What am I doing wrong? New D1 wemos and Max 6675
logs show it sending temp, but I cannot find the sensor to add it to lovelace. I am expecting to find sensor.pit_#2
Thanks,
Grey
[18:07:40][C][wifi:355]: IP Address: 192.168.1.64
[18:07:40][C][wifi:356]: BSSID: [redacted]
[18:07:40][C][wifi:358]: Hostname: ‘pit’
[18:07:40][C][wifi:360]: Signal strength: -60 dB ▂▄▆█
[18:07:40][C][wifi:364]: Channel: 2
[18:07:40][C][wifi:365]: Subnet: 255.255.255.0
[18:07:40][C][wifi:366]: Gateway: 192.168.1.1
[18:07:40][C][wifi:367]: DNS1: 192.168.1.1
[18:07:40][C][wifi:368]: DNS2: 0.0.0.0
[18:07:40][C][logger:233]: Logger:
[18:07:40][C][logger:234]: Level: DEBUG
[18:07:40][C][logger:235]: Log Baud Rate: 115200
[18:07:40][C][logger:236]: Hardware UART: UART0
[18:07:40][C][spi:097]: SPI bus:
[18:07:40][C][spi:098]: CLK Pin: GPIO14
[18:07:40][C][spi:099]: MISO Pin: GPIO12
[18:07:40][C][spi:102]: Using HW SPI: YES
[18:07:40][C][max6675:025]: MAX6675 ‘Pit #1’
[18:07:40][C][max6675:025]: Device Class: ‘temperature’
[18:07:40][C][max6675:025]: State Class: ‘measurement’
[18:07:40][C][max6675:025]: Unit of Measurement: ‘°C’
[18:07:40][C][max6675:025]: Accuracy Decimals: 0
[18:07:40][C][max6675:026]: CS Pin: GPIO13
[18:07:40][C][max6675:027]: Update Interval: 20.0s
[18:07:40][C][captive_portal:088]: Captive Portal:
[18:07:40][C][mdns:084]: mDNS:
[18:07:40][C][mdns:085]: Hostname: pit
[18:07:40][C][ota:085]: Over-The-Air Updates:
[18:07:40][C][ota:086]: Address: 192.168.1.64:8266
[18:07:40][C][ota:089]: Using Password.
[18:07:40][C][api:138]: API Server:
[18:07:40][C][api:139]: Address: 192.168.1.64:6053
[18:07:40][C][api:143]: Using noise encryption: NO
[18:07:49][D][max6675:046]: ‘Pit #1’: Got temperature=36.2°C
[18:07:49][D][sensor:124]: ‘Pit #1’: Sending state 36.25000 °C with 0 decimals of accuracy
Looks like api: is specified going on the logs - but the hash (#) symbol is not supported in device ids - if you create an entity with the name “Pit #1” in HA it will give it an id of pit_1. Maybe that is the issue.
That is the wrong address for HA it should be 50 not 62?
[19:25:37][C][ota:085]: Over-The-Air Updates:
[19:25:37][C][ota:086]: Address: 192.168.1.62:8266
[19:25:37][C][ota:089]: Using Password.
[19:25:37][C][api:138]: API Server:
[19:25:37][C][api:139]: Address: 192.168.1.62:6053
[19:25:37][C][api:143]: Using noise encryption: NO
[19:25:40][D][max6675:046]: ‘Pit 1’: Got temperature=35.8°C
[19:25:40][D][sensor:124]: ‘Pit 1’: Sending state 35.75000 °C with 0 decimals of accuracy
[19:26:00][D][max6675:046]: ‘Pit 1’: Got temperature=35.8°C
[19:26:00][D][sensor:124]: ‘Pit 1’: Sending state 35.75000 °C with 0 decimals of accuracy
[19:26:20][D][max6675:046]: ‘Pit 1’: Got temperature=35.8°C
[19:26:20][D][sensor:124]: ‘Pit 1’: Sending state 35.75000 °C with 0 decimals of accuracy
sorry yes, i reinstalled another one that is working and figured that out
What now?
Yes I no longer see the MQTT accepted anywhere.
I appreciate your help soo much
Grey
