Guys I made a complete tutorial on how to set it up here: Broadlink AC Integration (AUX, Dunham, Rcool, Akai, Rinnai, Kenwood, Tornado, Ballu)
I just set this up and thought I would share the pitfalls I fell into.
I am running the docker (https://github.com/broadlink-ac/broadlink_ac_mqtt_docker) on unraid and connecting it to HASSOS running in a VM. I ahve a couple of rinnai AC units that are controllable with the AC freedom app.
Andremain’s guide was useful for trouble shooting. Thanks
My pitfalls:
- the config.yaml for the docker doesnt seem to parse passwords with symbols correctly. This prevented the docker from connecting to the MQTT broker. changing the password to alphanumeric characters resolved it.
- My AC units werent being discovered. Using MQTT explorer I could see the docker was connected to the MQTT broker but no data was being passed. I assume this is due to having the AC units on a different vlan and UDP not being passed between the networks. Manually adding the devices to the dockers config.yaml didnt fix it. But thankfully someone earlier in this thread had solved the issue. Change self discovery to false. All sorted.
My last issue is getting the ac unit temp to appear as a sensor in home assistant. I can control them using love lace but want to do some basic datalogging. Still new to Home assistant.
Thanks to any and all that worked on the code to make this possible.
I’ve set this up in docker desktop but from the logs it is just looping with these errors:
Set the network to host.
Uses this pull:
https://hub.docker.com/r/broadlinkac/broadlink_ac_mqtt/tags?page=1&ordering=last_updated
What am I missing?
Starting Monitor...
[Errno -3] Try again
Stopping
Starting Monitor...
hi, i know its a old post, but if u could, i need ur help, i have 2 ac unitsone buyed about 3-4 years ago whit broadlink wifi module,working perfectly whit ur script monitor.py
the other one,same model but newer, cant be discover, i tried mqtt explorer, i could see topics in /aircon but 0 topics from this one.
my question is, how could i know about topic i must search for new ac?
ty
Hi All, Please vote here for my idea:
Thanks!
I also get this issue. I’m a new user. Tried installing it a few weeks ago .
monitor stop basicaly if cant find configuration or log file, or if cant found any ac
your ac works whit acfredoom?
look at propierties of ur ac in app and look if he shows and [email protected]
if not probably u have newwer units and this script didnt work
Installation of PyCrypto keeps failing:
Installing collected packages: PyCrypto
Running setup.py install for PyCrypto ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py'"'"'; __file__='"'"'/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-han661ge/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/PyCrypto
cwd: /tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/
Complete output (189 lines):
running install
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.9
creating build/lib.linux-aarch64-3.9/Crypto
copying lib/Crypto/__init__.py -> build/lib.linux-aarch64-3.9/Crypto
copying lib/Crypto/pct_warnings.py -> build/lib.linux-aarch64-3.9/Crypto
creating build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/MD4.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/SHA384.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/RIPEMD.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/SHA256.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/HMAC.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/MD2.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/SHA512.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/SHA224.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/hashalgo.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/SHA.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
copying lib/Crypto/Hash/MD5.py -> build/lib.linux-aarch64-3.9/Crypto/Hash
creating build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/blockalgo.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/DES3.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/XOR.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/PKCS1_OAEP.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/Blowfish.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/ARC2.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/DES.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/AES.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/PKCS1_v1_5.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/CAST.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
copying lib/Crypto/Cipher/ARC4.py -> build/lib.linux-aarch64-3.9/Crypto/Cipher
creating build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/RFC1751.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/randpool.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/_number_new.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/py3compat.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/asn1.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/Counter.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/winrandom.py -> build/lib.linux-aarch64-3.9/Crypto/Util
copying lib/Crypto/Util/number.py -> build/lib.linux-aarch64-3.9/Crypto/Util
creating build/lib.linux-aarch64-3.9/Crypto/Random
copying lib/Crypto/Random/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Random
copying lib/Crypto/Random/_UserFriendlyRNG.py -> build/lib.linux-aarch64-3.9/Crypto/Random
copying lib/Crypto/Random/random.py -> build/lib.linux-aarch64-3.9/Crypto/Random
creating build/lib.linux-aarch64-3.9/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/SHAd256.py -> build/lib.linux-aarch64-3.9/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/FortunaGenerator.py -> build/lib.linux-aarch64-3.9/Crypto/Random/Fortuna
copying lib/Crypto/Random/Fortuna/FortunaAccumulator.py -> build/lib.linux-aarch64-3.9/Crypto/Random/Fortuna
creating build/lib.linux-aarch64-3.9/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/fallback.py -> build/lib.linux-aarch64-3.9/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/rng_base.py -> build/lib.linux-aarch64-3.9/Crypto/Random/OSRNG
copying lib/Crypto/Random/OSRNG/posix.py -> build/lib.linux-aarch64-3.9/Crypto/Random/OSRNG
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest
copying lib/Crypto/SelfTest/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest
copying lib/Crypto/SelfTest/st_common.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/common.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_DES3.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_Blowfish.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_ARC2.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_CAST.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_DES.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_AES.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_pkcs1_15.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_XOR.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_pkcs1_oaep.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
copying lib/Crypto/SelfTest/Cipher/test_ARC4.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Cipher
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/common.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_MD2.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA512.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_HMAC.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA224.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA384.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_SHA256.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_MD5.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_RIPEMD.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
