I’ve was in the process of trying to recover my HA from a corrupted sd card more info from a previous post here:
I’m no longer trying to recover my old HA and now have a SSD with an old snapshot which has about a third of my devices. Some of my devices are working, some are unavailable, and the rest have to be added to the system again.
Moreover, now I can’t update from 0.110.3 to 0.117.4.
I get this error:
20-11-05 06:17:06 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:0.110.3 to homeassistant/raspberrypi4-64-homeassistant:0.117.4
20-11-05 06:17:06 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 0.117.4.
20-11-05 06:17:23 ERROR (SyncWorker_1) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-64-homeassistant:0.117.4 → 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi4-64-homeassistant:0.117.4: No such image: homeassistant/raspberrypi4-64-homeassistant:0.117.4”).
20-11-05 06:17:23 INFO (SyncWorker_1) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 204.5 GiB
20-11-05 06:17:23 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
I know this means there is not enough space however there is 204 gbs available?
I update through the Lovelace UI and it errors out then loses connection. I have to do a hard reboot then start with ha start with keyboard hooked up to RPi4 to get things back to what’s stated above.
