Hi all,
i am not sure how big the need is but i think this would push the awareness of Homeassisant especially for our loved ones to the next level.
I am thinking about daily suggestions for the perfect scent. Based on weather, season, temperature and the list of owned parfumes it could help for much higher acceptance in our families
The idea is to get the parameters and the list from parfumo.de where you can create a list with your scents and their features.
Than based on information usually already known in HA it can suggest a matching scent for the days behaviour and needs.
Unfortunately i am not a developer,so the question is: Do you guys think this would be nice and does someone knows anyone to support?
Thofi (Germany)
Hi there Thomas,
Generally new integrations are rarely and seldom put into Home Assistant Core first, as you are asking for when putting in a Feature request here. The usual path is someone builds a custom integration that can be use with HA. It is then used and tweaked by the author, and that is then in a form that could be loaded into HA core.
I suggest looking for some existing code elsewhere, this could be a thing somewhere. You will also need to find someone to help you code and that would be a good place to look as well.
I wish you luck.
