Script not working and non helpful error message
Hey all,
I tried to write an automation to set my offset for the termostat automaticaly.
However I get an error when saving “Message malformed: not a valid value for dictionary value @ data[‘type’]”
Here is my Yaml (based on a automation from the visual editor with added pices from here: Tado set offset using separate temperature sensor)
mode: single
variables:
  thermos_temp: "{{ state_attr(climate.tze200_6rdj8dzm_ts0601_thermostat_2, 'current_temperature') | float }}"
  current_offset: "{{ states(number.tze200_6rdj8dzm_ts0601_number_temperature_calibration_2) | float }}"
  actual_temp: "{{ states(sensor.lumi_lumi_sens_temperature) | float }}"
  calculated_offset: "{{ ( ( actual_temp - thermos_temp ) + current_offset ) | round }}"
  - platform: device
    device_id: 7edea5c1c3aebdee5dc137a4c85c7d0f
    domain: climate
    entity_id: 712e8ec167f3b4ac9dc8443196cc86cd
    type: current_temperature_changed
condition: []
  - device_id: 7edea5c1c3aebdee5dc137a4c85c7d0f
    domain: number
    entity_id: 0b380c53d0687df2b882e8042a2b83a4
    type: set_value
    value: "{{ calculated_offset }}"
Any hint what’s wrong here?
Not sure if this is the problem or not, but you’re not specific what to round to.
Try:
calculated_offset: "{{ ( ( actual_temp - thermos_temp ) + current_offset ) | round(0) }}"
…if you want a whole number.
Thanks for the repsonse, but I get the same error even when specified.
Have you tried putting that calculation into developer tools / template ?
You can’t add templates to a Device Action so change it to a Service Call.
  - service: number.set_value
For future reference:
Why and how to avoid device_ids in automations and scripts - Community Guides - Home Assistant Community (home-assistant.io)
