Your lighting experience, your way โ take control and customize it to perfection! ![]()
Bug Fixes
Bypass
Turn OFF action: When using Night Glow, the bypass would not turn off the Glow lights when using option 2.
Crossover when bypass is ON: Addressed multiple scenarios where, if the bypass was turned ON and a crossover occurred, the correct action would now be performed when all bypasses were turned OFF.
Global Conditions
- Fixed an issue where Night Glow lights would not turn OFF based on sun, ambient, or time conditions.
Maintenance
- Some code clean up in Device Tracker.
If you like this blueprint? Consider hitting the
button in the top post ![]()
If you like my blueprints, and would like to show your support or just say thank you? Click Here ![]()
Enjoy
Blacky ![]()
