xbmcnut
(xbmcnut)
August 20, 2021, 5:10am
1
I’m trying to see if I can get power rates from my power company but these are only available after login. The class I’ve deciphered is .rate
which identifies the four values shown below (and yes, I know our power is very expensive!).
I tried using the following but I get an unknown value from the sensor. I don’t know how to test if I’m even logging in let alone whether any data is returned. Anyone got any tips? Ideally all I need to extract is one value <$0.20c and one value >$0.20c as the morning and evening rates are always the same. The damn energy platform has sent me down a deep dark rabbit hole!
- platform: scrape
resource: https://secure.powershop.co.nz/customers/<mycustomernumber>/balance
name: Scrape PowerShop Rates
authentication: basic
username: !secret powershop_user
password: !secret powershop_pw
# verify_ssl: false
select: ".rate"
headers:
User-Agent: Mozilla/5.0
P.S I’ve tried using digest
authentication too without success.
A login via a form is something else than HTTP basic/digest authenticating.
First find out if the values are present in the initial html and not being injected by Javascript (because then they cannot be scraped). Then try multiscrape form-submit.
xbmcnut
(xbmcnut)
August 21, 2021, 11:17am
3
Thanks @danieldotnl , but pretty much all of that went over my head. Might just have to program some averages.
joem
(Zsolt)
February 21, 2022, 1:46am
4
Did you manage to get you poweshop rates?
I tried using Scrape sensor improved - scraping multiple values , but didn’t manage to log in.
xbmcnut
(xbmcnut)
March 1, 2022, 3:10am
5
I gave up. Too hard for me which is a shame. Would be a really handy thing to know.
xbmcnut
(xbmcnut)
September 28, 2022, 10:53am
6
For those wanting to do this, I solved it here using the HACS version of the sensor which is a lot more capable.
Greminn
(Simon)
July 31, 2023, 2:58am
7
For those that are interested, I added to the excellent work by @xbmcnut adding the Powershop Special and Weekend rates:
multiscrape:
- name: Powershop Rates
resource: 'https://secure.powershop.co.nz/rates'
log_response: true
scan_interval: 43200 #every 12hrs
form_submit:
submit_once: true
resource: 'https://secure.powershop.co.nz'
select: ".content > form"
input:
email: !secret powershop_user
password: !secret powershop_pass
- unique_id: powershop_offpeak
name: Powershop Off Peak
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(1) > td.base-rates.current > span.rate.gst_inclusive"
unit_of_measurement: "NZD/kWh"
value_template: '{{ (value | int) / 100 | float | round(3)}}'
device_class: monetary
- unique_id: powershop_peak
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(2) > td.base-rates.current > span.rate.gst_inclusive"
- unique_id: powershop_weekend
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(3) > td.base-rates.current > span.rate.gst_inclusive"
- unique_id: powershop_offpeak_special
name: Powershop Off Peak Special
select: "#main_container > div > div.row > div.rates-table-container.special-rates-table > table > tbody > tr:nth-child(1) > td.base-rates.current > span.rate.gst_inclusive"
- unique_id: powershop_peak_special
name: Powershop Peak Special
select: "#main_container > div > div.row > div.rates-table-container.special-rates-table > table > tbody > tr:nth-child(2) > td.base-rates.current > span.rate.gst_inclusive"
- unique_id: powershop_weekend_special
name: Powershop Weekend Special
select: "#main_container > div > div.row > div.rates-table-container.special-rates-table > table > tbody > tr:nth-child(3) > td.base-rates.current > span.rate.gst_inclusive"
- unique_id: powershop_daily_charge
name: Powershop Daily Charge
select: "#main_container > div > div.row > div.rates-table-container.base-rates-table > table > tbody > tr:nth-child(4) > td.base-rates.current > span.rate.gst_inclusive"
on_error:
log: warning
value: last
