I believe Z2M changed the sensor IDâs. Youâll have to delete the old sensor IDâs and enable the new one, in each device, then change all the automations that used the old sensor IDâs.
Blacky ![]()
Blacky ![]()
Yes.
If it get re-triggered then the time delay starts again once the trigger is clear.
Look at this blueprint.
Manual light control with auto OFF and Enable the motion sensor option
I have a few blueprints for different things so make sure you check them out. You will find links to them all in the first post at the top.
Blacky ![]()
Have a look at the bypass section. You will probably use option 2 - Enable the Bypass - Turn lights OFF and use the entity for alarmo that is ON when you set it to night.
Blacky ![]()
@Blacky question⌠how can I tell the automation to only fire when the light is = OFF ? For example, if the light is already on 50%, I dont want it this automation to fire (when it senses motion) because it would set the light to 100%.
Thank you, your Blueprints are fantastic! I sent you a direct message about a few ideas.
Hi there,
I have been using the automation with a hue bridge. When I trigger the automation after the sun has set (such as to revert from scene I have set), it will adjust the brightness as expected it will not change the light temp. When the sun is above the set elevation, the correct temp will be set. Perhaps there is a config error in the automation? I have toggles set up for all settings. What am I doing wrong?
Many thanks.
The automaton can be triggered on many things and it needs to be trigger for it to work correctly. So it will need to fire when it senses motion again as this is how it will keep the lights ON. I written it so it will not effect your lights once they are ON. If you are using a scene or script then you will need to make sure you add the Scenes & Scripts - Toggle Helper as this is why it is there only when using a scene or script. Lights and switches donât need this helper.
Try it out, trigger the automation so the lights turn ON, adjust the light % or colour, then let you motion go to clear and re-trigger the motion sensor. Your lights should stay the same.
Blacky ![]()
Welcome to the community.
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on â</>â and paste code in there.
Blacky ![]()
Thank you. I didnt see it documented that the light would not change but yeah, been playing with it today, works nicely.
Would love for this same BP to be able to be triggered by any Entity change, not just a Sensor.
You can, as long as the entity has an On / OFF state. Just copy the entity ID and paste it in. If the entity does not have an ON / OFF state then you can create a template sensor to handle it for you.
Blacky ![]()
Many thanks for helping, please see below. I should note that if I remove all triggers and manually run the automation, it will first turn off the lights, then on the second, it will turn them back on with the correct temp. If any trigger is used, it will only ever change the brightness, not the temp.
alias: Study Dynamic Lights
description: ""
use_blueprint:
path: Blackshome/sensor-light.yaml
input:
motion_trigger:
- binary_sensor.study_dynamic_lighting_binary_sensor
light_switch:
entity_id: light.study_2
include_light_control:
- use_transition
- use_brightness
light_transition_on: 3
light_transition_off: 3
include_light_colour_control: use_colour_temperature
light_colour_temperature: 3500
include_dynamic_lighting: enable_sun_elevation_colour_lux_brightness
dynamic_lighting_lux_sensor: sensor.illuminance
dynamic_lighting_max_lux: 10000
dynamic_lighting_min_colour_temp: 2200
dynamic_lighting_time_start_morning: "06:00:00"
include_device_tracker: zone_people_enabled
include_night_lights: night_lights_disabled
night_lights_conditions:
- time_enabled
include_night_glow: night_glow_disabled
night_glow_lights:
device_id: 31f39a37abb58369224cdf4eccb9b273
night_glow_light_brightness: 1
dynamic_lighting_min_lux: 500
dynamic_lighting_max_colour_temp: 6500
dynamic_lighting_step_value: 100
dynamic_lighting_time_end_morning: "09:00:00"
dynamic_lighting_time_end_evening: "21:00:00"
include_time: time_enabled
after_time: "06:00:00"
before_time: "21:00:00"
night_lights_after_time: "21:00:00"
night_lights_before_time: "06:00:00"
include_night_light_control:
- use_brightness
- use_transition
- if_lights_are_on_adjust_when_crossing_over
night_light_brightness: 20
night_light_transition_on: 5
night_light_transition_off: 5
include_night_light_colour_control: use_colour_temperature
night_light_colour_temperature: 2200
