I had a look at it today, but unfortunately I had to roll back as there was a bug in the release for me. Hope they fix it.
When I add a condition I make sure it works through the whole blueprint. Example;
By-pass (helper toggles or a kill switch): If you just added a condition it would prevent it from running. I have made sure it will do more. You have options when you turn the bypass ON and when you turn it OFF it analyse your automation and reacts correctly. So The bypass will prevent the automation running but let say you would like to turn on a helper (bypass / kill switch) and if any light are ON turn them OFF too. This will do that. But the other light you would like ON, no problem. What happen when you come home and your motion group is ON and you turn the bypass OFF. This will check that and turn your lights ON if required.
Sun: If you put a condition it would prevent it from running. I have made it analyse your automation and it reacts correctly.
Ambient: If you put a condition it would prevent it from running. I have made it analyse your automation and it reacts correctly. You also have more options.
A new one is coming out in the next release that I realy like. I have more on the road map to.
So the conditions in this blueprint do more that just prevent it from running. It all works together to analyse your automation with a simple click. You can use none of them or all of them. Code goes through the whole blueprint for this to happen. Condition selector will not do this.
The condition selector could be added and would say it probably will. If I add it now everyone would have to have the latest HA, and I donât have it yet.
If you find that you cant do something let us know as I do add a lot of suggestions.
PS: I also added a sensor light add on blueprint. For anyone else reading this, a bug was fixed so check it out and update. It links to this automation so you can have, movie lights, smoke detector light, alarm lights. Be sure to check this out.
Thanks Blacky, my settings look to me to be the same as yours, but I cover the sensor, lux goes to 1 and the lights turn on, I uncover the sensor, lux goes to 87 but the lights just stay on. Is this expected?
Iâm about a week into being a HA user - and absolutely loving this blueprint. Iâm hoping someone can point me in the right direction on this situation:
I have a door sensor, and a motion sensor in a hallway outside the door. The door is always closed (except for passage), together they should allow me to infer which direction someone is traveling. Aka - turn lights on in bedroom if motion sensor triggers then door sensor triggers, or turn lights on in hallway if door sensor triggers then motion sensor triggers.
I think I understand enough about automations that I could create this automation as a standalone, but I specifically like ALL the options already in this blueprint. So is there an easy way to create something this blueprint would still recognize as a âbinary sensorâ that is based off the sequential order of two other sensors?
Iâve created groups for other applications already, but that doesnât have the sequential nature. I also understand I can add lots of options to my own custom automation triggers, but I donât understand how to make those then report as a binary sensor for this blueprint to read.
As with most things HA Iâve encountered so far, I am guessing this is much easier than I am making it out to be, and I just need a little help getting pointed in the right direction. Thanks!
Thanks for providing your YAML it makes it easier to resolve.
I will jump to the problem and then answer your question.
In âLights - Switches - Scenesâ you have entered in a âAreaâ called âdining roomâ. We canât use areas or devices and it must only be entities. I am amusing that your lights âdining_table_lightâ and âdinning_wall_lightâ are the only lights you would like to control. If so remove your area âdining roomâ from the automation and you will be good to go.
In the âThe Settings & Best Practice Guidelinesâ Click Here see under âLights - Switches - Scenesâ for a better explanation on this.
No, but a few things are also considered in the automation for this condition and option selection
If your trigger is ON then this happens. If you cover the sensor and it crosses over your setting (high to low) then the light will turn ON and your trigger is active. If you then remove the cover from the sensor and it crosses over your setting (low to high) the light will turn OFF after your âTime Delayâ setting.and trigger is disabled.
If the trigger is OFF the light will not turn ON if the sensor goes from (high to Low) and from (low to High) it just allow the trigger to be active when it is below your setting so the lights can turn ON if triggered.
If the trigger is ON and you cover the sensor and it crosses over your setting (high to low) then the light will turn ON. If the trigger then goes OFF it starts the time delay from that point. If you then remove the cover from the sensor and it crosses over your setting (low to high) and the light is still ON the light will still turn OFF and your trigger is disabled.
