Thanks @valvex
Inspired by your work, this got me thinking and I had a play, up to this point I had zero python experience but wanted a challenge and was intrigued by MQTT which I’d stumbled upon elsewhere.
I have done this through excessive use of Google, looking at other peoples work and lot & lots of trail and error. I would love it if anyone could offer advice as to where I could do things better, stuff I should not do etc. etc.
My approach was to use auto discovery in Home Assistant to create an entity for each VPN client within pivpn using the pivpn -l
command (and remove them if they were deleted), then have MQTT check-in every so often with a status update on them using pivpn -c
and your work.
#!/usr/bin/env python3
import os
import json
import paho.mqtt.client as mqtt
import time
import threading
import logging
from datetime import datetime
logging.basicConfig(level=logging.WARNING, format='%(asctime)s %(levelname)s: %(message)s')
# --- CONFIGURATION OPTIONS ---
discoveryTopicPrefix = 'homeassistant/sensor/'
topicPrefix = 'home/nodes/vpnclients/' # suffix (state /state, attributes /attr, availability /status)
vpnType = 'WireGuard' # WireGuard or OpenVPN or other?
mqttUser = 'USERNAME'
mqttPassword = 'PASSWORD'
mqttAddress = 'IP.ADDRESS' # assumes standard ports
updateFrequency = 5 # in minutes
# --- END CONFIGURATION OPTIONS ---
# MQTT Connection Made
def on_connect(client, userdata, flags, rc):
logging.debug('--> on_connect')
logging.info('Connected with result code '+str(rc))
stateTopic = '{}status'.format(topicPrefix) # publish status update
client.publish(stateTopic, payload='Online', qos=0, retain=True)
for device in deviceList: # call discovery for each device
publishDiscovery(device)
# Timer based on update frequency
def periodTimeoutHandler():
global deviceList
logging.info('Timer interrupt')
updatedDeviceList = getDeviceList() # Get an upto date list of devices
logging.info('Updated device list...')
logging.info(updatedDeviceList)
if deviceList != updatedDeviceList: # Compare the previous and current lists
logging.info('Device lists are different')
newDevices = [i for i in updatedDeviceList if i not in deviceList]
logging.info('New devices:')
logging.info(newDevices)
removedDevices = [i for i in deviceList if i not in updatedDeviceList]
logging.info('Removed Devices')
logging.info(removedDevices)
for deviceName in newDevices: # Create discovery data for new devices
publishDiscovery(deviceName)
for deviceName in removedDevices: # Remove HA entity/device for removed devices
removeDiscovery(deviceName)
else:
logging.info('Device lists are the same')
deviceList = updatedDeviceList # Update the device list
publishDeviceAttributes() # Call to publish the attributes for each device
startPeriodTimer()
def startPeriodTimer():
logging.debug('--> startPeriodTimer')
global endPeriodTimer
global periodTimeRunningStatus
stopPeriodTimer()
endPeriodTimer = threading.Timer(updateFrequency * 60.0, periodTimeoutHandler)
endPeriodTimer.start()
periodTimeRunningStatus = True
logging.info('Timer Started')
def stopPeriodTimer():
endPeriodTimer.cancel()
periodTimeRunningStatus = False
logging.info('Timer stopped')
# Get VPN Device List
def getDeviceList():
logging.debug('--> getDeviceList')
rawDevices = os.popen("pivpn -l").read().split()
deviceCount = (len(rawDevices) - 9) / 7
x = 0
namePosition = 9
deviceList = []
while x < deviceCount:
deviceName = rawDevices[namePosition]
logging.info('Appending device ' + deviceName + ' to deviceList')
deviceList.append(deviceName)
x += 1
namePosition += 7
return deviceList
# Publish discovery data for a device
def publishDiscovery(deviceName):
