Samsungtv turn on with WOL
I’ve found that the latest update to samsungtv isn’t all that reliable with tizen/2016+ tvs when sending commands. They are delayed or never get there… I haven’t figured it out yet (or submitted a report) but I did add the ability to turn on using Wake on Lan (WOL). Below is the modified py file that I have in …/custom_components/media_player
then add mac to your config:
- platform: samsungtv
  host: 192.168.1.183
  port: 8001
  mac: B8:BB:AF:49:C6:F3
This may be worth submitting as a PR but I wanted to get feedback on it first and see if is working for others.
samsungtv.py
Support for interface with an Samsung TV.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/media_player.samsungtv/
import logging
import socket
import voluptuous as vol
from homeassistant.components.media_player import (
    SUPPORT_NEXT_TRACK, SUPPORT_PAUSE, SUPPORT_PREVIOUS_TRACK,
    SUPPORT_TURN_ON, SUPPORT_TURN_OFF, SUPPORT_VOLUME_MUTE, SUPPORT_VOLUME_STEP,
    SUPPORT_PLAY, MediaPlayerDevice, PLATFORM_SCHEMA)
from homeassistant.const import (
    CONF_HOST, CONF_NAME, STATE_OFF, STATE_ON, STATE_UNKNOWN, CONF_PORT, CONF_MAC)
import homeassistant.helpers.config_validation as cv
REQUIREMENTS = ['samsungctl==0.6.0',
                'wakeonlan==0.2.2']
_LOGGER = logging.getLogger(__name__)
CONF_TIMEOUT = 'timeout'
DEFAULT_NAME = 'Samsung TV Remote'
DEFAULT_PORT = 55000
DEFAULT_TIMEOUT = 0
KNOWN_DEVICES_KEY = 'samsungtv_known_devices'
SUPPORT_SAMSUNGTV = SUPPORT_PAUSE | SUPPORT_VOLUME_STEP | \
    SUPPORT_VOLUME_MUTE | SUPPORT_PREVIOUS_TRACK | \
    SUPPORT_NEXT_TRACK | SUPPORT_TURN_OFF | SUPPORT_PLAY
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_HOST): cv.string,
    vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
    vol.Optional(CONF_PORT, default=DEFAULT_PORT): cv.port,
    vol.Optional(CONF_MAC): cv.string,
    vol.Optional(CONF_TIMEOUT, default=DEFAULT_TIMEOUT): cv.positive_int,
# pylint: disable=unused-argument
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Setup the Samsung TV platform."""
    known_devices = hass.data.get(KNOWN_DEVICES_KEY)
    if known_devices is None:
        known_devices = set()
        hass.data[KNOWN_DEVICES_KEY] = known_devices
    # Is this a manual configuration?
    if config.get(CONF_HOST) is not None:
        host = config.get(CONF_HOST)
        port = config.get(CONF_PORT)
        name = config.get(CONF_NAME)
        mac = config.get(CONF_MAC)
        timeout = config.get(CONF_TIMEOUT)
    elif discovery_info is not None:
        tv_name, model, host = discovery_info
        name = "{} ({})".format(tv_name, model)
        port = DEFAULT_PORT
        timeout = DEFAULT_TIMEOUT
    else:
        _LOGGER.warning(
            'Internal error on samsungtv component. Cannot determine device')
        return
    # Only add a device once, so discovered devices do not override manual
    # config.
    ip_addr = socket.gethostbyname(host)
    if ip_addr not in known_devices:
        known_devices.add(ip_addr)
        add_devices([SamsungTVDevice(host, port, name, mac, timeout)])
        _LOGGER.info("Samsung TV %s:%d added as '%s'", host, port, name)
    else:
        _LOGGER.info("Ignoring duplicate Samsung TV %s:%d", host, port)
class SamsungTVDevice(MediaPlayerDevice):
    """Representation of a Samsung TV."""
    def __init__(self, host, port, name, mac, timeout):
        """Initialize the Samsung device."""
        from samsungctl import exceptions
        from samsungctl import Remote
        from wakeonlan import wol
        # Save a reference to the imported classes
        self._exceptions_class = exceptions
        self._remote_class = Remote
        self._name = name
        self._wol = wol
        self._mac = mac
        # Assume that the TV is not muted
        self._muted = False
        # Assume that the TV is in Play mode
        self._playing = True
        self._state = STATE_UNKNOWN
        self._remote = None
        # Generate a configuration for the Samsung library
        self._config = {
            'name': 'HomeAssistant',
            'description': name,
            'id': 'ha.component.samsung',
            'port': port,
            'host': host,
            'timeout': timeout,
        if self._config['port'] == 8001:
            self._config['method'] = 'websocket'
        else:
            self._config['method'] = 'legacy'
    def update(self):
        """Retrieve the latest data."""
