@Blacky Not sure if this was suggested before, but i would love to have an extra option to be able to dim a light when no motion is detected anymore before turning off after a set timeout.
So i would expect the following behavior: Motion detected > Turn on light > No motion detected > Dim light to X percentage > Wait X minutes before turning off fully OR turn on again when motion was detected again.
This could make some lights in my hallway a bit more subtle.
I believe i could use this night glow setting, but then my light would be turned on the whole day which is not desirable.
Thanks!
I noticed youâre using an older, unsupported blueprint of mine: Turn Light, Switch, Entity or Scene On & Off with Trigger Conditions.
If youâd like, consider updating to ensure youâre using the latest version. Also, make sure youâre running the latest version of Home Assistant (HA), as recent updates are required for the new blueprints to work properly. To update, click the blue Import button at the top of the post.
For the second blueprint,  Smart Light now replaces the older blueprint, Turn Light, Switch, Entity or Scene On & Off with Trigger Conditions. Itâs a completely new blueprint, so youâll need to create a new automation. However, it provides the same functionality with many additional options.
That said, the blueprints youâre currently using should still work, as all your settings seem correct. If youâre experiencing issues, it could be due to incorrect time settings in HA.
To verify your HA time:
- Go to Developer Tools > Template Tab.
- Copy and paste the following code into the template editor:
{{ now() }}
{{ now().astimezone() }}
{{ utcnow().astimezone() }}
{{ now().now() }}
{{ now().today() }}
{{ now().utcnow() }}
{{ utcnow() }}
{{ now().tzinfo }}
{{ now().astimezone().tzinfo }}
{{ utcnow().tzinfo }}
It should display the time configured in HA.
Blacky
Iâm not sure which light you intend to use. If itâs a light included in the Lights input, it wonât work as expected.
For any other light (if itâs not part of the Lights input), youâll need to create a template binary sensor and invert it to reflect the lightâs behavior. Then, use this binary sensor in the night light entity state option.
Try setting it up, and if youâre having trouble, share your YAML for the automation. Iâll take a look and help you troubleshoot.
Blacky
There was a community member who requested this previously. I believe we created a script and used it in the Turn OFF action.
You could try using a scene or script in the Lights input. Avoid using a Scenes & Scripts - Toggle Helper. Then use the Scenes - Scripts To Turn OFF input.
In the script used in Scenes - Scripts To Turn OFF input, you could set the light to 50%, wait for a specified duration, and then turn it OFF.
Blacky
Thanks will have a look at that option!
Hello Blacky,
Iâve updated the Blueprints and switch to use new  Smart Light.  I used the template, and the date/time is correct for my location.  Iâve see how it goes for the next couple days.
One additional question can you mix Time ON/OFF with Sun Elevation. Example,
include_sun:
      - sun_falling
sun_elevation: -5
include_time:
     - time_off
before_time: "07:00:00"
Mark
Hey guys, I noticed that when I set a Night Glow light that is not included in Night Light or Lights, the bypass option that turns off all lights does not turn of the Night Glow light.
I tried to use a scene to force to turn off the light and Iâve added it to to the âScenes - Scripts To Turn Offâ field but the problem now occurs when turning off the bypass entity. The automation does not turn on again the Night Glow light (Night Light entity helper was on when I run this test).
I donât know if Iâm doing something wrong or if that behavior is expected or is a known issue.
As a workaround Iâve added the light to the Night Light entities but the idea is to turn on that light only when Night Glow is on, otherwise should be off.
If you find a better solution, Iâd appreciate your help.
I hope this is an easy one âŚ
I would like the automation to run only if someone is at home, otherwise switching lights on donât make much sense.
I have a sensor that indicates whether a person is at home (not speaking about the cat  ):
 ): binary_sensor.someone_at_home
I would like to use that sensor to decide whether the sensor light automations are active.
as soon as there is no one at home anymore, the already started automations should finish (mainly switching off lights after the configured delay).
and then the automations should âsleepâ until someone is at home again. Basically I would like to stop the automation to run triggered by the cat
I think I should use âBypass Switch - Keep The Lights Current Stateâ - am I right?
Or do I need to group the binary_sensor.someone_at_home with the motion sensor used in the automation?
Does this include a timer helper for tracking the remaining time and also does the timer resets automatically if there is motion detected?
It seems like a great blueprint with tons of options but I canât see the option to use a timer helper.
Please let me know.
Thanks!
Hallo Blacky,
Zwischen Sonnenuntergang und -Aufgang soll der Bewegungsmelder das Aussenlicht fĂźr ein paar Minuten einschalten. geht!
