Screek Human Sensor 2A - LD2450 24Ghz mmWave Human Tracker Sensor
I thought it would be best to share our progress with the LD2450 here, as of right now, we’ve made about 500+ DIY sensors for the LD2450.
It took us two months from the release of this module, to testing and designing the enclosure.
We are happy that in the recent test firmware, after getting feedback and suggestions from users, we have initially added three area detection and one exclusion area detection.
I don’t think this is a new thing, but still, we would like to have it here as a post to facilitate the exchange and discussion of this LD2450 radar module.
We have organized the documentation and information we have gathered at: Human Sensor 2A - Screek Workshop
Human Sensor 2A Zone Function Demo - YouTube
After getting a lot of feedback from users, we embarked on a lot of improvements to the original firmware, and now, judging by the feedback from the recent test firmware V230810_2_Beta, it’s working pretty well in general with the zone feature.
  • But there is still some room for improvement:For example, support for multiplayer mode in the official ld2450 firmware, and the demo mode, which we’ve heard from the hilink developers will be available this month. At least the multiplayer mode is already in their internal testing.
  • The display in HomeAssistant still doesn’t take full advantage of the intuitive function of coordinates, and we are still looking forward to working with you all to refine a lovelace display that shows a room area with a few dots moving around, which would be a lot cooler than the primitive ID display that shows a simple occupied state.
  • Likewise, the current setup area requires manual number entry, which isn’t intuitive enough, and would definitely be nice to have in some sort of drawing-like interface. We’re currently told that the folks at hilink are also envisioning a zoning feature from their app, presumably like the LD2410, which seems like a nice addition.
  • To give you a better experience of this groundbreaking cost-effective body tracking radar module, we’ve prepared more Sensor 2A to share with you, and in the meantime, we’re offering a 10% discount on all SCREEK sensors for the next 24 hours.
I’m looking forward to trying this out!
I have purchased 2, I have installed one in the kitchen to turn on the kitchen main light (zone 1), the sink light (zone 2), and the fires light (zone 3). Planning the second for the far side of the living room.
Seems to work reasonably well, need to optimize the timings and maybe put the sensor elsewhere (European kitchen, no central island big enough to dissect a dolphin) and need to light the main light better according to existing light level.
What is interesting is that the kitchen is open, and I could use a fourth zone to control the light in the living room just outside the kitchen area.
Maybe a template sensor to use the targets distance instead would be the solution, to check.
Thanks to this sensor I am finally starting to explore the real meaning of smart, autonomous home. Having HA control lights via tablet and buttons is fine but not really the idea of smart home and energy saving (i.e more comfort and sell wasted energy when the kids forget the lights on…).
After having countless issues with Aqara motion sensors in Smartthings I made the switch to Home assistant with a used thin client. I went on to purchase (5) esp32-c3s and (5) LD2450s thinking they were already supported by ESPHome. I have tried loading the 2A firmware onto my esp32-c3s since I saw images of the c3 being used in what I guess were earlier models of the 2A via ESPHome. However, I am not able to get the config to install on the c3s. Is there a barebones version of the config available for just the mmwave sensor without the light sensor? Or perhaps can someone point out what lines to remove to accomplish this? Is it possible to simply add the config to a esp32-c3 that is already connected to Home Assistant and local wifi without needing to install the screek firmware and connect to the AP created by the esp32? If this is not the correct place to ask could someone point me in the right direction? Any assistance is greatly appreciated.
Which pins on the ESP are you using for TX/RX?
I am at work away from the device but if I recall correctly it is RX GPIO05(I2C_SCL) and TX GPIO04(I2C_SDA).
You’re using these?
https://www.aliexpress.com/item/3256805648573146.html?spm=a2g0o.order_list.order_list_main.11.6b501802TqPBt4
Not actually able to pull up that link(work firewall maybe)… but I purchased the classic version of these ESP32 C3 Development Board ESP32 C3 CORE Board Onboard 2.4G Antenna 32Pin IDF WiFi + Bluetooth CH343P for Arduino Microprython - AliExpress
Looks like they forgot to update the board in the YAML posted in the Github. It’s set to the the c3 mini.