logging.debug('--> publishDiscovery(' + deviceName + ')')
discoveryTopic = '{}{}/config'.format(discoveryTopicPrefix, deviceName)
payload = {}
payload['name'] = 'VPN Client {}'.format(deviceName.title())
payload['unique_id'] = 'VPN{}{}Client'.format(vpnType, deviceName)
#payload['device_class'] = 'timestamp'
payload['state_topic'] = '{}{}/state'.format(topicPrefix, deviceName)
payload['payload_available'] = 'Online'
payload['payload_not_available'] = 'Offline'
payload['availability_topic'] = '{}status'.format(topicPrefix)
payload['icon'] = 'mdi:vpn'
payload['json_attributes_topic'] = '{}{}/attr'.format(topicPrefix, deviceName)
payload['dev'] = {
'identifiers' : ['vpnClient{}'.format(deviceName)],
'manufacturer' : vpnType,
'name' : 'VPN-Client-{}'.format(deviceName.title()),
'model' : 'VPN Client',
'sw_version': "not applicable"
client.publish(discoveryTopic, json.dumps(payload), 0, retain=True)
# Remove discovery data for deleted devices
def removeDiscovery(deviceName):
payload = {}
# Publish attribute data for devices
def publishDeviceAttributes():
logging.debug('--> publishDeviceAttributes')
for deviceName in deviceList:
logging.info('Getting device attributes for ' + deviceName)
query = "pivpn -c | grep '" + deviceName + "'" # Get device row data
clientRecord = os.popen(query).read().split()
if clientRecord[5]=="(not":
data = json.dumps({"device":clientRecord[0], "remote_ip":clientRecord[1], "local_ip":clientRecord[2], "received":clientRecord[3], "sent":clientRecord[4], "seen":clientRecord[5]+' '+clientRecord[6]})
state = clientRecord[5] + ' ' + clientRecord[6]
else:
data = json.dumps({"device":clientRecord[0], "remote_ip":clientRecord[1], "local_ip":clientRecord[2], "received":clientRecord[3], "sent":clientRecord[4], "seen":clientRecord[5]+' '+clientRecord[6]+' '+clientRecord[7]+' '+clientRecord[8]+' '+clientRecord[9]})
state = clientRecord[5] + ' ' + clientRecord[6] + ' ' + clientRecord[7] + ' ' + clientRecord[8] + ' ' + clientRecord[9]
logging.info('Device attributes...')
logging.info(data)
logging.info('Device state...')
logging.info(state)
topic = '{}{}/attr'.format(topicPrefix, deviceName)
client.publish(topic, str(data), retain=False) # Publish attributes
topic = '{}{}/state'.format(topicPrefix, deviceName)
client.publish(topic, state, retain=False) # Publish state
# Timer configuration
deviceList = []
reported_first_time = False
# MQTT connection
client = mqtt.Client()
client.on_connect = on_connect
client.username_pw_set(username=mqttUser,password=mqttPassword)
client.connect(mqttAddress, 1883, 60)
stateTopic = '{}status'.format(topicPrefix) # set last will
client.will_set(stateTopic, payload='Offline', qos=0, retain=True)
# Commence Timer & get initial device list
deviceList = getDeviceList()
logging.info('Inital device list...')
logging.info(deviceList)
startPeriodTimer()
client.loop_forever()
copy here: https://github.com/woodmj74/pivpn_vpnrpt/blob/50150a5241c41455ef07e408878622004b2e6196/vpnrpt.py
I created a service on the PI to run this and then with with Thomas Loven’s auto entities card to auto populate these:
type: 'custom:auto-entities'
show_empty: false
card:
type: entities
title: VPN Clients
filter:
include:
- entity_id: sensor.*vpn_cl*
options:
secondary_info: last-changed
There’s still loads I think I need to do and will likely change it as I learn more, as said above happy to receive any guidance from those wiser than me and like valvex putting this out there as an idea.
I should also credit https://github.com/ironsheep/RPi-Reporter-MQTT2HA-Daemon where I learnt/‘borrowed’ quite a bit from.