ambient_light_options: ambient_light_option_enabled
dynamic_lighting_min_brightness: 20
night_lights_entity_state: []
zone: zone.home
people:
- person.oliver
time_delay: 0
end_scenes: []
motion_bypass_lights_stop:
- input_boolean.bypass_keep_state_study
include_bypass_auto_off: []
bypass_auto_off_delay: 240
include_bypass: []
bypass_time_delay: 5
motion_bypass_lights_off: []
light_brightness: 52
boolean_scenes_scripts: input_boolean.study_scene_toggle_helper
dynamic_lighting_boolean: input_boolean.study_dynamic_toggle_helper
night_lights:
night_time_delay: 0
night_boolean_scenes_scripts: input_boolean.study_night_toggle_helper
dynamic_lighting_state_control_entity: light.study_2
dynamic_lighting_state_control: disable_state_control
Thank you, I didnât know that would work since the drop-down list automatically filters to only show the user Sensor devices, not dimmers or switches. Your BPs have so much functionality (which is awesome) and of course, I need functionality that isnât documented ![]()
THANK YOU for responding quickly to help guide us! Using your Sensor and Manual BPs have allowed me to replicate my old Homeseer based âcoreâ lighting automation (stuff that is in nearly every room: light timers, motion lighting, etc) with more ease and additional functionality too!
now if I can only convince you to combine both BPs into one (Manual and Sensor) ![]()
I looks like the main difference is Sensor doesnt âsyncâ the devices? If that was in Sensor, I could remove all the Manual BPs, reducing my Automations by 50%.
@Blacky Its not working as Iâd expectâŚ
I have 2 Automations⌠one Sensor and one Manual
ON works : Turning on Master or Slave dimmer correctly turns on the Group and other dimmer .
OFF does not work : turning off either device Entity; neither the other entity nor the group turn off.
Are you sure the Sync function in Sensor works with groups?
Thanks for your YAML.
I see you have tried a few things⌠what I have done is cleaned up all your YAML and enabled what I think your trying to do. Now you can just disable the night lights and night glow if you donât want it.
Things I changed.
From all of the changes you will see how the whole blueprint will work now. If you donât want night lights or night glow you can disable them but I thought I would just set it all up for you so you can see everything set up correctly. Copy and paste your YAML in and test it out using your motion sensor.
description: ""
use_blueprint:
input:
motion_trigger:
light_switch:
- use_transition
include_night_lights: night_lights_enabled
- time_enabled
include_night_glow: night_glow_enabled
night_glow_lights:
dynamic_lighting_step_value: 4
- use_brightness
- use_transition
zone: zone.home
people:
- person.oliver
time_delay: 5
- bypass_auto_off_enabled_stop
include_bypass:
- bypass_enabled_stop
night_lights:
night_time_delay: 2
include_night_glow_light_control:
- use_brightness
- use_transition
include_night_glow_light_colour_control: use_colour_temperature
night_glow_light_colour_temperature: 2200
Let us know how you go.
Blacky ![]()
Syncing Lights in Home Assistant (HA)
In Home Assistant, syncing all your lights is commonly achieved using a light group. A light group entity allows you to control all included lights as a single unit, ensuring they turn ON and OFF together while staying synchronized, including attributes like effects, brightness, colour, or colour temperature.
However, if you turn ON or OFF, or change the effects, brightness, colour, or colour temperature of one of the individual entities within the group, the group will no longer remain synchronized. To maintain synchronization, you must control the group entity itself.
Sync Option in Manual Light Blueprint
The sync option in the manual light blueprint ensures that your lights (entities) turn ON and OFF together. However, it does not sync other attributes like brightness, colour, or colour temperature.
In the manual light blueprint, the lights themselves act as triggers. This differs from the sensor light blueprint, where the motion sensor is the trigger. These differences mean the two blueprints cannot be combined seamlessly.
Sensor Light Blueprint Behaviour
The sensor light blueprint uses a motion sensor to turn all your lights (entities) ON and OFF. If you manually turn OFF one light, the others will remain unaffected because the lights are not the triggers. Additionally, if you manually turn OFF a light but the motion sensor triggers again before the rest of the lights turn OFF, the blueprint will turn the light back ON.