I’m guessing you’d need to update the board:
esp32-c3-devkitm-1
I previously noticed that and updated the yaml with esp32-c3-devkitm-1 but the install failed. However, in hindsight I tried to install wirelessly instead of directly connected to thin client running HA and also may have tinkered with other settings as well. So, when I get home I will grab the yaml from the github again and only change the board to be sure.
This config is working for me:
substitutions:
  # Set the device name
  # Set the friendly name
  friendly_name: 2A Sensor Test
  # Provide the wifi SSID
  wifi: !secret wifi_ssid
  #Provide the wifi password
  wifi_pass: !secret wifi_password
  #Provide an OTA password:
  ota_pass: "trustbutverifywalkingwithabigstick"
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
# This is a custom firmware for Human Presence Sensor 2A
# https://docs.screek.io/2a
esphome:
  friendly_name: $friendly_name
  name_add_mac_suffix: false
  on_boot:
    - priority: 100
      then:
        lambda: |-
          id(cpu_speed) = ESP.getCpuFreqMHz();
    - priority: -200
      then:
        lambda: |-
          id(zone1_target_exsits).publish_state(false);
          id(zone2_target_exsits).publish_state(false);
          id(zone3_target_exsits).publish_state(false);
          id(zone_ex1_target_exsits).publish_state(false);
  platformio_options:
    board_build.flash_mode: dio
preferences:
    flash_write_interval: 5s
external_components:
  - source:
      type: git
      url: https://github.com/screekworkshop/custom_components_support_for_screek_2a
      ref: main
    components: [esp32, uart]
globals:
  - id: cpu_speed
    type: int
    restore_value: no
    initial_value: '0'
  - id: last_update_ld2450
    type: unsigned long
    restore_value: no
    initial_value: '0'
  - id: init_zone_publish
    type: bool
    restore_value: no
    initial_value: "false"
  - id: last_illuminance
    type: float
    restore_value: no
    initial_value: "-1"
improv_serial:
logger:
debug:
  update_interval: 30s
api:
ota:
  password: $ota_pass
wifi:
  ssid: $wifi
  password: $wifi_pass
  power_save_mode: LIGHT
  ap:
captive_portal:
web_server:
  port: 80
text_sensor:
  - platform: debug
    reset_reason:
      name: "ESP Reset Reason"
      icon: mdi:anchor
      disabled_by_default: True
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
      entity_category: "diagnostic"
      icon: mdi:ip-network
    mac_address:
    icon: mdi:information-outline
    entity_category: config
    lambda: |-
      return {"Configure below" };
    update_interval: 1000s
    lambda: |-
    lambda: |-
    lambda: |-
      return {"Zone Exclusion 1" };
number:
    name: "Any Presence Timeout"
    min_value: 0
    max_value: 600
    mode: box
    device_class: duration
    unit_of_measurement: s
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 600
    mode: box
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 600
    mode: box
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
    min_value: 0
    max_value: 600
    mode: box
    icon: mdi:timer-off
    step: 1
    optimistic: True
    initial_value: 0
    restore_value: True
  # Zone 1
    min_value: -4000
    max_value: 4000
    mode: box
    device_class: distance
    unit_of_measurement: mm
    icon: mdi:arrow-left-bold
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zone1_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    icon: mdi:arrow-right-bold
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    icon: mdi:arrow-up-bold
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    icon: mdi:arrow-down-bold
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
