My Samsung refrigerator with the screen in it had a software update the other day (change from Tizen 3.0 to 4.0 I believe). Since then, the view from inside the fridge is no longer available on my HA. This occurred while running 0.91.4, and still doesn’t work after upgrading to 0.94.1.
Any thoughts or fixes would be appreciate.
I am running the 0.94.1 on a RPi3.
I can confirm this issue. My fridge just updated a couple of days ago and the image no longer works. I’m guessing how to access the camera has changed from Tizen 3.0 to 4.0. Unfortunately I don’t know where to start. If there is an underlying Python library, it probably has to be updated before it will work with HASS again.
EDIT: There is an issue in the HASS GitHub here.
I created an issue for the Samsung camera as well, but it wasn’t related to the tizen update. I think something in Home Assistant updated broke the configuration. The issue occurred when I updated from 0.93.2 to 0.94
https://github.com/home-assistant/home-assistant/issues/24327
were there any updates on this?
Im having the same issue.
GitHub here (diffrent to one above): https://github.com/home-assistant/home-assistant/issues/24327
I opened a new issue on github more specificity for the issue I am having:
https://github.com/home-assistant/home-assistant/issues/28473
