I’m looking for a developer/coder who can do some work on homeassistant. I have been trying to a few weeks endlessly and cant get a scrape automation to work.
I need someone to write up a scrape automation, its fairly simple nothing too complex.
I require five sensors to scrape timings daily from website provided.
The sensors then need to trigger automation to my google speaker at those times to play a recording.
Post the problem here, including the code you’ve tried. I’m sure you’ll get the help you need. In fact, is this it?
I’ve posted a solution to extracting the times in that topic. Using those in an automation is then easy: create an automation with a time trigger using your new sensors, and output the message in the action.
