I am having issues with my Schlage FE599 lock.
This is the lock: https://www.amazon.com/Schlage-FE599NX-CAM-619-ACC/dp/B0083GJ17G/ref=sr_1_2?ie=UTF8&qid=1543448823&sr=8-2&keywords=schlage+fe599
There are several threads discussing issues with Schlage Locks. Schlage has a few different models and much of the information is years old and not applicable anymore or is not relevant to the FE599 lock. I am starting this thread to try and fix my own issues and hopefully it will be useful to others with the same lock.
I have the Aeotec Z-Stick Gen 5 as the ZWave controller. It is plugged into a Raspberry Pi running HASSIO. I have 38 ZWave devices that are powered (No batteries). They are all over the house, so I can’t imagine that I am having range issues.
The lock was added securely through the ZWave control panel in HASSIO.
I added group2 node associations as outlined here: Schlage Connect ZWave Locks
At one point I was able to remove the group 1 node association, and things were working, at least for a little while. Then the lock stopped working and would be “presumed dead”. Sometimes it would come back on it’s own, sometimes healing the network seemed to work. Now I am noticing that the group 1 node association is back and I am unable to remove it. I click “remove from group” as shown below, but it isn’t going away for some reason.
This is what I see in the Zwave log (full log at end of post). It shows the node 1 association being removed, then it shows it coming back. No idea what kind of voodoo is going on here.
2018-11-28 18:38:56.442 Info, Node055, Received Association report from node 55, group 1, containing 0 associations
That seems like a good sign.
2018-11-28 18:38:56.642 Info, Node055, Received Association report from node 55, group 2, containing 1 associations
Another good sign.
2018-11-28 18:38:56.925 Info, Node055, Received Association report from node 55, group 1, containing 1 associations
Not sure why the node 1 association suddenly comes back… So frustrating.
Furthermore, 2 new entities showed up that were not there before. (cover and switch)
Here is the complete log (for node 55 which is my lock that is not working right):
2018-11-28 18:38:54.808 Info, Node055, Association::Remove - Removing node 1 from group 1 of node 55
2018-11-28 18:38:54.809 Detail, Node055, Queuing (Send) AssociationCmd_Remove (Node=55): 0x01, 0x0b, 0x00, 0x13, 0x37, 0x04, 0x85, 0x04, 0x01, 0x01, 0x25, 0xfb, 0x8b
2018-11-28 18:38:54.810 Info, Node055, Get Associations for group 1 of node 55
2018-11-28 18:38:54.810 Detail, Node055, Queuing (Send) AssociationCmd_Get (Node=55): 0x01, 0x0a, 0x00, 0x13, 0x37, 0x03, 0x85, 0x02, 0x01, 0x25, 0xfc, 0x8d
2018-11-28 18:38:54.810 Info, Node055, Sending (Send) message (Callback ID=0xfb, Expected Reply=0x13) - AssociationCmd_Remove (Node=55): 0x01, 0x0b, 0x00, 0x13, 0x37, 0x04, 0x85, 0x04, 0x01, 0x01, 0x25, 0xfb, 0x8b
2018-11-28 18:38:54.818 Detail, Node055, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-28 18:38:54.819 Detail, Node055, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-28 18:38:56.309 Detail, Node055, Received: 0x01, 0x07, 0x00, 0x13, 0xfb, 0x00, 0x00, 0x95, 0x85
2018-11-28 18:38:56.309 Detail, Node055, ZW_SEND_DATA Request with callback ID 0xfb received (expected 0xfb)
2018-11-28 18:38:56.310 Info, Node055, Request RTT 1500 Average Request RTT 1689
2018-11-28 18:38:56.310 Detail, Expected callbackId was received
2018-11-28 18:38:56.310 Detail, Expected reply was received
2018-11-28 18:38:56.310 Detail, Message transaction complete
2018-11-28 18:38:56.310 Detail, Node055, Removing current message
2018-11-28 18:38:56.310 Info, Node055, Sending (Send) message (Callback ID=0xfc, Expected Reply=0x04) - AssociationCmd_Get (Node=55): 0x01, 0x0a, 0x00, 0x13, 0x37, 0x03, 0x85, 0x02, 0x01, 0x25, 0xfc, 0x8d
2018-11-28 18:38:56.319 Detail, Node055, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-28 18:38:56.319 Detail, Node055, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-28 18:38:56.389 Detail, Node055, Received: 0x01, 0x07, 0x00, 0x13, 0xfc, 0x00, 0x00, 0x07, 0x10
2018-11-28 18:38:56.389 Detail, Node055, ZW_SEND_DATA Request with callback ID 0xfc received (expected 0xfc)
2018-11-28 18:38:56.390 Info, Node055, Request RTT 79 Average Request RTT 884
2018-11-28 18:38:56.390 Detail, Expected callbackId was received
2018-11-28 18:38:56.442 Detail, Node055, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x37, 0x05, 0x85, 0x03, 0x01, 0x03, 0x00, 0x46
2018-11-28 18:38:56.442 Info, Node055, Response RTT 131 Average Response RTT 1153
2018-11-28 18:38:56.443 Info, Node055, Get Associations for group 2 of node 55
2018-11-28 18:38:56.443 Detail, Node055, Queuing (Send) AssociationCmd_Get (Node=55): 0x01, 0x0a, 0x00, 0x13, 0x37, 0x03, 0x85, 0x02, 0x02, 0x25, 0xfd, 0x8f
2018-11-28 18:38:56.443 Detail, Node055, Expected reply and command class was received
2018-11-28 18:38:56.443 Detail, Node055, Message transaction complete
2018-11-28 18:38:56.443 Detail, Node055, Removing current message
2018-11-28 18:38:56.443 Detail, Node055, Notification: Group
2018-11-28 18:38:56.445 Detail,
2018-11-28 18:38:56.445 Info, Node055, Sending (Send) message (Callback ID=0xfd, Expected Reply=0x04) - AssociationCmd_Get (Node=55): 0x01, 0x0a, 0x00, 0x13, 0x37, 0x03, 0x85, 0x02, 0x02, 0x25, 0xfd, 0x8f
2018-11-28 18:38:56.453 Detail, Node055, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-28 18:38:56.454 Detail, Node055, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-28 18:38:56.589 Detail, Node055, Received: 0x01, 0x07, 0x00, 0x13, 0xfd, 0x00, 0x00, 0x0e, 0x18
2018-11-28 18:38:56.589 Detail, Node055, ZW_SEND_DATA Request with callback ID 0xfd received (expected 0xfd)
2018-11-28 18:38:56.589 Info, Node055, Request RTT 143 Average Request RTT 513
2018-11-28 18:38:56.589 Detail, Expected callbackId was received
2018-11-28 18:38:56.642 Detail, Node055, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x37, 0x06, 0x85, 0x03, 0x02, 0x02, 0x00, 0x01, 0x41
2018-11-28 18:38:56.642 Info, Node055, Response RTT 197 Average Response RTT 675
2018-11-28 18:38:56.642 Info, Node055, The group contains:
2018-11-28 18:38:56.642 Info, Node055, Node 1
2018-11-28 18:38:56.643 Info, Node055, Querying associations for node 55 is complete.