Zwischen Sonnenuntergang und 21 Uhr und 7 Uhr und Sonnenaufgang soll Dauerlicht sein. geht leider nicht.
Was mĂźsste ich einstellen? Vielen Dank
Sorry now in English
Hello Blacky,
Between sunset and sunrise the motion detector should switch on the outside light for a few minutes. It works!
Between sunset and 9 p.m. and 7 a.m. and sunrise the light should be continuous. Unfortunately it doesnât work.
What should I set? Many thanks
Vorhand
Welcome to the community.
Thanks for bringing this to our attention. This is a bug, and it should work as expected. Iâll work on a fix⌠stay tuned for an update!
Blacky
You could just use Device Tracker option.
If you want to use your sensor, it must be in the ON state when no one is home. If itâs not, youâll need to invert it. Then, use it in Bypass Option 2 to ensure your lights turn OFF. In the Bypass - Time Delay, set a delay so that when your sensor triggers the bypass to turn OFF the lights, it waits for the specified time before doing so.
Blacky
All good for me ether way.
The best way to do this is to create a Template Binary Sensor for your continuous condition and then group it with your motion sensor.
In the trigger section of the blueprint, youâll find a link explaining how to group your motion sensor and the template sensor. Once youâve grouped them, use only the group as the trigger.
Creating a Template Binary Sensor:
- Navigate to Settings > Devices & Services > Helpers.
- Click Create helper.
- Select Template â Template a binary sensor.
Next:
- Name the sensor.
- Choose a Device class (optional).
- (Optional) Link the sensor to an existing device for better organization.
State Template Code:
Paste the following into the State template field:
{{ (state_attr('sun.sun', 'elevation') < -1.5 and now().hour < 21)
   or (now().hour >= 7 and state_attr('sun.sun', 'elevation') < -4.0) }}
Note: The -1.5 and -4.0 sun elevation values determine when the sensor is active. Adjust them to fit your needs.
Blacky
In German for you.
"FĂźr mich ist beides in Ordnung.
Der beste Weg, dies zu tun, ist das Erstellen eines Template-Binärsensors fĂźr deine dauerhafte Bedingung und anschlieĂend das Gruppieren mit deinem Bewegungssensor.
Im Trigger-Abschnitt des Blueprints findest du einen Link, der erklärt, wie du deinen Bewegungssensor und den Template-Sensor gruppierst. Sobald sie gruppiert sind, verwende nur die Gruppe als Trigger.
Erstellen eines Template-Binärsensors:
- Navigiere zu Einstellungen > Geräte & Dienste > Helfer.
- Klicke auf Helfer erstellen.
- Wähle Template â Template-Binärsensor.
Als Nächstes:
- Benenne den Sensor.
- Wähle eine Geräteklasse (optional).
- (Optional) VerknĂźpfe den Sensor mit einem vorhandenen Gerät fĂźr eine bessere Ăbersicht.
State-Template-Code:
FĂźge den folgenden Code in das State-Template-Feld ein:
Hinweis: Die Werte -1.5 und -4.0 fĂźr die Sonnenelevation bestimmen, wann der Sensor aktiv ist. Passe sie nach deinen BedĂźrfnissen an.
