💡 Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
@coalfield
Hi John
This seems to be a unique option. However you could achieve this with a custom automation for your by-pass and then use the by-pass in the sensor light blueprint. I would do this.
  1. Create a blank automation.
  2. Your trigger is state, your motion sensor to OFF for X amount of time.
  3. Your condition is your by-pass is ON
  4. Your action is to turn OFF your by-pass.
Hope this helps you
Blacky :smiley:
@butcha89
Looks like you updated for and older version. Form time to time things need to be done when updating and I do document this. You can miss it though and links are provided in the FAQ if you would like to go done the road. For this one I would recommend you just delete the automation (not the blueprint) and create a new one. It then will clean up everything and you won’t miss anything that was required to do.
Blacky :smiley:
Thanks for quick response, I did a rollback to a few hours ago, now theres everything ok. Maybe I messed up things, will have a look into the FAQ later.
Hi! Thanks for the awesome blueprint.
I was wondering if you could enable the use of scripts also for the “Scenes - Scripts To Turn OFF” section…it only allows scenes to be selected there but i would like to use a script.
Best regards
Thank you so much. I got it to work as I wanted. Thank HA dev for the Automation trace feature, I was able to figure it out with the help of the trace feature and a couple of tries.
Turns out I had to put my TV state binary sensor as well as the light entity itself in by-pass option 3 as well as select the corresponding auto-off checkbox. Then I made sure both standard off-delay and bypass offdelay values were equal.
Works like a charm. The light will turn ON on motion but the automation will not trigger on motion if the TV is ON. In all cases, the light will turn itself off after the expiry delay, whatever the external conditions.
Thanks again for all the help!
How can I use RGB color values instead of Kelvin for my HUE lamps?
I can’t get this to work…
  • The lights will stay ON if the motion sensor detects motion before the time delay turns the lights OFF. It will then reset the time delay after last motion is detected.
Still after the delay is up, we are still in the room, the lights turns off.
Checking the log in HA; it says that the Automation is still running.
My code; Rörelse - Kök · GitHub
Hello all,
I’ve browsed through the FAQs and also read some things that are already going in that direction, but I’m not quite sure, maybe you have a tip for me.
Since I am currently restarting Homeassistant a lot and optimising again and again, I wanted to ask how you set this after a restart of HA or how can I set it to check whether the lights are on and the automation is triggered once after the restart, so that the light goes out after the time has elapsed?
Currently, they remain on because there is no trigger after a restart. If the light in the room is not on after a restart and there is no movement, it should of course not turn on.
Blacky, not only that they are ingenious blueprints, but also the way you really go about almost every topic is sensational, thank you! Wish you and everyone else a good start to the new year. Best regards, Seger
I’m unable to install this blueprint. I get an “unknown error.” Any suggestions how I can resolve this?
I cannot download this either. I get same error what benyzboy8682 gets. Github link is not working either.
I have exactly the same scenario (with Sensor Light v5.2).
This mostly happens to me when using two motion sensors, but not always. Also when in conjunction with Bathroom Humidity Exhaust Fan v2.2
Moved away from the Hue bridges since a couple of weeks. This blueprint is almost ideal. And respect for this blueprint!
… but still missing rgb color instead of Kelvin …
Does github having issue? I try to import but 404 in github.
I’m having the import issue too.
i have the same issue - error 404 and unknown error via import link :pensive:
Same error here I’m on ver 2.8 of sensor light but latest ver of HA and started having some glitches so i came here to update and github is gone and so is the import blueprint functionality
Hope everything is going OK in github land. I just saw that your hub is now showing " Blackshome doesn’t have any public gists yet". Happy new year, cheers.
@Blacky How can I do this?
Github Link doesn’t work?
@ob1w4nken0b1
Thanks for your suggestion, it is on the list.
Blacky :smiley:
