Im trying to get a Servo motor to function and from what i can tell i did the code correct. can someone tell me where im going wrong?
its for a smart air vent cover
im using a ESP8266
heres the code on that:
and heres what i have in the automation.yaml file:
- id: smart-vent_servo
alias: write servo value to esp
platform: state
entity_id: input_number.servo_control
- service: esphome.smart-vent_control_servo
data_template:
level: '{{ trigger.to_state.state | int }}'
any help would be appreciated. im using a SG90 servo ( the basic hobby servo)
i can confirm its not the hardware as i test both usin arduino code and it worked fine.
I will share my working version for ESP32. I did it with feedback and brought out the servo position sensor, and also added the start and end positions. These positions are needed when we know exactly the starting and ending positions, by setting these values and using the switch we can already set the desired positions. The slider is needed to control the servo and find the desired position. Implemented memorize the last position of the servo. If the board is de-energized and the voltage is applied, the position will be restored
esphome:
esp32:
board: esp32dev
framework:
type: arduino
#Wi-Fi credentials for connecting the board to the home network
wifi:
ssid: !secret wifi_ssid
fast_connect: on
#If there is no connection with WiFi, then the access point will rise
ap:
ssid: !secret ap_esp_ssid
password: !secret ap_esp_password
#Web server
web_server:
port: 80
#Logging
logger:
#OTA и API
ota:
password: "esphome"
api:
password: "esphome"
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
- sensor.template.publish:
state: !lambda 'return (float)level;'
#Output Platform
output:
- platform: ledc
pin: 13
frequency: 50 Hz
#Configuration variables: Output (required, ID): ID of the output component to be used for this servo
servo:
- id: servo_control
output: pwm_output
auto_detach_time: 0s
transition_length: 5s
#Sensors
#WiFi Signal Sensor
- platform: wifi_signal
name: gateway wifi signal
update_interval: 30s
unit_of_measurement: "dBa"
accuracy_decimals: 0
#Servomotor position sensor
name: servo sensor position
on_value:
then:
- script.execute: script_servo
#Switches
switch:
#Restart esp
- platform: restart
#Servo switch with start and end position
name: servo start/end
icon: mdi:bathtub
restore_state: true
turn_on_action:
state: !lambda 'return id(servo_start).state;'
- switch.template.publish:
state: true
- servo.write:
level: !lambda 'return (id(servo_start).state/100);'
turn_off_action:
state: !lambda 'return id(servo_stop).state;'
state: false
- servo.write:
level: !lambda 'return (id(servo_stop).state/100);'
#Script servo script
script:
- id: script_servo
then:
- if:
condition:
- lambda: 'return id(servo_sensor).state == id(servo_start).state;'
then:
state: !lambda 'return (id(servo_start).state/100);'
- switch.turn_on: servo_control_switch
- if:
condition:
and:
- lambda: 'return id(servo_sensor).state == id(servo_stop).state;'
then:
- switch.turn_off: servo_control_switch
#Adding a slider to control the servo
number:
min_value: -100
max_value: 100
update_interval: 5s
mode: slider #slider/box
lambda: 'return id(servo_sensor).state;'
step: 1
set_action:
then:
- servo.write:
level: !lambda 'return x / 100.0;'
state: !lambda 'return x;'
#Specify the initial position of the servo
name: servo start position
min_value: -100
max_value: 100
mode: box #slider/box
step: 1
optimistic: true
restore_value: true
#Specify the final position of the servo
name: servo end position
min_value: -100
max_value: 100
step: 1
optimistic: true
restore_value: true
Just spent few hours trying to get SG90 working on ESP32. I was using a separate power supply for the 5V. Eventually worked it out that I had to tie the GND together of the external power supply to the GND of the ESP32.
Hello. Maybe try to use frendly name (that does not contain spaces). For example in your ESP YAML file:
" esphome:
friendly_name: ESP1 " â here
This is a name that Home Assistant use and so the name that should be in automations.yaml:
" action:
service: esphome.ESP1_control_servo " â change the ESP1 if you have set diffrent friendly name earlier