Blacky
@Blacky
thanks a million for the pointer to Bypass Option 2 - will try it soon
Hi, Iâm having some trouble with this automation and the add-on, when I return from watching on PC, âLED Scrivaniaâ turns off instead of on
Hereâs the sensor light config:
alias: Lights
description: ''
use_blueprint:
  path: Blackshome/sensor-light.yaml
  input:
    motion_trigger:
      - binary_sensor.ep_lite_5cb900_occupancy
    light_switch:
      entity_id:
        - scene.home
    end_scenes:
      - scene.tutto_spento_camera
    time_delay: 1
    include_night_glow: night_glow_enabled
    night_glow_lights:
      entity_id:
        - scene.camera_night_glow
    motion_bypass_lights_stop:
      - input_boolean.disable_sensor_tv_lights
      - input_boolean.disable_sensor_pc_lights
    include_bypass:
      - bypass_enabled_stop
    include_light_control:
      - use_transition
    include_dynamic_lighting: disable_dynamic_lighting
    include_device_tracker: zone_enabled
    zone: zone.home
    boolean_scenes_scripts: input_boolean.lights_helper
    include_night_lights: night_lights_enabled
    night_lights_conditions:
      - time_enabled
    night_lights_before_time: '08:00:00'
    night_lights:
      entity_id:
        - light.led_scrivania
    night_time_delay: 1
    include_night_light_control:
      - use_brightness
      - use_transition
      - if_lights_are_on_adjust_when_crossing_over
    night_light_brightness: 20
    include_night_light_colour_control: use_rgb_colour
    night_light_colour_temperature: 3000
    night_light_rgb_colour:
      - 255
      - 186
      - 137
Hereâs the addon config:
alias: Lights - PC
description: ''
use_blueprint:
  path: Blackshome/sensor-light-add-on.yaml
  input:
    trigger_entities:
      - media_player.filippo_pc_plex
    trigger_on_state:
      - playing
    trigger_off_state:
      - unavailable
    include_start_turn_off: enable_start_turn_off
    off_light_switch:
      entity_id:
        - light.led_letto
        - light.yeelight_lampada_scrivania
        - light.lampadario_camera
        - light.comodino_dx
        - light.comodino_sx
        - light.nanoleaf
    off_include_light_control:
      - use_transition
    intermission_include_light_control:
      - use_transition
      - use_brightness
    include_intermission: intermission_enable
    intermission_light_switch:
      entity_id:
    intermission_include_light_colour_control: use_rgb_colour
    include_end_turn_on: enable_end_turn_on_snapshot
    end_snapshot_name: pc_lights
    end_snapshot_helper: input_boolean.snapshot_pc_lights
    end_include_light_control:
      - use_transition
    time_delay: 0
    light_switch:
      entity_id: scene.empty_scene
    end_light_switch:
      entity_id:
        - light.led_letto
        - light.comodino_dx
        - light.comodino_sx
        - light.nanoleaf
    intermission_light_rgb_colour:
      - 0
      - 0
      - 255
    intermission_light_brightness: 100
    include_automation_link: enable_automation_link
    automation_link:
I am running Ikea bulbs with this automation (like many others I suppose) but also have the issue that quite often some lights wonât turn off after the automation. Not sure why that is happening, but I found out that this might be a rather common issue with the ikea bulbs. Hopefully we can somehow integrate a fix for all those of us running ikea lights or help us with the current workarounds:
The currently best workaround is either to create template sensors and helpers for every light and create an additional automation that turns off these lights according to the state of these helpers. The other method described is to send the turn off signal twice.
As the latter option is much less work and maintanance, it would be great to have an option to add a custom action that triggers together with turning on and off a light. The you could just run the turn off signal as a custom action again.
As you then could also run other stuff together with the lights without a lot of fuss, I imagine this would be a neat feature for other people as well. Any chance of making this happen?
@Blacky Iâm having a problem with my bathroom toilet light using the night lights. For some reason the toilet light dimming level is not being set to 10. Itâs stuck full blast at 100% per the HA dashboard. Any ideas why the brightness is not being properly set? Itâs a Inovelli White series thread/matter dimmer.
alias: Master Bathroom Toilet Lights
description: ""
use_blueprint:
  input:
    motion_trigger:
      - binary_sensor.eve_motion_occupancy_mb_toilet
    light_switch:
      entity_id: light.inovelli_master_bathroom_toilet_lights
      - use_brightness
    include_night_lights: night_lights_disabled
      - time_enabled
    night_lights_after_time: "22:00:00"
    night_lights_before_time: "06:00:00"
    include_bypass:
      - bypass_enabled_turn_off
    motion_bypass_lights_off:
      - binary_sensor.presence_fp2_master_bedroom_bed
    night_lights:
      - use_brightness
      - use_transition
    night_light_transition_on: 1
    night_light_transition_off: 3
    night_time_delay: 3
    night_light_brightness: 10
There are a few things to check, but you should find the answer somewhere in your settings:
- Snapshot Behavior: A snapshot is created before running the add-on. This means the current state is included in the snapshot. Is the light OFF at this time?
- Scene Inclusion: In the sensor light, you have a scene called home. Is the light included in that scene?
- Night Glow Behavior: In the sensor light blueprint, you have night lights with glow lights. Are the glow lights turning ON while LED Scrivania is not? Is this happening between 12 AM and 8 AM when night lights are active?
Hopefully, this helps you track it down. Itâs likely happening because something in your settings is triggering it.
Iâm also releasing an update for the sensor light blueprint, which includes several bypass bug fixes. I have done all the code changes for the update. Now, I just need to do a final check to ensure everything is correct before releasing it. This update might resolve the issue, so if you canât find the cause now, you may want to wait for the update to see if it fixes it.
Blacky