  # Zone 2
    min_value: -4000
    max_value: 4000
    mode: box
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zone2_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
  # Zone 3
    min_value: -4000
    max_value: 4000
    mode: box
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zone3_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
  # Zout1
    min_value: -4000
    max_value: 4000
    mode: box
    step: 10
    optimistic: True
    initial_value: 0
    restore_value: True
    on_value:
      then:
        - script.execute: check_zout1_vaild
    mode: box
    min_value: -4000
    max_value: 4000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    step: 10
    initial_value: 0
    optimistic: True
    restore_value: True
    on_value:
      then:
    mode: box
    min_value: 0
    max_value: 6000
    initial_value: 0
    step: 10
    optimistic: True
    restore_value: True
    on_value:
      then:
binary_sensor:
  - platform: status
    name: "Any Presence"
    device_class: occupancy
    filters:
      - delayed_off: !lambda |-
          return id(any_presence_timeout).state * 1000.0;
    name: "Zone1 Presence"
    filters:
          return id(zone1_x_timeout).state * 1000.0;
    name: "Zone2 Presence"
    filters:
          return id(zone2_x_timeout).state * 1000.0;
    name: "Zone3 Presence"
    filters:
          return id(zone3_x_timeout).state * 1000.0;
    name: "Zout1 Presence"
    icon: mdi:account-multiple-remove
i2c:
  sda: GPIO7
  scl: GPIO11
  scan: true
script:
  - id: check_zone1_vaild
    then:
      - lambda: |-
          if (id(zone1_x_begin).state > id(zone1_x_end).state){
            id(tips_zone1_conf).publish_state("Err: X-Begin > X-End");
            return;
          if (id(zone1_y_begin).state > id(zone1_y_end).state){
            id(tips_zone1_conf).publish_state("Err: Y-Begin > Y-End");
            return;
          if (id(zone1_x_begin).state == 0, id(zone1_x_end).state == 0, id(zone1_y_begin).state == 0, id(zone1_y_end).state == 0){
            id(tips_zone1_conf).publish_state("Configure below");
            return;
          int x_size = id(zone1_x_end).state - id(zone1_x_begin).state;
          int y_size = id(zone1_y_end).state - id(zone1_y_begin).state;
          char combined[80];
          sprintf(combined, "Curr Size: %d x %d", x_size, y_size);
          id(tips_zone1_conf).publish_state(combined);
  - id: check_zone2_vaild
    then:
      - lambda: |-
          if (id(zone2_x_begin).state > id(zone2_x_end).state){
            id(tips_zone2_conf).publish_state("Err: X-Begin > X-End");
            return;
          if (id(zone2_y_begin).state > id(zone2_y_end).state){
            id(tips_zone2_conf).publish_state("Err: Y-Begin > Y-End");
            return;
          if (id(zone2_x_begin).state == 0, id(zone2_x_end).state == 0, id(zone2_y_begin).state == 0, id(zone2_y_end).state == 0){
            id(tips_zone2_conf).publish_state("Configure below");
            return;
          int x_size = id(zone2_x_end).state - id(zone2_x_begin).state;
          int y_size = id(zone2_y_end).state - id(zone2_y_begin).state;
          char combined[80];
          id(tips_zone2_conf).publish_state(combined);
  - id: check_zone3_vaild
    then:
      - lambda: |-
          if (id(zone3_x_begin).state > id(zone3_x_end).state){
            id(tips_zone3_conf).publish_state("Err: X-Begin > X-End");
            return;
          if (id(zone3_y_begin).state > id(zone3_y_end).state){
            id(tips_zone3_conf).publish_state("Err: Y-Begin > Y-End");
            return;
          if (id(zone3_x_begin).state == 0, id(zone3_x_end).state == 0, id(zone3_y_begin).state == 0, id(zone3_y_end).state == 0){
