname: xxx-nuc
[18:02:25] INFO: Interfaces: wlp1s0 lo
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
account_policy_get: tdb_fetch_uint32_t failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
Added user *user*.
[cont-init.d] samba.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
nmbd version 4.13.17 started.
Copyright Andrew Tridgell and the Samba Team 1992-2020
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
smbd version 4.13.17 started.
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
Processing section "[media]"
interpret_interface: Can't find address for wlp1s0
added interface lo ip=::1 bcast= netmask=ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
added interface lo ip=127.0.0.1 bcast=127.255.255.255 netmask=255.0.0.0
daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
INFO: Profiling support unavailable in this build.
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
i dunno but i have been having problems since the last update 9.5.1. something obliterated my network config and i sure as hell do not feel like reinstalling from scratch. there must be an easier way just to completely reset the network configuration back to factory but i have not found anything.
sorry i cant help you any with your problem but if its any consideration here is my lg output from samba
[fix-attrs.d] done.
[00:12:37] INFO: Hostname: homeassistant
[00:12:37] INFO: Interfaces: eth0 lo
Added user homeassistant.
[cont-init.d] done.
[services.d] done.
added interface eth0 ip=192.168.254.33 bcast=192.168.254.255 netmask=255.255.255.0
create_subnets: Ignoring loopback interface.
create_subnets: ignoring non IPv4 interface.
making subnet name:192.168.254.33 Broadcast address:192.168.254.255 Subnet mask:255.255.255.0
making subnet name:UNICAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
making subnet name:REMOTE_BROADCAST_SUBNET Broadcast address:0.0.0.0 Subnet mask:0.0.0.0
daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
queue_query_name: interface 1 has NULL IP address !
if anyone knows anything please for the love of god helpā¦ my wall cannot take much more head bashing
whats even funnier isā¦ there is no way to downgrade to a different version without a backup. and stupid me did not create any backups except for the first few days i had it up and running. but something to do with samba has completely broken my hyperv install of hass
Agree with you on this @tom_l. The Samba add-on should be using the eno1 interface (and was successfully for years now thru Samba 9.5.1), now w/ upgrade to 9.6 it ignores eno1 and tries using wlp1s0, with no success.
Also worth noting Iāve tried both with and without the:
interface: eno1
option in the configuration settings. (Also tried with interface: "" which some previous poster[s] found success with). Each yielded the exact same failed result / log output as posted above. (Historically, this option was not included in my config settings for this addon.)
Lastly, someone on Discord asked about my HA network settings, they appear like this:
configuration.yaml has #default_config: commented out, and does not contain network: This have had no adverse affect on my setup to date and has not changed in years.
Looking at your posted logs at Github I see exactly the same behavior as with Markās Samba failure to start: Samba is trying to build-up a connection through WiFi (wlp-xxx) instead through the default NIC.
I am using a NUC i3 running Ubuntu and I just checked ( to be sure as I only ever use the RJ45 Ethernet port) the WiFi and the WiFi adapter is not enabled.
Similar problem here.
Tried manual and auto configure in HA config.
My adapter is eth0, see image.
SAMBA does detect only Io, but the rest of the log is similar.
[fix-attrs.d] done.
[20:10:42] INFO: Hostname: homeassistant
[20:10:42] INFO: Interfaces: lo
Added user zsolt.
[cont-init.d] done.
[services.d] done.
On all supported interfaces. I notice in the issue the author says they are running supervised on an unsupported os (put āotherā). And above in the posts is mention of Ubuntu (also not supported).
Iāll talk it over with the supervisor team but Iām not going to immediately revert this change without a report of something breaking for a user on a supported system as there was a lot of requests to support multiple interfaces in the samba addon.
EDIT: btw if anyone is seeing issues with this update on a supported system please make a new issue with those details.
Forgive my lack of technical expertise. Iām not trying to have this ārolled backā, simply prefer to not adversely affect my current setup. My ip addr shows the wlp1s0 interface as down, yet this is the one post-upgrade the new code is trying to have Samba use? Again, not an expert, but canāt this simply be filtered out and the eno1 interface be used? Clearly this interface has worked for years now before this upgrade, so seems it should be able to be included and used after the upgrade?
Sure I get it. But HA doesnāt support your system given the installation method youāve chosen, you do. If you switch to a supported installation method and this change still causes issues then we will make sure to fix them. If you run on an unsupported OS though then you should prepare to face unexpected breaking changes at any time with any update. There is no testing done on unsupported OSās so its very likely there will be no warning at all. And youāll need to be prepared to fix what broke yourself.
Thanks for the pointerā¦ I use Samba daily and would be crippled without.
Obviously I am holding out on that upgrade and will watch this thread for updates.
As it been reported to the maker(s)
