πŸ’‘ Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
New update 7.8
Your lighting experience, your way – take control and customize it to perfection! :bulb::sparkles:
:new: New Feature
  • Dynamic Lighting - State Control Option
    You now have an option to enable or disable dynamic lighting based on the state of a specified entity. When the entity is in the selected activation state, dynamic lighting will function as configured. When the entity is not in the activation state, dynamic lighting will be disabled. This allows you to toggle between normal lighting and dynamic lighting based on the entity’s state.
  • Dynamic Lighting - Next Day
    With options 10, 11, 12, and 13, you can now set the time for transitioning to a new day.
:bug: Bug Fixes
  • Dynamic Lighting
    • Resolved an issue with options 10, 11, 12, and 13 that could cause excessive RAM usage and generate a critical log, depending on your settings.
    • Fixed a bug where turning OFF the bypass might not reset your lights correctly.
If you like this blueprint? Consider hitting the :heart: button in the top post :+1:
If you like my blueprints, and would like to show your support or just say thank you? Click Here :smiling_face_with_three_hearts:
Enjoy
Blacky :grinning:
