Great work with this blueprint!!! Its amaizng tool
-Is it possible to add more devices to send a same notification in one automation?
-Could you upgrade your blueprint to add several motion sensors and connect them with camera?
In that case I want to send a notification to 3 devices. I have 8 cameraâs and 14 motion detection. I had to created 24 automations with your blueprint and I only solved 8 motion detectionâŚ
It would be great to have one blueprint for many devices, many motion detections and many cameras.
Something like:
-Choose how many cameras do you have?
-Put a list of sensors for each camera
-Put a list of devices for notification for each camera
-Put title and text for notification for each camera
-Put a conditional (if alarm set or time is between sunrise/sunset) for each camera
Thank you very much for your blueprint. I have also installed it in my Home Assistant. Unfortunately, it does not work as desired. I have integrated my cameras via onvif. Normally i use synology surveillance station. There it detect motion.
I have tested âInputCellMotion Detectionâ and âInputMotionAlarmâ as motion sensors. Unfortunately, I do not receive a notification when motion is detected. If I run through the automation as a test, it works. Here is my automation. I use my outdoor cameras from Anke (Hikvision). Does anyone have an idea what the problem is and can they help me?
Yes, they are saved in /media, but every time the event is triggered the image is replaced (there is a way to save them with time and date, so as not to rewrite it, but I donât use this function)
I didâŚ
Hmmm, I think I figured it out though. For whatever strange reason, a SECOND device for my iPhone was created ⌠the first one was âiPhoneâ and the second one was âiPhone (5)â. Crazy.
Both pointed to the same iPhone but had different information (e.g. battery level was different). Sending a message to both worked. But images only worked with the former one.
I deleted both devices and when restarting the app the device was re-created.
first off I wanted to thank the author for this awesome blueprint. It worked right away for me. Secondly, Iâd like to ask if thereâs a way to reduce the number of notifications it sends somehow. I noticed that the camera motion sensor detects persons continuosly (like every 3 seconds or so), so if someone stands just under the camera for a while, it is continuosly monitored, therefore I receive a loooot of notifications (an unmanageable number).
Is there a way to reduce these notifications? I was thinking to use the delay setting, but I donât want that to impact the time it detects somebody and I receive the notification for the first time⌠any suggestions?
This blueprint worked like a charm for me on my reolink E1.
Could someone please tell me which exact lines of code are used to retrieve and then save the image, Iâd like to use them elsewhere as my usual snapshot method does not seem to work on this camera.
Also, is there any way to save the image to my phone?
Hey, I went through all the replies and didnt find any solution that would work The automation used to work perfectly on my HA app on my iPhone and now when im connected to local URL I only get a small preview of the snapshot and when i tap and hold on the notification a large snapshot no longer appears. AND when im connected to an external URL, I only get a text notification without even the small preview of the snapshot. Both used to work with both the preview and a large snapshot appearing after tap and holding on the notification. Also used to work on my apple watch. Is there a fix? Nothing changed in my HA as far as i know. Thanks!!
also - for some reason with this automation (đ¸ Notification with camera snapshot with blocking condition and clickaction) when on local i can at least do the tap and hold to see the larger snapshot⌠really strange - with this automation only the external doesnt work (at all, not even the small preview image)
Hey, how do I send the notification to several devices?
I should modify the blueprint? And create a group of devices? What if itâs a mix of ios and android devices?
Hi, Thank you for the blueprint script. It is working fine.
Iâm newbie on HA, my question is just a support about the following issue.
How can I integrate condition to that blueprint script, example, send me the snapshot notification only when I.m out of Home zone.
Can you help me ?
Thanks a lot