            id(tips_zone3_conf).publish_state("Configure below");
            return;
          int x_size = id(zone3_x_end).state - id(zone3_x_begin).state;
          int y_size = id(zone3_y_end).state - id(zone3_y_begin).state;
          char combined[80];
          id(tips_zone3_conf).publish_state(combined);
  - id: check_zout1_vaild
    then:
      - lambda: |-
          if (id(zone_ex1_x_begin).state > id(zone_ex1_x_end).state){
            id(tips_zone_ex1_conf).publish_state("Err: X-Begin > X-End");
            return;
          if (id(zone_ex1_y_begin).state > id(zone_ex1_y_end).state){
            id(tips_zone_ex1_conf).publish_state("Err: Y-Begin > Y-End");
            return;
          id(tips_zone_ex1_conf).publish_state("Zone Exclusion 1");
    name: "ESP CPU Speed"
    accuracy_decimals: 0
    icon: mdi:cpu-32-bit
    unit_of_measurement: Mhz
    lambda: |-
      return (id(cpu_speed));
    update_interval: 600s
    name: ESP Temperature
    lambda: return temperatureRead();
    unit_of_measurement: °C
    device_class: TEMPERATURE
    update_interval: 45s
  - platform: uptime
    update_interval: 60s
  - platform: wifi_signal
    icon: mdi:memory
    name: ESP Free Memory
    lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL) / 1024;
    unit_of_measurement: 'kB'
    state_class: measurement
  - platform: bh1750
    accuracy_decimals: 1
    update_interval: 1s
    filters:
      - lambda: !lambda |-
          if (id(last_illuminance) == x){
            return {};
          if (id(bh1750_fast_update).state){
            id(last_illuminance) = x;
            // ESP_LOGD("custom", "Fast Update BH1850");
            return x;
          if (abs(id(last_illuminance) - x) > 1){
              return x;
          return {};
  # 高级雷达数据
    name: "All Target Counts"
    icon: "mdi:counter"
    unit_of_measurement: "targets"
    name: "Zone1 Target Counts"
    icon: "mdi:counter"
    name: "Zone2 Target Counts"
    icon: "mdi:counter"
    name: "Zone3 Target Counts"
    icon: "mdi:counter"
    name: "Zout1 Target Counts"
    icon: mdi:account-multiple-minus-outline
  # Target 1
    unit_of_measurement: 'mm'
    accuracy_decimals: 2
    unit_of_measurement: 'm/s'
    device_class: speed
    name: "Target1 Resolution"
  # Target 2
    device_class: speed
    name: "Target2 Resolution"
  # Target 3
    device_class: speed
    name: "Target3 Resolution"
light:
  - platform: status_led
    pin: GPIO13
    internal: True
    restore_mode: ALWAYS_OFF
  - platform: binary
    name: "Red Info Light"
    output: board_info_ed
    entity_category: "config"
time:
  - platform: sntp
output:
  - platform: gpio
    pin: GPIO12
switch:
  - platform: factory_reset
    icon: mdi:heart-broken
    optimistic: True
    icon: mdi:account-cancel
    restore_mode: RESTORE_DEFAULT_OFF
    name: Illuminance Fast-Update
    optimistic: True
    entity_category: diagnostic
    icon: mdi:run-fast
button:
  - platform: restart
    icon: mdi:power-cycle
uart:
  tx_pin:
    number: GPIO5
    mode:
      input: true
      pullup: true
  rx_pin:
    number: GPIO4
    mode:
      input: true
      pullup: true
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
  data_bits: 8
  debug:
    direction: BOTH
    dummy_receiver: True
    after:
     delimiter: [0X55, 0XCC]
    sequence:
      - lambda: |-
          if ((millis() - id(last_update_ld2450)) <= 500) {
            return;
          id(last_update_ld2450) = millis();
          // p1
          int16_t p1_x = (uint16_t((bytes[5] << 8) | bytes[4] ));
          if ((bytes[5] & 0x80) >> 7){
            p1_x -= pow(2, 15);
          }else{