There are more scenarios but I think you get the idea. There are so many to consider in this automation and this is just one option with a few scenarios .
Idea is you just donât notice anything behind the automation and it just works
I understand what your trying to do but running through some scenarios in my head.
Scenario 1 - Motion sensor in the Hallway
When motion is detected, hall light turn ON - Done
If you are in bedroom and you walk out into hallway motion detected hall light ON - Done
If you are in hall way entering bedroom motion detected hall light ON - Done.
All option covered with just motion. Light turns OFF when motion is not detected.
Scenario 2 - Bedroom Door sensor.
In hallway enter bedroom (door sensor), bedroom light ON - Done
In bedroom enter hall open door bedroom light ON, but it should be ON already as you could be in the dark - Not Done
Questions:
What turns it OFF?
Do you leave the door open when you would like the light ON and then close it to turn the light OFF? If so then that would work
Scenario 3 - Bedroom Door sensor. If the door is the trigger then it just works of a time delay. Door is open and closed.
In hallway enter bedroom (door sensor), bedroom light ON after some time light OFF - Done
In bedroom enter hall open door bedroom light ONâŚ, but it should be ON already as you could be in the dark, so you have manually turned the light ON already, ok. so we leave bedroom close the door light is ON after some time light OFF - Done
This seems to work but only for a short time
Scenario 2 & 3 seams unresolved Would a motion sensor be better for a bedroom (Room) as door sensors work well for cupboards or small rooms like food storage, clothes rooms etc.
Maybe I donât fully understand what you are trying to do in its entirety.
Is this saying that I would have to leave the room (presence clear) before the lights would turn off? I have a main room that can be used all day. What I would like is that in the morning when it is still dark the lights will turn on, but as the sun rises (and the lux value goes low->high) the lights would turn off, even though Iâm still in the room. Is that the intended behaviour? I removed the room from the lights, they still turn on when lux goes high->low, but as long as Iâm in the room they just stay on forever.
Added the ability to use another condition in night lights called âEntity Stateâ . Night lights have 3 conditions now.
Entity State
Time
Sun Elevation
The entity must have an ON state to activate nigh lights. So now you can use âDo Not Disturbâ on your phone, a helper toggle, a switch near your bed, a bed sensor etc to activate night lights. More information can be found in our FAQ or Click Here for more information.
Bugs Fixes
Fixed an error when transition was disabled like shown below. This was probably when you are using zigbee2mqtt.
Transition value 0 is not valid.
If you like this blueprint? Consider hitting the button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Thanks for that awesome work and constantly improving this blueprint!
Just a minor thing i want to point out there is a typo in the change log date of V4.3.
Thats great to hear, i faced issues with the combination of yeelight and nightlight functionality previously. Let me check tonight if this is gone now. If not iâll come back and post my logs.
Fixed an bug in crossover transition from ânight light to normal lightsâ and from ânormal light to night lightsâ using wrong transition selection.
Well seeing as youâve released several new versions while weâve been talking I decided to update to the latest, delete the automation and start it from scratch and it works! Shame we will never get to the bottom of the problem, but Iâm happy that is working perfectly now. Thanks so much for all the time you put into your automaton blueprints
Thanks for your reply and explanation, @Blacky. So in my case I have a variety of âkill switchesâ for each automation. Stuff like âdisable downstairs light automationsâ, âguest modeâ, etc. It looks like with the current blueprint you can have just a single by-pass? Based on your description of by-pass, seems like that would be sufficient when it comes to achieving my kill switch functionality, but I am constrained by the limitation of allowing only a single entry.
I recently upgraded the blueprint and am seeing an odd error. I did just try to delete the respective automations, delete then re-add the blueprint, and add back one automation.
error:
Error rendering variables: UndefinedError: âdict objectâ has no attribute âentity_idâ
(Source: components/automation/init.py:608)
