Scraping website behind login
Hi Everyone,
I would like to scrape my power/hydro bill amount and bill due date from my local provider’s website. I would like to use Node-Red if possible. I can easily scrape a site that isn’t behind login using the www-request node however I haven’t found a way to scrape a site that requires you to log in first. As an alternative, I’ve installed the nbrowser node which looks like it will work however when I call the node, I see absolutely nothing (no errors, no results etc). There is an option from the node to show a browser window instance but I can’t seem to get it to work. Has anyone else had any success in running this node in node-red (from Frenck) on Hassos?
You should have a look at the headers to find how to log and make request.
Best tool for my point of view is to make try with postman and find what headers/bearer need to be add.
Thanks @tikismoke I’ll have a look at postman
@Schocker did you manage to get anywhere with this? - I’m facing exactly the same issue for my LPG tank data.
I thought I’d hit the jackpot when I stumbled on nbrowser but it doesn’t appear to work in the hassio node red addon by @frenck - I did a little bit of investigation and it seems to require xvfb in the container :frowning:
Personally, Node-Red isn’t the best idea for something like this. If you can code in Python (which is actually super easy to learn), you could use the BeautifuSoup (https://www.crummy.com/software/BeautifulSoup/bs4/doc/) library, which makes things like this really simple. If you’re a fan of nodejs, take a look at SuperAgent (https://visionmedia.github.io/superagent/).
There’s a good write up about how to attempt this in NodeRed though: https://discourse.nodered.org/t/is-there-any-way-to-automatically-authenticate-myself-in-a-site-with-a-node/12703/3
I look at it like this…
Pictures vs text - is like - node red vs python
For node red I don’t need te really learn syntax and programming. For python I need to, variables, syntax, declaration…
And I used to just don’t like reading back at school :joy: - is like - don’t like text :yum:
LOL fair enough. Programming isn’t everyone’s forte… I totally get that, BUT, with that said, sometimes things are just easier by writing a few lines of code. :wink: (Hence how we even have projects like NodeRed and HA).
Thanks, I wouldn’t have initally gone down the NR route but my when looking at the website I’m trying to scrape (https://my.flogas.co.uk) the site seems to use some kind of Ajax login form which is beyond me :laughing:
Once I’m past that I can simply scrape the data I need from the page, but the issue is logging in.
Unfortunately after checking with frenck it seems the NR add-on doesn’t (and won’t) contain xvfb so nbrowser is a no go…
@swifty Unfortunately I couldn’t get it to work so I created a python script and used Selenium to scrape the data I was after. It works pretty well. By going this route, you will have more options and control. Having said that, if nbrowser did work inside of Node-Red my use case would have been much easier to implement.
I’ve just had to go the same route but used node red to control a selenium docker container; https://flows.nodered.org/node/node-red-contrib-webdriverio
The flow then uses the usual Home Assistant nodes to create entities in HA for my LPG level.
Interesting… I’ll have to check out that node. Thanks for the link @swifty
