worked perfectly, thanks
This is great and it would be awesome if there was a way to pipe the sensor data from the watch into HA like the phone app
I was finally able to send the token and the URL to the watch, but it now says āAn error has occurred. Status code 0. Check network connection or home assistant URL in settingsā Iām using the local URL http://homeassistant.local:8123/, should I be using the HS cloud URL? Also, Iām very sure that the Long-Lived Access Token is correct. They are both visible in settings. Any ideas?
Hello, how did you copy the token? I have just manual input in token field on my watch and im not sure if i'm writting de letter O or the number 0, same with the capital i or l. Is there a easy way to copy and paste or other method?
P.S. It's still working, the app?
I didnāt type the token. I followed these instructions:
Yes, it still works
Thanks Jan!
You saved my day! Tried to type the token manually
A suggestion / request for the app, NFC reading , that would be great would make things alot easy.
great work
Does anyone know of a more up to date fork of this app? - Seems this was abandoned a few years ago, but has a lot of potential!
If it could filter, or even display by HA area then that would be amazing.
Alternatively, are there any other options that work for the Galaxy Watch 3 ? - I did see there are 3rd party Alexa / Google Assistant appsā¦ but not sure how I feel about giving my credentials to such appsā¦
Been trying to get this app to work.
Tried the idea above to follow the link hassgalaxy.app/XXXX
when I enter the Address and Code it has the error āNot Foundā
tried to reinstall the app a few times, create a new tokenā¦not sure why i get the error
i had it installed on my watch for less than 2 days. i normally charge my watch once every 4 or 5 days, with this installed, i had to charge it 3 times in less than 2 days
Iām having the same issue.
āNot found.ā
Itās a timing issue. Once you open the app on your watch and get given the code hassgalaxy.app/xxxx
You have about 30 secs ( this might be an exaggeration. Itās more like 35secs) to type your HA address and paste the token and submit.
If it say ānot foundā
Close the app on your watch and reopen it to get a new code, go again but faster
Justamente isso apanhei durante um tempo, mais consegui realizando o processo dentro do tempo, obrigado pela dica!
Will be amazing to use it, i still donāt understand how to copy and past the token on the phone, is it possible?! someone can help me?
Look at peoples post above. the instructions are simple but you need to be fast!
The app gives you a webpage to visit - hassgalaxy.app/XXXX
have this typed in a search bar on a pc āwww.hassgalaxy.app/ā just waiting for you to type in your code and press enter
Have your Long Life Token already generated and ready to copy/paste
open the watch app and complete the steps in about 30sec or get ready to start again
- type in website on your watch and press enter
- it will be a simple page for you to added details
- paste in code
- submit
your watch app should start to update and you need to accept some auth things and that is it.
iām sure most people will agree, you don;t work it out first go!
Look how I connected the watch to HA! First I installed G-KEYBOARD PRO on my watch and phone, after that I sent the token created by HA on whatsapp and from the phone I sent the HA Url and Token to the watch.
@Beeble1983 sorry but that appears to not be true. The app on my watch doesnāt give me any web site to visit. My watch only has several buttons that do nothing, except for the settings button, and when I select that, it asks me for a url and a token. The token I generated in HA has about 300 characters, and I CANNOT type the 300 characters with ridiculous chicklet keys perfectly on a field I am populating that does not allow me to even see the field I am trying to fill in:
and when I go to the āhassgalaxy.appā web site, it just shows this:
I think I see the issue you are having, (needed to restart my watch app too, so i need to re-connect)
The page I speak of does flash up when you open the app on your watch,
but very quickly, another page appears āError connecting to Web Socketā
might be the end of that methodā¦
www.hassgalaxy.app/ [the unique code displayed is required in the address, to connect to your watch]
Seems like itās not even worth the effort - especially as Iāve seen people post complaints about it using up the watch battery quickly, so thatās useless too!
I have seen those comments too, and donāt agree!!, not as dramatic as was implied anyway.
Did I use the app a lot, no!
Although I had a lot configured on it. Iād only use it for 2 specific lights under my house.
Long way of saying, if you find here, it is still working give it a go. itās worth a tinker
(Iām looking to get it back if I can)
