With the current integration its not possible to arm 2 partitions at once. You will have to use an output which is linked to a zone in Integra itself (the zone would be a set/disarm at which you can assign partitions) or create an automation / script that arms the partitions after each other.
You do not arm zones, you arm partitions. But you can disable zones when you arm a partition.
Thats what the macro will do for you. Its possible todo this with activating outputs that are connected to zones that disable zones (Sound confusing, but simple enough :D)
Not with the current integration. Its there in the protocol you just send 0x7D +1 byte the 1 byte being the zone number (1-256). Youâll get an answer with the zone number and temperature (`0x006E being 0 Celsius, 0x006F being 1⌠ect ect)
You could request for this to be added, or i suppose fork this integration and adjust it yourself. Might even look at that myself. Tho i might not be able to decipher the code The one i did for Gira Homeserver is pretty hacky⌠but it works
I remember (perhaps a false memory) that it wasnât necessary to enter your code when arming or disarming the alarm. Now, it only works if I input the code, even though the code is also in the YAML file.
Is it true that this wasnât necessary before and now it is? Or could this be related to a setting that I can adjust to make it work without entering the alarm code?
Iâd find it much more convenient if entering the alarm code wasnât required for arming or disarming.
You can use outputs for that. Create a pulse output (1 second) in the Integra for arming
and 1 for disarming.
Now create 2 zones that are type 8 (follow output) and set them to arm/disarm
and set them to the correct output.
Now if you trigger the outputs the system will arm/disarm depending on which you choose.
You will need to provide a code thats allowed to switch in the yaml, but sound like
you already have that in there. Just make sure the user is allowed to switch in Integra.
Have you tried to implement the 7D function yet? I have done it in the past in domoticz but cant see where in the source the protocol handling various functions is in here.
Hi all! I have a simple question, can i get door sensors, pir sensors states in Home Assistant at all, when system is armed or disarmed, i need to use them in automations, thk
I have a Satel Versa IP alarm system installed and I want to connect it to Home Assistant with the Satel Integra plugin. However, I still need to buy a ETHM1-Plus card because itâs installed with a ETHM1 card.
But before I will go through with this, I want to verifiy if the Satel Versa IP system is compatible with this plugin. As I only see Satel Integra. I could not find this anywhere on the web.
