In my case is working adding to manifest.json under domain:
“version”: “1.0”,
“version”: “1.0”,
Thanks Javi!
Hello, I just updated my core to the latest core-2021.6.2 version in since then my securitas integration don’t start anymore, do you have any ides where it could come from?
Component error: securitas_direct - Integration ‘securitas_direct’ not found.
Did you check the logs? Check this discussion about a version string that must be included in the manifest file for a custom component to be allowed to run:
Can you copy the manifest as you have it?
I have tried to put the version in different ways but it always gives me an error.
"domain": "securitas_direct",
"version": "1.0",
"name": "Securitas Direct",
"documentation": "https://www.home-assistant.io/integrations/securitas_direct",
"requirements": [
"pysecuritas==0.1.4"
"codeowners": [
"@segalion",
"@Cebeerre"
I am now getting these errors. Any ideas what the problem is?? I am using the latest mobile app.
Do you have access to any of the sensors and/or cameras or just the alarm?
This just gives you access to the Securitas API and therefore, just allows to interact with the Alarm Panel in the same way yo do with the mobile app.
Just the alarm. You can arm any of the available modes (ie: away/night) or disarm it only.
Hello, did you get any solution to this?
I am having the same issue.
Thank you
Hi
Suddenly the securitas_direct does no longer connect to the alarm anyone else having the same issue?
Regards,
M
I am using the same integration in Spain. Just checked it and it is working as usual. No issues so far.
Ok that is strange I suddenly get a “configuration error” but changed nothing and it was working until yesterday afternoon
Was working… Update to 2021.9.1… This integration cannot be loaded. Nothing in logs even if logs activated in configuration.yaml? Reinstalled, cleared pycache… No success.
Any idea ?
Hi, same situation for me. Nothing in the logs and have an “invalid config” error as well.
Sorry no idea
Still no issues here.
Have you guys added the “version” line into the manifest.json file included in the custom_component/securitas_direct folder as advised in the issue #31?
This is exactly what I have in such a file:
"version": "1.0",
"requirements": [
"codeowners": [
"@segalion",
"@Cebeerre"
Yes I added the line months ago and it is still there,
The issue seems to be with something else but log shows nothing.
Cheers
M
I can share my custom_component/securitas_direct folder if you thing it will help, just in case there is some sort of little difference in the code for whatever reason. However, I don’t remember to have changed anything on there. Do find below my config.yaml working content, as I remember that I had some problems in the past due to forgetting the country and/or lang key. Without them, I think the integration used to work sometimes, and sometimes didn’t.
securitas_direct:
username: !secret securitas_user
password: !secret securitas_pass
installation: !secret securitas_installation
code: !secret securitas_code
country: ES
lang: es
Hi Sesar,
Thanks. That is how my config yaml file is set up. It used to be fined and worked for months without an issue and suddenly in Friday it stopped for no reason I could see.
I suspect Verisure have changed something in their app but I can’t see what
