Hi Murat, firstly welcome to the community
This blueprint by-pass requires a state change from ON to OFF. If you have buttons then first you will need to create a by-pass using a helper. On how to do this see our FAQ Click Here.
Once you have created the by-pass helper you will need to add it into the blueprint.
Then you can install my
Push Button Relay - Contactor blueprint. You will then use this blueprint so you can use your button to toggle the by-pass switch
. It is easy and simple with this blueprint and I am sure you will get more use out of it with other things you will need to control.
Hope this helps you
Blacky
