You can add the legacy set_temperature action to the card, for the time being.
I want to add the multiple entity/multiple action support ASAP, to give the user the choice to change only the setpoint or also the HVAC mode.
Personally I don’t ever set the temperature if i don’t want my thermostat to heat, but everyone can have their own taste and i want to facilitate that.
For some reason, my climate schedule isn’t working. I have everything updated to most recent update. It’ snot turning on ever for my attic mini split:
E.g. one of the time segments is setup like this:
How do I begin to debug this?
Actually, you don’t. There’s an update you don’t have (i can see it from the pictures), but it won’t change anything regarding your problem.
A lot of users reported such problems.
The recipe for debugging is to monitor the history of the schedule + the climate entity.
The schedule should to go triggered
state once the timer is due. The thermostat should ofcourse change the temperature setpoint + the operation mode at this time.
In 9/10 cases the thermostat does change its setpoint but does not change the operation mode. So it will stay off. This is even the case for the generic thermostat.
The scheduler sets the hvac_mode
when calling the set_temperature
service, it is often ignored by integrations.
If this is the case, don’t bother to ask for a fix here. The problem is with your thermostat integration.
File a bug report or create a PR to solve it. For the generic thermostat this is already in progress.
As a workaround you could try to never switch modes (so only change temperature setpoint).
One question. can i use a temperature sensor value as a condition option inside a schema?
i add the sensor as included entities but i cannot see it
It was your own idea
And credits go to @Misiu for proposing to hide the markers until you select a timeslot.
I remember seeing this screenshot somewhere
@neliss your component is betting better and better. This topic is almost 1000 messages long, that only confirms how such component (functionality) is needed in Home Assistant. I hope that maybe someday this will become part of the core.
@neliss what do you think about this: ability to provide custom schedule entity id (or at least custom postfix - eg. switch.schedule_myfancyname).
I know you said you need the entity_id to be able to keep track of the schedules. But maybe you can instead use the unique_id attribute.
My use case:
Have two distinct scenes:
- regular
- have lights turn on in certain rooms at dusk;
- have scheduler set thermostats to a lower temp on certain rooms that are not used;
- guest mode
- have lights in guest room turned on at dusk too;
- disable the “regular schedule” and enable the “guest schedule” which uses a different timetable and temperature setpoints, to better suit the guests.
I can do this now too, but I need to know the exact schedule ID. And if I delete it or create it again, the schedule ID changes, so the previous automations will be broken.
Does this make any sense? If yes, I can create a feature request.
Maybe you haven’t noticed, but I have been holding off from making changes in the scheduler-component for a while.
There is quite a big change pending, which will take care of this, but also some other (much more important) restrictions.
Ideally, the entity ID is just a ‘slug’ of the friendly name, and you are free to set anything you want.
I don’t really want to put effort in anything else in the mean time (your proposal seems more of a quick-fix to me), it seems a distraction from what really needs to be done.
I haven’t found the time (or volunteer) to work on this yet…
Great! Indeed I’ve noticed the rather non-existing scheduler-component changes, but that just meant to me that it’s that stable and working good that it doesn’t need changes
Anyway, good to hear that it’ll be there at some point, so I’ll wait until it is. You know your plans best.
What kind of volunteer you need? If you need Python experienced developer, I’m not your man. Othewise I’d be glad to help as far as the time permits.
I’m using the Kumo Cloud Mitsubishi integration and can’t tell from the code why this would be happening as it’s passing through set_hvac and set_temp commands
If you look at the set_temperature function, you see that this component does not support changing the hvac_mode
together with the temperature setpoint.
It completely ignores this property.
Told you
Is there a way to backup the existing schedules, and later restore them if needed?
Should be included in the backup if you create a snapshot.
In this sense the integration is not really different than any other integration.
Ofcourse the schedules would be ‘corrupted’ if they contain actions for non-existing entities.
Hi, I integrated my Fibaro HC2 into HA and I use the scheduler for a few Popp Thermostat Radiator Valves. These valves only have 1 mode: auto. The scheduler works perfect, the valves open close at the times I set up. I only do not know yet how I can ‘manually override’ the auto mode. Today the heating was scheduled to go on in the afternoon but I wanted it to go on in the morning. I manually set it to a temperature, the walves got set to that temperature but a while later they were back to the scheduled temperature. In the logbook I also see: Livingroom changed to Auto. Does anyone knows how I can do this?
would it be possible to give the individual schedules a custom name? At the moment the name shown is that of the entity + the action. This gets confusing if you have different schedules depending on weekday/time etc for the same entity. It would be much clearer if I could name it for example:
“Weekend heating on”, “Weekend heating off”, “Weekday heating on morning” etc.
Cheers,
Manuel
Yes, you can give a schedule a name in the “Options” panel in the card.
And by setting the display_options, you can choose what you want to show.
I’ve seen this but if I set the name it doesn’t change what is getting displayed unless I do something wrong…
Edit your card in yaml :
primary_info and secondry_info
add {name}
type: 'custom:scheduler-card'
title: "Christmas lighting ⏰\U0001F384"
include:
- switch.rf_socket_01
- switch.rf_socket_02
- switch.rf_socket_03
discover_existing: false
display_options:
primary_info: '{name} - {entity} : {action}'
secondary_info:
- relative-time
icon: entity
Maybe a stupid question, i use your card/component to control the heating in my house.
But now i have this situation:
The heating goes to 20 degrees at 07:00 and at 23:00 it goes back to 18 degrees. But when i leave i use the button “eco” at my heating control system. When i use that the button it goes back to 18 degrees.
But when i coming home at for example 16:00 hour and i press the “eco” button again is dont goes back to 20 degrees. Can i fix that with your card?