2018-11-28 18:38:56.643 Info, Node055, Adding the controller to group 1 (Group 1) of node 55
2018-11-28 18:38:56.643 Info, Node055, Association::Set - Adding node 1 to group 1 of node 55
2018-11-28 18:38:56.643 Detail, Node055, Queuing (Send) AssociationCmd_Set (Node=55): 0x01, 0x0b, 0x00, 0x13, 0x37, 0x04, 0x85, 0x01, 0x01, 0x01, 0x25, 0xfe, 0x8b
2018-11-28 18:38:56.643 Info, Node055, Get Associations for group 1 of node 55
2018-11-28 18:38:56.643 Detail, Node055, Queuing (Send) AssociationCmd_Get (Node=55): 0x01, 0x0a, 0x00, 0x13, 0x37, 0x03, 0x85, 0x02, 0x01, 0x25, 0xff, 0x8e
2018-11-28 18:38:56.643 Detail, Node055, Expected reply and command class was received
2018-11-28 18:38:56.643 Detail, Node055, Message transaction complete
2018-11-28 18:38:56.644 Detail,
2018-11-28 18:38:56.644 Detail, Node055, Removing current message
2018-11-28 18:38:56.644 Info, Node055, Sending (Send) message (Callback ID=0xfe, Expected Reply=0x13) - AssociationCmd_Set (Node=55): 0x01, 0x0b, 0x00, 0x13, 0x37, 0x04, 0x85, 0x01, 0x01, 0x01, 0x25, 0xfe, 0x8b
2018-11-28 18:38:56.653 Detail, Node055, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-28 18:38:56.653 Detail, Node055, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-28 18:38:56.790 Detail, Node055, Received: 0x01, 0x07, 0x00, 0x13, 0xfe, 0x00, 0x00, 0x0f, 0x1a
2018-11-28 18:38:56.790 Detail, Node055, ZW_SEND_DATA Request with callback ID 0xfe received (expected 0xfe)
2018-11-28 18:38:56.790 Info, Node055, Request RTT 145 Average Request RTT 329
2018-11-28 18:38:56.790 Detail, Expected callbackId was received
2018-11-28 18:38:56.790 Detail, Expected reply was received
2018-11-28 18:38:56.790 Detail, Message transaction complete
2018-11-28 18:38:56.790 Detail, Node055, Removing current message
2018-11-28 18:38:56.791 Detail,
2018-11-28 18:38:56.791 Info, Node055, Sending (Send) message (Callback ID=0xff, Expected Reply=0x04) - AssociationCmd_Get (Node=55): 0x01, 0x0a, 0x00, 0x13, 0x37, 0x03, 0x85, 0x02, 0x01, 0x25, 0xff, 0x8e
2018-11-28 18:38:56.800 Detail, Node055, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-28 18:38:56.800 Detail, Node055, ZW_SEND_DATA delivered to Z-Wave stack
2018-11-28 18:38:56.871 Detail, Node055, Received: 0x01, 0x07, 0x00, 0x13, 0xff, 0x00, 0x00, 0x08, 0x1c
2018-11-28 18:38:56.872 Detail, Node055, ZW_SEND_DATA Request with callback ID 0xff received (expected 0xff)
2018-11-28 18:38:56.872 Info, Node055, Request RTT 80 Average Request RTT 204
2018-11-28 18:38:56.872 Detail, Expected callbackId was received
2018-11-28 18:38:56.924 Detail, Node055, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x37, 0x06, 0x85, 0x03, 0x01, 0x03, 0x00, 0x01, 0x43
2018-11-28 18:38:56.925 Detail,
2018-11-28 18:38:56.925 Info, Node055, Response RTT 133 Average Response RTT 404
2018-11-28 18:38:56.925 Info, Node055, The group contains:
2018-11-28 18:38:56.925 Info, Node055, Node 1
2018-11-28 18:38:56.925 Detail, Node055, Expected reply and command class was received
2018-11-28 18:38:56.925 Detail, Node055, Message transaction complete
2018-11-28 18:38:56.925 Detail, Node055, Removing current message
2018-11-28 18:38:56.926 Detail, Node055, Notification: Group