        # Send an empty key to see if we are still connected
        return self.send_key('KEY')
    def get_remote(self):
        """Create or return a remote control instance."""
        if self._remote is None:
            # We need to create a new instance to reconnect.
            self._remote = self._remote_class(self._config)
        return self._remote
    def send_key(self, key):
        """Send a key to the tv and handles exceptions."""
        try:
            self.get_remote().control(key)
            if key == 'KEY_POWER' or key == 'KEY_POWEROFF':
                # Force closing of remote session to provide instant UI feedback
                self.get_remote().close()
                self._state = STATE_OFF
            else:
                self._state = STATE_ON
        except (self._exceptions_class.UnhandledResponse,
                self._exceptions_class.AccessDenied, BrokenPipeError):
            # We got a response so it's on.
            # BrokenPipe can occur when the commands is sent to fast
            self._remote = None
            return False
        except (self._exceptions_class.ConnectionClosed, OSError):
            self._remote = None
            return False
        return True
    @property
    def name(self):
        """Return the name of the device."""
        return self._name
    @property
    def state(self):
        """Return the state of the device."""
        return self._state
    @property
    def is_volume_muted(self):
        """Boolean if volume is currently muted."""
        return self._muted
    @property
    def supported_features(self):
        """Flag of media commands that are supported."""
        if self._mac:
          return SUPPORT_SAMSUNGTV | SUPPORT_TURN_ON
    def turn_on(self):
        """Turn on the media player."""
        if self._mac:
            self._wol.send_magic_packet(self._mac)
        self.update()
    def turn_off(self):
        """Turn off media player."""
        self.update()
        if self._config['method'] == 'websocket':
            self.send_key('KEY_POWER')
        else:
            self.send_key('KEY_POWEROFF')
    def volume_up(self):
        """Volume up the media player."""
        self.send_key('KEY_VOLUP')
    def volume_down(self):
        """Volume down media player."""
        self.send_key('KEY_VOLDOWN')
    def mute_volume(self, mute):
        """Send mute command."""
        self.send_key('KEY_MUTE')
        self.update()
    def media_play_pause(self):
        """Simulate play pause media player."""
        if self._playing:
            self.media_pause()
        else:
            self.media_play()
        self.update()
    def media_play(self):
        """Send play command."""
        self.send_key('KEY_PLAY')
        self.update()
    def media_pause(self):
        """Send media pause command to media player."""
        self._playing = False
        self.send_key('KEY_PAUSE')
        self.update()
    def media_next_track(self):
        """Send next track command."""
        self.send_key('KEY_FF')
        self.update()
    def media_previous_track(self):
        """Send the previous track command."""
        self.send_key('KEY_REWIND')
        self.update()
    # def turn_on(self):
        # """Turn the media player on."""
        # self.send_key('KEY_POWERON')
Sorry to report bad news but I am getting the same results from my previous post. Added the samsungtv.py into config_directory/custom_components/media_player. Am i supposed to see a on button on the front end to turn on the TV? Thanks for trying to get this working. :slight_smile:
Hi
Where is this directory: config_directory/custom_components/media_player
I cannot find it .
You probably have to create it. Find your configuration.yaml file and create a folder next to it called custom_components.
Inside that, create media_player folder. Then paste the above file in there as samsungtv.py
I tried this but got error re: “websocket”
normal samsungtv component works. Any idea?
i named and loaded the custom component as samsungtv1
same error whennamed and run as samsungtv
17-02-16 15:33:19 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
    result = coro.throw(exc)
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 387, in _update_entity_states
    yield from update_coro
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 209, in async_update_ha_state
    yield from self.hass.loop.run_in_executor(None, self.update)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/home/pi/.homeassistant/custom_components/media_player/samsungtv1.py", line 122, in update
  File "/home/pi/.homeassistant/custom_components/media_player/samsungtv1.py", line 135, in send_key
  File "/home/pi/.homeassistant/custom_components/media_player/samsungtv1.py", line 128, in get_remote
  File "/home/pi/.homeassistant/deps/samsungctl/remote.py", line 10, in __init__
    self.remote = RemoteWebsocket(config)
  File "/home/pi/.homeassistant/deps/samsungctl/remote_websocket.py", line 13, in __init__
    import websocket
ImportError: No module named 'websocket'
Hmm, only difference from the default one is an added import and an updated ‘turn on’ method so not sure why you’d run into that… What does your configuration.yaml look like?
configuration.yaml
media_player: !include media_player.yaml
mediaplayer.yaml
#                            SAMSUNG TV                             #
- platform: samsungtv1
  host: 192.185.185.20
  port: 8001
  mac: f8:04:2e:17:8d:d2
  name: Living Room TV
normal component worked with no issue
I looked and didnt see any additions to cause this either.
im getting the exact same error.
Incorrect port seems to be the issue.
I ran on different port and NO error(still didn’t work but my TV 2014 so compatibility is problem there)
Port 8001 is for Tizen / 2016+ TVs and uses websockets - older TVs need to be on the original port 55000. Try making that adjustment if you are on an older model and see if that eliminates the error(s).
doesnt work for me I have used port 55000 as my tv is 2015 and on HA it does show up with only the power switch but if I use port 8001 I do get the media switches i.e. forward,rewind,play etc but none of them work.
There is a PR (not from me) to put this into the production version of the component. May be worth waiting for that to go live before digging into the details.
I am getting this error
17-03-05 05:55:01 ERROR (MainThread) [homeassistant.components] Testing configuration at /home/homeassistant/.homeassistant
Fatal error while loading config: source code string cannot contain null bytes
Failed config
General Errors:
- source code string cannot contain null bytes
Successful config (partial)
The latest build has this built into the Samsung component. Give it a try.
I have the exact same issue.
Me too. Tv from 2015.