Manual Light Blueprint Use Cases
The manual light blueprint is ideal for situations where you want to manually control a light while incorporating additional features such as time delays or motion-based interactions. Here are some practical examples:
Reading Lamp in a Motion-Sensor Room
Use a sensor light blueprint to control the roomâs main lighting with motion, while a manual light blueprint handles a reading lamp that you might turn ON manually. When you leave the room, both blueprints can work together to turn OFF all the lights, ensuring nothing stays ON unnecessarily. Of course, you can manually turn OFF the reading lamp anytime, but if you forget, the blueprint will handle it for you.
Manual Control with Motion-Based Continuity
Enter a room and manually turn ON a light. The motion sensor keeps it ON while youâre present, and the manual light blueprint ensures it turns OFF when you leave after a set time delay. You can still manually turn OFF the light if needed, but if you forget, all lights will turn OFF automatically.
Time-Delayed Lighting Without a Motion Sensor
In spaces like a garbage room, toilet, or any area where a motion sensor isnât necessary, the manual light blueprint lets you manually turn ON a light (or even a fan) and automatically turns it OFF after a set delay. You can manually turn OFF the entity at any time, but if you forget, the blueprint ensures nothing is left ON.
Conclusion
Both blueprints have unique purposes and cannot be combined due to their differences in trigger behaviour. Understanding these distinctions allows you to use each blueprint effectively for different scenarios.
Blacky ![]()
First of all, many thanks for the great support. You always do a lot of work here for each individual case. Respect for that.
I had configured motion_bypass_lights_on and motion_bypass_lights_stop separately just a few days ago, because I suddenly read in the blueprint that you canât configure both values with the same entity. I didnât even know that before. But it doesnât really matter here.
I think your suggestion of using motion_bypass_lights_off with âAuto offâ is a good one. However, I also had to switch off the light via a light.turn_off action, because otherwise I would have to wait for the âAuto Off Delayâ before anything happened at all.
Unfortunately, everything is a little awkward with the bypass. But at least this way it works.
Did you change anything here with regard to retriggering? That wasnât the case a few versions ago.
Thanks again for your blueprints and the excellent support.
âJust wanted to say âThank youâ! This is exactly what I was looking for in my workspace. Now I am no longer sitting in the dark because I am too lazy to change the brightness.
I trigger the dynamic lighting with a sensor âpingâ and look for my laptop. If it is available, your blueprint will take action. If the laptop is offline, I take manual control of the lights again.
â
I made some changes for crossing over and so it will work using automation link in my other blueprints. I have tested it here again through many options and I cant fault it.
You could try going back to Version 7.3 and see if that resolves it.
Blacky ![]()
Thanks for sharing your experience⌠it is really nice to get these ones. Glad you like it and it helped you ![]()
Blacky ![]()
Continuing the discussion from
Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights:
Hello Blacky,
Got an issue and not sure what the problem is. I have a light attached to Tapo P135 which is a plug with dimmer and remote switch. Iâm using to automation; 1. Third reality motion sensor set to work from 5pm to 5:25am Blueprint Light Sensor, 2. Timed light on/off Blueprint Turn Light, Switch, Entity or Scene On & Off with Trigger Conditions.
Problem is motion sensor keeps turning on light after 5:25am.
Blueprint Light Sensor, YAML
alias: Motion Sensor - Office Light
description: ""
use_blueprint:
input:
motion_trigger:
- binary_sensor.third_reality_inc_3rms16bz_motion
light_switch:
entity_id: light.office_light
- use_brightness
- use_transition
light_brightness: 70
after_time: "17:00:00"
before_time: "05:25:00"
weekday_options:
- mon
- tue
- wed
- thu
- fri
Turn Light, Switch, Entity or Scene On & Off with Trigger Conditions - YAML
alias: Office Light
description: ""
use_blueprint:
path: Blackshome/entities-on-off-trigger-conditions.yaml
input:
entity_switch:
entity_id: switch.office_light
after_time: "05:30:00"
before_time: "06:15:00"
weekday_options:
- mon
- tue
- wed
- thu
- fri
include_weekdays: weekday_enabled
Very good Blueprint, so many options
But i wounder how to use conditions in this Blueprint?
I like to use this Blueprint for a âNightlightâ, when someone go up to the toilet, but it should only start the light if other lights are turned off.
