Send wireguard client info to HA with mqtt + template sensor to show active clients
Hello everyone and Merry Christmas.
About half a year ago I posted a simple way on how to show piVPN client info on HA. @woodmj74 has made an excellent script for that matter, so be sure to check out the thread if you’re still using piVPN.
However, I recently bought an Edge Router X so I decided to run Wireguard directly on the router.
Once again, I wanted to send my client’s info to home assistant, so here’s a very simple way to do this.
If you run the sudo wg command on your router’s terminal you will get a long list with all your clients and their activity (remote IP, last seen, data usage etc).
In order to send this data over to HA, use the following scipt and edit accordingly.
## Replace 'peer_id' with your actual peer id, eg. 6bUWCstPx52ufh=138fsf234efd ##
## Replace mqtt_ip, mqtt_user, mqtt_pass and mqtt_topic ##
#!/bin/bash
ip=$(sudo wg | grep -A 4 'peer_id' | grep 'endpoint' | sed s'/endpoint://' | sed -e 's/^[[:space:]]*//')
lastseen=$(sudo wg | grep -A 4 'peer_id' | grep 'latest' | sed s'/latest handshake://' | sed -e 's/^[[:space:]]*//')
data=$(sudo wg | grep -A 4 'peer_id' | grep 'transfer' | sed s'/transfer://' | sed -e 's/^[[:space:]]*//')
final='{"Client":"your_client_name","IP":"'"$ip"'","Last Seen":"'"$lastseen"'","Data":"'"$data"'"}'
mosquitto_pub -h mqtt_ip -u "mqtt_user" -P "mqtt_pass" -t mqtt_topic -m "$final" -r
Save the file as something.sh and run it with crontab at your desired schedule.
Create an mqtt sensor on your configuration.yaml or sensor.yaml with the following:
- platform: mqtt
  name: ## your desired sensor name ###
  state_topic: ## the mqtt_topic you specified earlier ##
  icon: mdi:vpn
  json_attributes_topic:  ## the mqtt_topic you specified earlier ##
  value_template: "{{ value_json.Client }}"
Finally, you will have something like this:
wg
Now, regarding the template binary_sensor that shows if a client is currently active.
The sudo wg command provides info on when the client was last seen in the format shown in the picture above. (eg. 3 seconds ago, 2 days 4 hours 6 minutes ago etc.)
In order to translate this to something useful, i’ve created a template binary_sensor that checks for words such as days, hours, minutes, seconds etc. And determines if a client was last seen in the previous 3 minutes, thus making this client active.
Maybe there is a better more efficient way, but this works for me, so here it is…
In your configuration.yaml or binary_sensor.yaml add a new template binary_sensor and remember to edit accordingly:
  sensors:
    vpn_alexlaptop:
        friendly_name: "Alex Laptop VPN Active"
        value_template: >
                    {% if state_attr('sensor.vpn_alex_laptop','Last Seen') != '' %}
                        {% if 'day' in state_attr('sensor.vpn_alex_laptop','Last Seen') or 'days' in state_attr('sensor.vpn_alex_laptop','Last Seen') or 'hour' in state_attr('sensor.vpn_alex_laptop','Last Seen') or 'hours' in state_attr('sensor.vpn_alex_laptop','Last Seen') %}
                        False
                        {% elif 'minute' in state_attr('sensor.vpn_alex_laptop','Last Seen') or 'minutes' in state_attr('sensor.vpn_alex_laptop','Last Seen') %}
                            {% if (state_attr('sensor.vpn_alex_laptop','Last Seen').replace("ago","").replace('minutes','').replace('minute','').replace('seconds','').replace('second','').split(',')[0].strip() | int) < 3 %}
                                True
                            {% else %}
                                False
                            {% endif %}
                        {% else %}
                        True
                        {% endif %}
                    {% else %}
                    False
                    {% endif %}
binary
Can this be made to work with the Wireguard add-on for HA?
I’m using a similar approach for the add on
Thanks for the link. I am using this in a slightly changed version:
- platform: rest
    name: WireGuard peers status API
    resource: http://a0d7b954-wireguard
    value_template: "OK"
    json_attributes:
      - peer00
      - peer01
template:
  - binary_sensor:
      - name: WireGuard Peer peer00
        state: "{{ state_attr('sensor.wireguard_peers_status_api', 'peer00').latest_handshake > as_timestamp(now()) - 180 }}"
      - name: WireGuard Peer peer01
        state: "{{ state_attr('sensor.wireguard_peers_status_api', 'peer01').latest_handshake > as_timestamp(now()) - 180 }}"
(Edit: Had used the endpoint attribute checked against "(none)" before, but this apparently never resets…)
Thank you for sharing this. I was able to get it up and running with a cronjob every minute to update binary sensor.
I am unable to see any of my data or allowed ips (i added this part in using your script). But both the data and allowed ips return empty in home assistant.
Below is my .sh being run by cron
#!/bin/bash
ip=$(sudo wg | grep -A 4 'Key' | grep 'endpoint' | sed s'/endpoint://' | sed -e 's/^[[:space:]]*//')
virtualip=$(sudo wg | grep -A 4 'Key' | grep 'virtualip' | sed s'/allowed ips://' | sed -e 's/^[[:space:]]*//')
lastseen=$(sudo wg | grep -A 4 'Key' | grep 'latest' | sed s'/latest handshake://' | sed -e 's/^[[:space:]]*//')
data=$(sudo wg | grep -A 4 'Key' | grep 'transfer' | sed s'/transfer://' | sed -e 's/^[[:space:]]*//')
final='{"Client":"Client-S21","IP":"'"$ip"'","Virtual IP":"'"$virtualip"'","Last Seen":"'"$lastseen"'","Data":"'"$data"'"}'
mosquitto_pub -h 192.168.0.111 -u "user" -P "pass" -t wgs21 -m "$final" -r
Below is what I get in home assistant
I am able to see all the stats in my machine with the command wg
Can the @valvex or anyone help me figure out whats going on?
Just wanted to say thanks very much for this. I made a modification to the script to allow multiple peers. Wireguard CLI to MQTT Bash Script - For getting Wireguard information in to Home Assistant MQTT sensors · GitHub
I run Wireguard on a Windows computer. Has anyone figured out how to monitor the WG status of Windows machines?
The solution presented here does not query your client, but the Wireguard server. Therefore, it does not matter which client OS you use.
(If you are running a Wireguard server on Windows, sorry, then what I said is not true)
However, I am still struggling with the solution.
Hey guys! Based on this topic and some additional investigations, I made automatic WireGuard server monitoring with MQTT Discovery.
In my case I have 2 scripts:
  • first available to exec by ssh on the VPS with vpn-server;
  • second must be executed for e.g. from Home Assistant container (you can create automation schedule I guess for call shell_command).
Fisrt script combine all data and print it as json. Second script calls first and publish all data to the target MQTT broker. Then Home Assistant MQTT module automatically creates new sensor-based devices with all entities. Also you can add multiple WireGuard servers for monitoring. I’m using docker and AmneziaVPN, so you probably will need to adjust the scripts a little.
See sample picture below.
You could find a sample here: Wireguard CLI to MQTT Bash Script - For getting Wireguard information in to Home Assistant MQTT sensors · GitHub
An old thread I know, but this was something I wanted to do.
Using the great suggestions above, I have created a docker container which when run on the Wireguard host will report the status to MQTT, which in turn automatically creates and populates the respective sensors in HA
Maybe someone else will find it useful
