Thanks so Much! This version run perfectly
Where is this version repository?
regards
regards
I donât know⊠@sesardelaisla send me the file and I uploaded it with lifetime link.
I read that the problem with @segalion repository is that he is not using the âinstallationâ parameter, and it is needed. The new code shared is using pysecuritas dependency (https://github.com/Cebeerre/pysecuritas) from @Cebeerre⊠while @segalion 's code is copying to his source some files from pysecuritas but an older version with less parameters so is not working with new app.
Also there is a pull request (https://github.com/nragon/core/tree/dev/homeassistant/components/securitas_direct) to HomeAssistant core that is trying to add it to core, using Integrations instead of YAML configuration. It is using the last version of pysecuritas and is working. However, is not added to core yet.
I donât remember where I downloaded the file from. I think I didnât do it from the original repository, but from a domotics related Spanish web site, so perhaps someone else tweaked it.
It seems itâs available here:
Itâs a fork from @segalion updated to use pysecuritas (with compatibility with new app)
Hello all,
I lost connection to my securitas alarm a few HA versions ago⊠and I read your post⊠I upgraded the app a few weeks⊠and saw thisâŠI hoped to make it work⊠but I get this errorâŠ
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/securitas_direct/init.py:94
Integration: securitas_direct
First occurred: October 21, 2021, 9:37:48 PM (1 occurrences)
Last logged: October 21, 2021, 9:37:48 PM
Error during setup of component securitas_direct
File â/usr/src/homeassistant/homeassistant/setup.pyâ, line 254, in _async_setup_component
result = await task
File â/usr/local/lib/python3.9/concurrent/futures/thread.pyâ, line 52, in run
File â/config/custom_components/securitas_direct/init.pyâ, line 65, in setup
if not HUB.login():
File â/config/custom_components/securitas_direct/init.pyâ, line 94, in login
self.installation_alias = self.installation.get_alias()
File â/usr/local/lib/python3.9/site-packages/pysecuritas/api/installation.pyâ, line 103, in get_alias
return self.get_sim_and_instibs()[âINSTALATIONâ][âALIASâ]
File â/usr/local/lib/python3.9/site-packages/pysecuritas/api/installation.pyâ, line 94, in get_sim_and_instibs
return self.sync_request(âSRVâ)
File â/usr/local/lib/python3.9/site-packages/pysecuritas/api/installation.pyâ, line 171, in sync_request
return self.request(payload)
File â/usr/local/lib/python3.9/site-packages/pysecuritas/api/installation.pyâ, line 183, in request
result = handle_result(result.get(âRESâ), result)
File â/usr/local/lib/python3.9/site-packages/pysecuritas/api/installation.pyâ, line 40, in handle_result
raise RequestException(result[âMSGâ])
pysecuritas.api.installation.RequestException: Hemos tenido problemas para identificarle, por favor, cierre la sesiĂłn y vuelva a iniciarla.
Any ideas�
Thanks in advance
thanks for this great module Iâm using without problem until now.
Iâm using the service from Italy with the new app and I was trying to use the Perimeter capability.
Just tried the pysecuritas PERI command (as you asked for) and it worked flawlessly.
I hope you will integrate this in the HA component/panel too.
pysecuritas -u xxxxxx -p xxxxxx -c IT -l it -i xxxxxx PERI
"RES": "OK",
"STATUS": "3",
"MSG": "La modalit\u00e0 Perimetrale \u00e8 attiva",
"NUMINST": "xxxxxxxx"
>pysecuritas -u xxxxxx -p xxxxx -c IT -l it -i xxxxxx DARM
"RES": "OK",
"STATUS": "0",
"MSG": "L'Allarme \u00e8 stato disattivato",
"NUMINST": "xxxxxx"
Regards and thanks in advance.
Dunno if this was already requested but⊠Is it possible to get the data from the sentinel (temp, humidity and air quality)? Thanks
Im having the same issue
ciao,
sono nuovo in questo mondo⊠sono riuscito a installare tutto ma anche io non riesco a inserire la modalità perimetrale. Come posso fare? credo che in qualche modo ci sei riuscito⊠grazie in anticipo
What version is the most recent/stable??
GitHub?
Dropbox link from this entry:
This is great, thanks because I was not able to test it. I am wondering if it would be easy to add this to the current version, probably using the custom bypass.
Hi, I have been able to arm the peri from the alarm panel in Home assistant. It seems the custom bypass was not active. so went to custom components folder and edit the alarm_control_panel.py and added the following line on the top:
import homeassistant.components.alarm_control_panel as alarm
from homeassistant.components.alarm_control_panel.const import (
SUPPORT_ALARM_ARM_AWAY,
SUPPORT_ALARM_ARM_HOME,
SUPPORT_ALARM_ARM_NIGHT,
SUPPORT_ALARM_ARM_CUSTOM_BYPASS)
and this on the bottom
@property
def supported_features(self) -> int:
"""Return the list of supported features."""
return (SUPPORT_ALARM_ARM_HOME
Now clicking the custom bypass button in the alarm panel it works.
I hope it helps the ones trying to use the perimiter capability.
Hi everyone,
Here you can find my first attempt of having a functional component for using securitas direct in Home Assistant.
https://github.com/guerrerotook/securitas-direct-new-api
This component is using the same configuration as the old one and itâs using the new API that Securitas Direct migrated all users.
Please download the component and tell me what do you think. For now itâs functional and you can arm and disarm your alarm and also works with multiple installations in case that you have more that one alarm in you account.
If you have feedback please create a new issue in my repository.
Thanks!
Im trying to install it now. what parameters are required in the configuration.yaml file?
I updated the readme of the project, but the same configuration that in the previous integration. And the domain for the integration is the same, so you can reuse your configuration.
If you have feedback please an issue in my GitHub
thanks, working for me here in the uk.
Whats the difference in performance, stability, code aprovecharâŠ, compared to this other one?
I donât know what is the different in these terms. The zip that you shared is using the old API and that API is going to be eventually shutdown, so that is why you canât compare these two. My implementation is based on the new API and I conform with what Home Assistant required to a integration. I take the time to modernize the code and make it more complaint with new rules in HA.
Hi Luis!!! thanks for the fix, It work perfectly to me in Spain.
It doesnât seem possible to get this in the app either
