Back with some more space stuff… if you have ever been interested in tracking satellites or like to know when the ISS is going to pass over head I’ve built an integration for that.
This integration can be added as either:
- Satellite Tracker
- Location Tracker
The Satellite Tracker will add 5 sensors for the next 5 visible passes of the satellite over your specified location (defaults to ISS and your Home Assistant home location). It will also add a device tracker sensor which will allow you to see where the satellite is on your map at any given time.
The Location Tracker will add one sensor which gives you a count of how many satellites are visible over head and in the attributes will list the details of those satellites (name, location, etc).
You can add multiple integrations so you can have one (or more) of each.
Note: The API used for this integration (N2YO.com) has rate limits so if you add too many integrations and/or set your polling interval too low you will wind up banned.
Any feedback let me know!
