I cannot connect from my win11 pc to home assistant via samba share…
In config of samba i wrote the IP of my PC und then i go to win explorer und type //192.168 …
But there is allways the same issue report:
Cannot connect to server
Can anybody help?
tom_l
February 15, 2022, 10:39am
2
Share your actual addon config. Local addresses are not routable on the internet so there is no need to obscure them. You can obscure the password and username.
Also you seem to be under the impression that this addon will share data from your PC to Home Assistant. It will not. It will only share from Home Assistant to your PC. Or maybe it is a language thing.
Yes i only want the connection from HA → PC
tom_l
February 15, 2022, 11:54am
4
You have some redundant hosts information there, 192.168.178.60/24
includes all the 192.168.178.x
addresses.
In windows what happens when you type \\<your_home_assistant_ip_address>
in the file explorer address bar?
Does it ask you for credentials.
What ip addresses are your PC and Home Assistant on?
Are they in the same subnet?
RaspPi an PC IP adress
Adress with :8123
Adress without :8123
…always the same → network issue, cannot connect to this host
petro
(Petro)
February 15, 2022, 12:17pm
6
You’re going to have to translate those messages. Are you connecting with the credentials you have listed?
petro
(Petro)
February 15, 2022, 12:18pm
7
Also, I believe you need to have network discovery enabled in Windows if I recall correctly.
I don’t think this is going to work. I believe this add-on only gives access TO Home Assistant folders FROM a PC.
Home Assistant can NOT see PC shares using this add-on.
Yes i only want to see a few HA folders on my PC!
…sorry for my english…
But whats going wrong? There are many youtube tutorials. It works great but not in my case
Yes i am connected to the credentials i have listed and i have also enabled the privat network discovery
petro
(Petro)
February 15, 2022, 1:13pm
12
Ok, so can you translate those errors then please?
Ok, ill go to work now and later about 10 hours ill post…
Thx
w35l3y
(w35l3y)
February 15, 2022, 11:41pm
14
In my case, I had to activate compatibility mode.
compatibility_mode: true
I set the compatibility mode to true but dont work
My IP… (the rasPI IP i have already showed in pics before)
…and the issue report only says that this issue cannot be identified
tom_l
February 16, 2022, 12:42am
16
You most definitely should not be attempting to use SAMBA over the internet.
Yes only on privat network but dont works…
What should i type into samba config to get it work?
tom_l
February 16, 2022, 1:11am
18
Why do you have your public ip address in the allowed hosts then?
Remove it.
Because i am a dude and try everything to get run this samba
But ok i remove it
petro
(Petro)
February 16, 2022, 1:20am
20
You’re going to actually have to translate that error. That error code is generic and does not correlate with the text.