            p1_x = 0 - p1_x;
          int16_t p1_y = (uint16_t((bytes[7] << 8) | bytes[6] ));
          if ((bytes[7] & 0x80) >> 7){
            p1_y -= pow(2, 15);
          }else{
            p1_y = 0 - p1_y;
          int p1_speed = (bytes[9] << 8 | bytes[8] );
          if ((bytes[9] & 0x80) >> 7){
            p1_speed -= pow(2, 15);
          }else{
            p1_speed = 0 - p1_speed;
          int16_t p1_distance_resolution = (uint16_t((bytes[11] << 8) | bytes[10] ));
          // p2
          int16_t p2_x = (uint16_t((bytes[13] << 8) | bytes[12] ));
          if ((bytes[13] & 0x80) >> 7){
            p2_x -=  pow(2, 15);
          }else{
            p2_x = 0 - p2_x;
          int16_t p2_y = (uint16_t((bytes[15] << 8) | bytes[14] ));
          if ((bytes[15] & 0x80) >> 7){
            p2_y -= pow(2, 15);
          }else{
            p2_y = 0 - p2_y;
          int p2_speed = (bytes[17] << 8 | bytes[16] );
          if ((bytes[17] & 0x80) >> 7){
            p2_speed -= pow(2, 15);
          }else{
            p2_speed = 0 - p2_speed;
          int16_t p2_distance_resolution = (uint16_t((bytes[19] << 8) | bytes[18] ));
          // p3
          int16_t p3_x = (uint16_t((bytes[21] << 8) | bytes[20] ));
          if ((bytes[21] & 0x80) >> 7){
            p3_x -=  pow(2, 15);
          }else{
            p3_x = 0 - p3_x;
          int16_t p3_y = (uint16_t((bytes[23] << 8) | bytes[22] ));
          if ((bytes[23] & 0x80) >> 7){
            p3_y -= pow(2, 15);
          }else{
            p3_y = 0 - p3_y;
          int p3_speed = (bytes[25] << 8 | bytes[24] );
          if ((bytes[25] & 0x80) >> 7){
            p3_speed -= pow(2, 15);
          }else{
            p3_speed = 0 - p3_speed;
          int16_t p3_distance_resolution = (uint16_t((bytes[27] << 8) | bytes[26] ));
          bool p1_vaild = (p1_x != 0 || p1_y > 0);
          bool p2_vaild = (p2_x != 0 || p2_y > 0);
          bool p3_vaild = (p3_x != 0 || p3_y > 0);
          // zone exlude 1
          int16_t target_count_in_zone_ex1 = 0;
          int16_t zone_ex1_x_min = id(zone_ex1_x_begin).state;
          int16_t zone_ex1_x_max = id(zone_ex1_x_end).state;
          int16_t zone_ex1_y_min = id(zone_ex1_y_begin).state;
          int16_t zone_ex1_y_max = id(zone_ex1_y_end).state;
          bool p1_zone_ex_enter = false;
          bool p2_zone_ex_enter = false;
          bool p3_zone_ex_enter = false;
          if (id(zone_ex1_enable).state){
            if (p1_vaild){
              if (p1_x >= zone_ex1_x_min && p1_x <= zone_ex1_x_max && p1_y >= zone_ex1_y_min && p1_y <= zone_ex1_y_max){
                  p1_zone_ex_enter = true;
                  target_count_in_zone_ex1 ++;
            if (p2_vaild){
              if (p2_x >= zone_ex1_x_min && p2_x <= zone_ex1_x_max && p2_y >= zone_ex1_y_min && p2_y <= zone_ex1_y_max){
                  p2_zone_ex_enter = true;
            if (p3_vaild){
              if (p3_x >= zone_ex1_x_min && p3_x <= zone_ex1_x_max && p3_y >= zone_ex1_y_min && p3_y <= zone_ex1_y_max){
                  p3_zone_ex_enter = true;
          bool has_target_in_zone_ex1 = (target_count_in_zone_ex1 > 0);
          int16_t all_target_counts = 0;
          if (p1_vaild && !p1_zone_ex_enter){
            all_target_counts ++;
          if (p2_vaild && !p2_zone_ex_enter){
          if (p3_vaild && !p3_zone_ex_enter){
          bool has_target_in_zone_all = (all_target_counts > 0);
          // zone 1 check
          int16_t target_count_in_zone1 = 0;
          int16_t zone1_x_min = id(zone1_x_begin).state;
          int16_t zone1_x_max = id(zone1_x_end).state;
          int16_t zone1_y_min = id(zone1_y_begin).state;
