Send local content URL to Chromecast Audio
I am attempting to configure HASS and a Chromecast Audio device to play sounds on the same RPi3 via a share URL. I have the chromecast set up to play an iHeart Radio stream for the dog when I leave, which works, but I can’t get it to play a local media file as an alert sound. Has anyone set this up? Any suggestions on alternate config I need to do?
IHeart radio config - working
  • service: media_player.play_media
    entity_id: media_player.living_room_music
    media_content_id: [stream url]
    media_content_type: audio/mp3
Local url mp3 file
Both content urls will start playing in my browsers without issue.
I got this to work by installing a plex media server on the raspberry pi. Then used plex to get a stream url that is used on the configuration of home assistant.
I tested with " python -m SimpleHTTPServer " and it worked great… think I might use it to cast voice notifications.
  - service: media_player.play_media
    entity_id: media_player.chromecast_audio
      media_content_id: http://<<hass_host>>:8000/test.mp3
I tried that but it was not working for me. I will have to try again, thanks!
I managed to get it working using python -m http.server 8080 (since I’m using Python 3.5) and the following code -
automation 4:
# If you select “FireplaceBurning”, play the “FireplaceBurning.avi” file
- alias: Play FireplaceBurning Lullaby
platform: state
entity_id: input_select.lullaby
to: “FireplaceBurning AVI”
- service: media_player.turn_on
- delay: 0:0:02
media_content_id: http://192.168.1.56:8080/FireplaceBurning.avi
media_content_type: video/avi
# If you select "Heavy Rain MP3", play the "Heavy Rain MP3" file
- alias: Play Heavy Rain Lullaby
    platform: state
    to: "Heavy Rain MP3"
    - delay: 0:0:02
        media_content_id: http://192.168.1.56:8080/Heavy Rain.MP3
If you select "None, turn the Chromecast off
- alias: Stop the Lullaby
    platform: state
    to: "None"
    service: media_player.turn_off
Define our dropdown list
input_select:
lullaby:
options:
- Heavy Rain MP3
- FireplaceBurning AVI
- None
initial: None
icon: mdi:weather-rainy
I could not get it to work at all with either streaming or MP4 files however AVI and MP3 work great.
@jasonmscollins How exactly did you do that mate ? I have a plex media server running in my Synology NAS which I can play from Web address. And from Plex ofcourse I can cast any media to Chromecast. But from hass, I can’t trigger any media via Chromecast; while my chomecast is discovered in hass but plex is not discovered there though. But I dont think that should be problem as I wanted to play the media from plex through Chromecast. So, I think Plex need not to be discovered in hass ??
The problem I find the media link which I need to play… If I try via the dev-service > media_players.play_media and then trying to cast the media_content_id as “http://:32400/library/metadata/397”. Should it be the right address ?
I got the metadata information from the dev-state > Chromecast > media_information… But it seems it is not the right address :frowning:
By the way, if I directly paste the link in a web, it opens up a xml file instead of opening the media.
Tarikul
@tarikul did you ever get this working? im looking at geeting a chromecast and of course these days i buy tech to fit in with my HA_
Hi Jason, to play local media via Chromecast from home assistant, in my case it worked only if I ran Python simplehttpserver. I couldn’t get Plex work properly to meet my requirement.
However, as I didn’t like the idea of running the simple http server in background. I completely moved to Kodi media centre where I can even play YouTube video from Hass. In deed, some days, I quickly upload a video in YouTube in private mode, get the ID and straightaway play at home to instruct or inform something via the TV :slight_smile: when I am at office…
I am able to play a remote URL mp3 file using google cast. But when I run the python simple HTTP server, the file does not play. If I pate the URL (http://localhost:8000/garagedooropen.mp3) in a browser tab, the audio plays fine, so the URL is correct. Any ideas, maybe one of you guys has encountered this?
I was able to run under Ubuntu like this:
I run simple http server under my ha_audio folder, not sure which makes any difference or not
python3 -m http.server 8091
And this is how I run service:
    entity_id: media_player.audio_house_speakers
    media_content_id: http://192.168.1.22:8091/ha_audio/SomeAudioFile.mp3
Hi! Is it possible to stream a url to a radio channel to my Chromecast audio. I can’t get it to work with this setup.
alias: Google audio p4
  platform: state
  entity_id: input_boolean.radio_p4
  state: 'on'
    entity_id: media_player.kk
      media_content_id: http://tunein.com/radio/P4-Malm%C3%B6hus-1020-s47336/
It is possible. I stream an iHeartRadio station to my google home when I’m not around so the dogs don’t have to hang out in silence.
      entity_id: media_player.google_home
        media_content_id: "http://wegr-fm.akacast.akamaistream.net/7/628/20075/v1/auth.akacast.akamaistream.net/wegr-fm"
        media_content_type: "audio/mp3"
I was having a similar issue until I used the same syntax that @Bahnburner used. Thanks @Bahnburner
Glad I could help.
Thanx to both @Bahnburner and @adamderuwe . It works!
Were you ever able to get this to work with TuneIn? All I get is Default Media Receiver Idle
Didn’t try, but i had the same problem in the begining. I solved it by open my live stream with vlc. In VLC I looked at information and found a direct link to the stream. I hope it can help you.
however this is my setup and it works
alias: Google audio på p4 köket
  platform: state
  entity_id: input_boolean.radiomalmo_p4
  state: 'on'
  - service: switch.turn_on
    entity_id: switch.google_audio_kket
  - delay: 00:00:03
      media_content_id: "http://http-live.sr.se/p4malmo-mp3-192"
Thank you! I will give it a shot
Is it possible to cast a link from Spotify to google audio? Can’t get it to work and I think it is because account and password. Someone that have succeed with this?
Hi
Are you running SSL as well? will the python -m http.server 8080 interfere with HA?
Also can you please guide me on how to set it up? I cannot play my mp3 files to my chromecast audio.
