Anyone care to suggest what sort of latency they are seeing from this? I’m looking into putting some cameras in the hallway of my house and currently use a motion sensor to trigger lighting at night. Would this be a fast enough replacement, or would you get most of the way down a hallway before HA even got the motion detection event?
Understand its going to be camera dependent, but a general idea would be good.
This is pretty fast in my experience, <2s. If you use a Hikvision camera though, HA have native integration for the cameras integrated sensors including motion, line cross and intrusion detection (which I also use), that may be a little faster and be easier to integrate?
OK that sounds interesting, I was actually looking at Hikvision so that might be a better option.
I currently have two types of motion sensors, one hardwired Ness units (painful to run new cabling in the roof for them though) and they are <100ms so pretty great, and Ikea Zigbee ones which are about 500ms or more. 2s sounds like much too much, I’d get most of the way down the hall and/or fall over something in the dark at that point.
snapshot_porch_camera:
alias: Trigger input boolean for motion from API
sequence:
entity_id: input_boolean.home_porch_motion
- delay: 00:00:05
- service: input_boolean.turn_off
Now here is where I am getting confused. I’ve installed this blueprint (📸 Send camera snapshot notification on motion) and it needs a binary_sensor to trigger the automation. What do I feed into the motion sensor field in this blueprint from all of this above? I thought it would be input_boolean.home_porch_motion but that doesn’t seem to be an entity? Did I miss a step? Forgive me, I am very new to Home Assistant.
You could also edit the blueprint here config\blueprints\automation\vorion\send-camera-snapshot-notification-on-motion.yaml (create a copy) and change the motion sensor domain to input_boolean?
blueprint:
name: Send a camera snapshot when motion is detected
description: 'This automation blueprint creates a camera snapshot if motion is detected and
sends a notification to your phone with the picture.
domain: automation
input:
motion_sensor:
description: The sensor which triggers the snapshot creation
selector:
entity:
domain: input_boolean
device_class: motion
With this modified blueprint, I would fill input_boolean.home_porch_motion for motion sensor? I see that entity listed in scripts.yaml but not mentioned anywhere else. That entity is not showing up in HA for me. Did I miss the instructions to create that entity?
Thank you, I just got it working! Here’s an updated guide of what I did:
In configuration.yaml add these 2 pieces:
homeassistant:
auth_providers:
- type: trusted_networks
trusted_networks:
- 192.168.1.26 # You Synology Surveillance Station IP
input_boolean:
home_porch_motion:
name: Porch camera motion
icon: mdi:cctv
In automations.yaml add the following. Pay attention to the webhook URL and ID.:
- alias: 'Porch Camera Motion' # For reference, paste your webhook URL that you setup in Synology here: http://192.168.1.56:8123/api/webhook/motion_porch
- platform: webhook
webhook_id: motion_porch
- service: camera.snapshot
entity_id: camera.home_porch
filename: '/config/www/snapshot-porch.jpg'
- delay: 00:00:05
In Synology Surveillance Station, open Action Rules and enter these settings. In the third picture it says Action 2, if you are just setting this up you will only have Action 1:
Awesome, well done. If you want to keep things tidy, you could just add the following into your action items without using the script. I only used a script as I had another action after this code that I didn’t want affected by the delay but you don’t need that.