          int16_t zone1_y_max = id(zone1_y_end).state;
            if (p1_x >= zone1_x_min && p1_x <= zone1_x_max && p1_y >= zone1_y_min && p1_y <= zone1_y_max){
                target_count_in_zone1 ++;
            if (p2_x >= zone1_x_min && p2_x <= zone1_x_max && p2_y >= zone1_y_min && p2_y <= zone1_y_max){
            if (p3_x >= zone1_x_min && p3_x <= zone1_x_max && p3_y >= zone1_y_min && p3_y <= zone1_y_max){
          bool has_target_in_zone1 = (target_count_in_zone1 > 0);
          // zone 2 check
          int16_t target_count_in_zone2 = 0;
          int16_t zone2_x_min = id(zone2_x_begin).state;
          int16_t zone2_x_max = id(zone2_x_end).state;
          int16_t zone2_y_min = id(zone2_y_begin).state;
          int16_t zone2_y_max = id(zone2_y_end).state;
            if (p1_x >= zone2_x_min && p1_x <= zone2_x_max && p1_y >= zone2_y_min && p1_y <= zone2_y_max){
                target_count_in_zone2 ++;
            if (p2_x >= zone2_x_min && p2_x <= zone2_x_max && p2_y >= zone2_y_min && p2_y <= zone2_y_max){
            if (p3_x >= zone2_x_min && p3_x <= zone2_x_max && p3_y >= zone2_y_min && p3_y <= zone2_y_max){
          bool has_target_in_zone2 = (target_count_in_zone2 > 0);
          // zone 3 check
          int16_t target_count_in_zone3 = 0;
          int16_t zone3_x_min = id(zone3_x_begin).state;
          int16_t zone3_x_max = id(zone3_x_end).state;
          int16_t zone3_y_min = id(zone3_y_begin).state;
          int16_t zone3_y_max = id(zone3_y_end).state;
            if (p1_x >= zone3_x_min && p1_x <= zone3_x_max && p1_y >= zone3_y_min && p1_y <= zone3_y_max){
                target_count_in_zone3 ++;
            if (p2_x >= zone3_x_min && p2_x <= zone3_x_max && p2_y >= zone3_y_min && p2_y <= zone3_y_max){
            if (p3_x >= zone3_x_min && p3_x <= zone3_x_max && p3_y >= zone3_y_min && p3_y <= zone3_y_max){
          bool has_target_in_zone3 = (target_count_in_zone3 > 0);
          // public all info
          if (id(target1_x).state != p1_x){
            id(target1_x).publish_state(p1_x);
          if (id(target1_y).state != p1_y){
            id(target1_y).publish_state(p1_y);
          float p1_m_speed = float(p1_speed) / 100.0;
          if (id(target1_speed).state != p1_m_speed){
            id(target1_speed).publish_state(p1_m_speed);
          if (id(target1_resolution).state != p1_distance_resolution){
            id(target1_resolution).publish_state(p1_distance_resolution);
          if (id(target2_x).state != p2_x){
            id(target2_x).publish_state(p2_x);
          if (id(target2_y).state != p2_y){
            id(target2_y).publish_state(p2_y);
          if (id(target2_speed).state != p2_speed){
            id(target2_speed).publish_state(p2_speed);
          if (id(target2_resolution).state != p2_distance_resolution){
            id(target2_resolution).publish_state(p2_distance_resolution);
          if (id(target3_x).state != p3_x){
            id(target3_x).publish_state(p3_x);
          if (id(target3_y).state != p3_y){
            id(target3_y).publish_state(p3_y);
          if (id(target3_speed).state != p3_speed){
            id(target3_speed).publish_state(p3_speed);
          if (id(target3_resolution).state != p3_distance_resolution){
            id(target3_resolution).publish_state(p3_distance_resolution);
          // publish target info
          if (id(all_target_count).state != all_target_counts){
            id(all_target_count).publish_state(all_target_counts);
            id(any_target_exsits).publish_state(has_target_in_zone_all);
          if (id(zone1_target_count).state != target_count_in_zone1){
            id(zone1_target_count).publish_state(target_count_in_zone1);
