I have four lighting scenes setup to control my theater lights
Play Movie Lighting
Pause Movie Lighting
End Movie Lighting / All on
Theater Lighting Off
They all work properly when triggering them, unless I have the End movie / All on triggered first. Then the Play movie and Pause movie scenes will set the Bar lamps properly first, then turn them off.
If i trigger the same scene again it will set the two bar lamps properly. Or if I trigger the same scenes from Theater Lighting off or Pause movie to play movie, that works fine.
Any ideas?
Here is the scene.yaml section for these scenes
- id: '1714749394907'
name: Play Movie Lighting
entities:
light.micro_dimmer_2b_18_06:
supported_color_modes:
- brightness
color_mode:
brightness:
insteon_address: 2B.18.06
insteon_group: 1
friendly_name: Theater South Middle Overhead Light
supported_features: 0
state: 'off'
light.micro_dimmer_2c_a0_f5:
- brightness
color_mode:
brightness:
insteon_address: 2C.A0.F5
insteon_group: 1
friendly_name: Theater Sconce Lights
state: 'off'
light.switchlinc_dimmer_33_86_b7:
- brightness
color_mode:
brightness:
insteon_address: 33.86.B7
insteon_group: 1
friendly_name: Game Room Overhead Switch
state: 'off'
light.switchlinc_dimmer_33_7f_84:
- brightness
color_mode:
brightness:
insteon_address: 33.7F.84
insteon_group: 1
friendly_name: Theater Middle Front Overhead Light
state: 'off'
light.micro_dimmer_2b_17_f0:
- brightness
color_mode:
brightness:
insteon_address: 2B.17.F0
insteon_group: 1
friendly_name: Theater Middle Rear Overhead Light
state: 'off'
light.bar_sign:
- brightness
color_mode: brightness
brightness: 255
friendly_name: 'Bar Sign '
supported_features: 32
state: 'on'
light.bar_lamp_north:
min_color_temp_kelvin: 2000
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
color_mode: hs
brightness: 76
color_temp_kelvin:
color_temp:
hs_color:
- 354.331
- 100
rgb_color:
- 255
- 0
- 24
xy_color:
- 0.694
- 0.296
friendly_name: Bar Lamp North
state: 'on'
light.bar_lamp_south:
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
color_mode: hs
brightness: 76
color_temp_kelvin:
color_temp:
hs_color:
- 0
- 100
rgb_color:
- 255
- 0
- 0
xy_color:
- 0.701
- 0.299
friendly_name: Bar Lamp South
state: 'on'
icon: mdi:ceiling-light-multiple-outline
metadata:
entity_only: true
entity_only: true
entity_only: true
entity_only: true
entity_only: true
light.bar_sign:
entity_only: true
entity_only: true
entity_only: true
- id: '1714750019554'
name: Pause Movie Lights
entities:
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
color_mode: color_temp
brightness: 76
color_temp_kelvin: 3030
color_temp: 330
hs_color:
- 27.777
- 56.086
rgb_color:
- 255
- 178
- 111
xy_color:
- 0.494
- 0.383
state: 'on'
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
brightness: 76
color_temp_kelvin: 3021
color_temp: 331
hs_color:
- 27.791
- 56.328
rgb_color:
- 255
- 177
- 111
xy_color:
- 0.495
- 0.382
state: 'on'
- brightness
brightness: 153
insteon_group: 1
state: 'on'
- brightness
brightness: 153
insteon_group: 1
state: 'on'
- brightness
color_mode:
brightness:
insteon_group: 1
state: 'off'
- brightness
brightness: 153
insteon_group: 1
state: 'on'
- brightness
brightness: 153
insteon_group: 1
state: 'on'
light.bar_sign:
- brightness
brightness: 255
state: 'on'
metadata:
entity_only: true
entity_only: true
entity_only: true
entity_only: true
entity_only: true
light.bar_sign:
entity_only: true
- id: '1714750184955'
name: End Movie Lighting/ All On
entities:
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
brightness: 255
color_temp: 330
hs_color:
- 27.777
- 56.086
rgb_color:
- 255
- 178
- 111
xy_color:
- 0.494
- 0.383
state: 'on'
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
brightness: 255
color_temp: 331
hs_color:
- 27.791
- 56.328
rgb_color:
- 255
- 177
- 111
xy_color:
- 0.495
- 0.382
state: 'on'
- brightness
brightness: 255
insteon_group: 1
state: 'on'
- brightness
brightness: 255
insteon_group: 1
state: 'on'
- brightness
brightness: 255
insteon_group: 1
state: 'on'
- brightness
brightness: 255
insteon_group: 1
state: 'on'
- brightness
brightness: 255
insteon_group: 1
state: 'on'
light.bar_sign:
- brightness
brightness: 255
state: 'on'
metadata:
entity_only: true
entity_only: true
entity_only: true
entity_only: true
entity_only: true
light.bar_sign:
entity_only: true
- id: '1714756959783'
name: Theater Lighting Off
entities:
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
color_mode:
brightness:
color_temp_kelvin:
color_temp:
hs_color:
rgb_color:
xy_color:
state: 'off'
min_mireds: 153
max_mireds: 500
- color_temp
- hs
- xy
color_mode:
brightness:
color_temp_kelvin:
color_temp:
hs_color:
rgb_color:
xy_color:
state: 'off'
- brightness
color_mode:
brightness:
insteon_group: 1
state: 'off'
- brightness
color_mode:
brightness:
insteon_group: 1
state: 'off'
- brightness
color_mode:
brightness:
insteon_group: 1
state: 'off'
- brightness
color_mode:
brightness:
insteon_group: 1
state: 'off'
- brightness
color_mode:
brightness:
insteon_group: 1
state: 'off'
light.bar_sign:
- brightness
color_mode:
brightness:
state: 'off'
metadata:
entity_only: true
entity_only: true
entity_only: true
entity_only: true
entity_only: true
light.bar_sign:
entity_only: true
