I recently upgraded to the newer version of the sensor light, and now my automation does not work anymore. I use my Unifi doorbell camera as my binary sensor for person detection, which then turns on our front porch switch and lights. The lights are then adjusted to 100% brightness and 5000K.
Since the upgrade, this automation no longer works. I have rebuilt it several times with no luck. Any help would be greatly appreciated.
Here is my automation setup. I do not have a copy of the old version.
alias: Front Entry Person Detection
description: Script triggered by a camera when a person approaches the front porch
use_blueprint:
path: Blackshome/sensor-light.yaml
input:
motion_trigger:
- binary_sensor.20102_leithcrest_way_frnt_door_person_detected
light_switch:
entity_id:
- light.wiz_rgbw_tunable_6bd442
- light.wiz_rgbw_tunable_6bbae2
- scene.front_porch_lights_on
end_scenes:
- scene.front_porch_off
include_sun: sun_disabled
time_delay: 7
dynamic_lighting_max_lux: 900
dynamic_lighting_min_lux: 0
night_time_delay: 0
after_time: '16:30:00'
before_time: '08:00:00'
light_transition_on: 0
night_light_transition_on: 0
include_light_control:
- use_colour_temperature
- use_brightness
bypass_auto_off_delay: 1
include_time: time_enabled
Here is the second automation I have created trying to perform the same task, using the same sensor and lights.
alias: Front Door Person Detection ver. 7
description: ""
use_blueprint:
input:
motion_trigger:
light_switch:
entity_id:
end_scenes:
time_delay: 7
@Blacky
Is there anyway for the “Bee In The Hive Sensor” to only keep the light on once the door is closed? AKA
Motion is detected, light turns on, timer starts
Door closes, timer stops till both door opens and motion is not detected
If that is possible anyways…
Below is your YAML to adjust the light to 100% brightness and 5000K. Look in Light Control I have selected the options there. Copy and paste it in… you may need to set your time condition up again.
When the door is closed if it detects motion in the room it will turn the Bee In The Hive sensor ON. It will stay ON until the door opens. Once you create it you then group it with your motion sensor, you then add that group to the trigger not the individual sensors.
The sensor is good because you can use it for whatever you like and it is not tied to a blueprint.
@Blacky
PERFECT!! Thank you!
I am just now figuring out all of the crazy stuff you can do with your blueprint… I am sure I will have more questions in the future. lol
I really love the customizability of this blueprint, however every now and then the automation seems to get a hiccup, where the light turns on, and then immeaditely shuts off. I tried the FAQ, where it describes the issue im facing, but the only difference is, that I only have on singular motion detector at work here (not multiple triggers).
Is anyone facing the same issue of the light turning off suddenly?
I use something similar, but in my case when some light was turn it on manually the automation do not run, and the light stay On all the time untill I turn it off. In that case the motion sensor switch the front light again on and off
This is my blueprint. Not a lot of fancy stuff happening here IMO thank you for the warm welcome and answer Before i was using a mqtt group that grouped my 3 lights as one, but it behaved very similar
re. the WLED colour temp: can you tell me what your relevant settings are in both HA and WLED? I wonder if I’ve got one of those adrift somewhere: the WLEDs will do colour temperature beautifully in WLED natively but not in HA so it must be somehting I’m doing…
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on “</>” and paste code in there.
I am not the guru on WLED but I love it. I know on the WLED discord there are so many people to help and very willing, they also use HA… hats of to them. Maybe ask on that forum but I use it here and it works perfectly never missing a beat. Below are one segment of the LED I use if that helps any.