            id(zone1_target_exsits).publish_state(has_target_in_zone1);
          if (id(zone2_target_count).state != target_count_in_zone2){
            id(zone2_target_count).publish_state(target_count_in_zone2);
            id(zone2_target_exsits).publish_state(has_target_in_zone2);
          if (id(zone3_target_count).state != target_count_in_zone3){
            id(zone3_target_count).publish_state(target_count_in_zone3);
            id(zone3_target_exsits).publish_state(has_target_in_zone3);
          // zout
          if (id(zone_ex1_target_count).state != target_count_in_zone_ex1){
            id(zone_ex1_target_count).publish_state(target_count_in_zone_ex1);
            id(zone_ex1_target_exsits).publish_state(has_target_in_zone_ex1);
          if (!id(init_zone_publish)){
            id(init_zone_publish) = true;
The config you provided installs but in logs I am seeing NO OTA attempt made, restarting. Eventually it show, “There have been 10 suspected unsuccessful boot attempts.” “Boot loop detected. Proceeding to safe mode.” The esp32-c3 connects to my wifi and shows connected in ESPHome addon. However, there is no notification for new device detected and in Integration it doesn’t show up under Discovered. Should I be installing factory-human-sensor-2a-V230908_1_stable.bin or maybe the OTA firmware?
I’m not sure then. I just tested again using the YAML I posted above.
  1. Created device in ESPhome.
  2. Edited config and did a direct paste of the YAML above.
  3. Selected install, manual, modern format.
  4. Use ESPHome Web to flash.
The board reset, connected to wifi, and showed up in device discovery. Added it and can see all the sensor data.
is this the right mmwave to use?
https://it.aliexpress.com/item/1005006121923099.html?spm=a2g0o.productlist.main.11.23be6594uNe8QF&algo_pvid=1a51dce4-429d-4695-846c-8cba75946d7e&aem_p4p_detail=2023111303475112826149144584340003340071&algo_exp_id=1a51dce4-429d-4695-846c-8cba75946d7e-5&pdp_npi=4%40dis!EUR!1.18!1.12!!!1.23!!%40211b81a316998760717705740e93dd!12000035851121209!sea!IT!2692602029!&curPageLogUid=fy2lazD9Oofp&search_p4p_id=2023111303475112826149144584340003340071_6
Any got a neat diy 3d print case file for this?
i don’t understand why i’m on zone 3. but zone 3 not show detect
Zones? From one sensor? Where is this documented?
here:
and here:
  • Zone Support: Based on the current firmware, three recognized zones (Zone1, Zone2, Zone3) are supported, as well as one excluded zone (Zout1), which can be switched on and off individually. Enabling the exclusion zone will disregard excluded targets in all recognition judgments.
  • Target Coordinate detection: Compared to LD2410, now you can support X coordinate reading! And Y coordinates are more accurate! They are accurate up to 36cm.
One reason why the LD2450 with this Firmware is such an Awesome sensor!
Especially now with Multiple Target support.
Hi, we haven’t received any such bug feedback yet, so our initial guess is that there may be some setup hurdles.
If possible, please provide a recording or screenshot that shows all the relevant settings and we can make an initial attempt to understand what’s happening.
A general and unexpected understanding might be that x-begin and x-end are reversed, i.e. in the case of a negative number, it might be that the former has a bigger number.
For example, think - 200 > -100, which would cause the judgment logic to fail.
This is a feature of the ld2450, a new sensor that was discussed more extensively in our other thread and is now supported by more open source libraries.
It is a ld2410 similar to the 24g radar sensor but with support for area characterization.