copying lib/Crypto/SelfTest/Hash/test_MD4.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Hash
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_AllOrNothing.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_KDF.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_chaffing.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Protocol
copying lib/Crypto/SelfTest/Protocol/test_rfc1751.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Protocol
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_importKey.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_ElGamal.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_RSA.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/PublicKey
copying lib/Crypto/SelfTest/PublicKey/test_DSA.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/PublicKey
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/test_random.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/test__UserFriendlyRNG.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random
copying lib/Crypto/SelfTest/Random/test_rpoolcompat.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/test_FortunaGenerator.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/test_FortunaAccumulator.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/Fortuna
copying lib/Crypto/SelfTest/Random/Fortuna/test_SHAd256.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/Fortuna
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_fallback.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_winrandom.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_generic.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_nt.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
copying lib/Crypto/SelfTest/Random/OSRNG/test_posix.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Random/OSRNG
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_Counter.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_winrandom.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_number.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Util
copying lib/Crypto/SelfTest/Util/test_asn1.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Util
creating build/lib.linux-aarch64-3.9/Crypto/SelfTest/Signature
copying lib/Crypto/SelfTest/Signature/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Signature
copying lib/Crypto/SelfTest/Signature/test_pkcs1_pss.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Signature
copying lib/Crypto/SelfTest/Signature/test_pkcs1_15.py -> build/lib.linux-aarch64-3.9/Crypto/SelfTest/Signature
creating build/lib.linux-aarch64-3.9/Crypto/Protocol
copying lib/Crypto/Protocol/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Protocol
copying lib/Crypto/Protocol/KDF.py -> build/lib.linux-aarch64-3.9/Crypto/Protocol
copying lib/Crypto/Protocol/AllOrNothing.py -> build/lib.linux-aarch64-3.9/Crypto/Protocol
copying lib/Crypto/Protocol/Chaffing.py -> build/lib.linux-aarch64-3.9/Crypto/Protocol
creating build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/_DSA.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/_slowmath.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/ElGamal.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/DSA.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/_RSA.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/RSA.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
copying lib/Crypto/PublicKey/pubkey.py -> build/lib.linux-aarch64-3.9/Crypto/PublicKey
creating build/lib.linux-aarch64-3.9/Crypto/Signature
copying lib/Crypto/Signature/__init__.py -> build/lib.linux-aarch64-3.9/Crypto/Signature
copying lib/Crypto/Signature/PKCS1_PSS.py -> build/lib.linux-aarch64-3.9/Crypto/Signature
copying lib/Crypto/Signature/PKCS1_v1_5.py -> build/lib.linux-aarch64-3.9/Crypto/Signature
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
running build_configure
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
File "<string>", line 1, in <module>
File "/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py", line 456, in <module>
core.setup(**kw)
File "/usr/lib/python3.9/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.9/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.9/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/usr/lib/python3.9/site-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/usr/lib/python3.9/distutils/command/install.py", line 546, in run
self.run_command('build')
File "/usr/lib/python3.9/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python3.9/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py", line 251, in run
cmd_obj.run()
File "/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py", line 278, in run
raise RuntimeError("autoconf error")
RuntimeError: autoconf error
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py'"'"'; __file__='"'"'/tmp/pip-install-toule5rt/pycrypto_8bfce04c62e84272ba9eee1456a7dcad/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-han661ge/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/PyCrypto Check the logs for full command output.
Any idea why?
Looks like you are missing the c compiler or at least the path to it. I would run the installer for gcc to see it will resolve that issue. If gcc is installed then adding the installed location to the path environment variable should do it.
Thanks, I’m pretty new to this so I’m trying to make sense of it all.
I’ve noticed that I do not have gcc. Can you point me to how to run the installer?
PS.
I’m running this install on a Raspberry 4b:
haos_rpi4-64-7.0.img.xz (github.com)
Yeah I get the same other than the Errno -3
error code. My aircon doesn’t use the ACFreedom app, rather the Home Comfort app, but thought I’d try it out as it uses a Broadlink Wifi chip as well.
All I receive via MQTT is the value “online” but I’m not sure whether that’s just the script/container that’s online or whether its an aircon.
Starting Monitor...
something went wrong, no devices found
Stopping
Starting Monitor...
Stopping
is it possible to make an integration with the help of this homebridge integration
I am also asking for help
We need this integration because many AC brands use the same app
Hello!
Maybe my code will help you.
I reversed AUX-based air conditioner protocol and made esphome component.
It is possible to drive AC from Home Assistant with DIY dongle (simple esp8266/esp32 + DC-DC + couple resistors).
Component source code is published on github.
How do I convert the temperature back to Fahrenheit?
Hi, thanks for the good work. In the AC Freedom app we can see the actual internal temperature of the room. Is it available in HA as a sensor?
Hi, Makis. Yes you can. For details see readme on github.
Can’t get it to work does not show up in MQTT Explorer. Running Docker on synology [broadlinkac/broadlink_ac_mqtt:latest] and Running MQTT [eclipse-mosquitto]
service:
daemon_mode: True
update_interval: 10
self_discovery: True
bind_to_ip: False
mqtt:
host: 192.168.1.106
port: 1883
client_id: ac_to_mqtt
user: *****
passwd: **********
topic_prefix: /aircon
auto_discovery_topic: homeassistant
auto_discovery_topic_retain: False
discovery: True
##Devices
devices:
- ip: 192.168.1.194
mac: A0:43:B0:AA:F1:22
port: 80
Got same config working except discovery: False
in my case.
