💡 Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
@dimatx
Hi Dima
No problem.
This can be done with the by-pass already + more
I had a look at it today, but unfortunately I had to roll back as there was a bug in the release for me. Hope they fix it.
When I add a condition I make sure it works through the whole blueprint. Example;
By-pass (helper toggles or a kill switch): If you just added a condition it would prevent it from running. I have made sure it will do more. You have options when you turn the bypass ON and when you turn it OFF it analyse your automation and reacts correctly. So The bypass will prevent the automation running but let say you would like to turn on a helper (bypass / kill switch) and if any light are ON turn them OFF too. This will do that. But the other light you would like ON, no problem. What happen when you come home and your motion group is ON and you turn the bypass OFF. This will check that and turn your lights ON if required.
Sun: If you put a condition it would prevent it from running. I have made it analyse your automation and it reacts correctly.
Ambient: If you put a condition it would prevent it from running. I have made it analyse your automation and it reacts correctly. You also have more options.
A new one is coming out in the next release that I realy like. I have more on the road map to.
So the conditions in this blueprint do more that just prevent it from running. It all works together to analyse your automation with a simple click. You can use none of them or all of them. Code goes through the whole blueprint for this to happen. Condition selector will not do this.
The condition selector could be added and would say it probably will. If I add it now everyone would have to have the latest HA, and I don’t have it yet.
If you find that you cant do something let us know as I do add a lot of suggestions.
PS: I also added a sensor light add on blueprint. For anyone else reading this, a bug was fixed so check it out and update. It links to this automation so you can have, movie lights, smoke detector light, alarm lights. Be sure to check this out.
:infinity: Sensor Light Add On - Media & Movie Lights - House Alarm Lights - Smoke Alarm Lights & Exhaust Fans + More
