Just wanted to second this for others looking for a solution - this does work. Although I still feel like we’re all just being dumb and missing something. How is this not default and standard?
Best feature request ever!
At work all the cookies are deleted every. Thus every morning I have to set my default dashboard. It’s really annoying!
Up vote. Put me on the waiting list!
I, too, would like to see this happen. For the time being, I just created a new “default” dashboard called “Auto” and took control of the “Overview” dashboard to customize it how I want every user to see it. Downside is, I can’t rename the Overview dashboard to something nicer.
Just spent the last few days constructing a new dashboard to take over from the old one. I can’t believe there is no way of making a specific dashboard the default globally!!! How frustrating. I’ve no idea how to get around this now ![]()
Please add this functionality!!!
I can’t believe that after 3 years of this conversation, it is still not possible to predetermine a panel for a user, or even easier, a specific panel for all users… Please, I think it’s something basic so that “non-technical” people, that they don’t have to be rummaging through a menu, on a totally black page when you enter Home Assistant and see everything empty (because I’m not interested in them seeing the summary)… and even less, having to be looking in options such as putting your main panel as default…
If this is too difficult, it may be easier to allow the configuration to be saved by user and not by device, so that the administrator can enter with that user and leave the panel configured and ready for when the “user” really enters…
I think part of the reason that this hasn’t been done is that no one has stepped up to create it and submit it for inclusion in Home Assistant. Also, I suspect that many people realize that there already is a default dashboard for everyone, but few people are willing to take control of it and customize it for each Home user themselves.
You may be right about that. However, the vast majority of HA users are probably YAML-challenged as it is (me included) so creating it is out of question ![]()
Please implement this.
pls integrate this - makes total sense
You don’t need to use YAML. It can all be done in the default UI editor.
Just reread your original comment. You said “no one has stepped up to create it and submit it for inclusion in Home Assistant.” My response was that most people can hardly use YAML so you can’t expect them to code and submit actual HA code. Surely Home Assistant itself is not developed using it’s own UI?
You also mention that there already is a default dashboard for everyone. Care to elaborate? I think the whole point of this topic is that people are willing to setup dashboards manually but then cannot use them as default for all users.
I also want this!
And also add the possibility to grant visibility rights to the entire dashboard (currently, it is only possible at the page level of the dashboard)
where can i vote for this?
Very much needed and basic admin area.
Voted!
The Overview dashboard is, by default, available to all users. What isn’t yet possible is to make buttons on that available only to certain people in the home, as well as dedicated dashboards that are only available to the administrator and certain people.
I think not only the dashboard but also the sidebar menu. In general, the option of setting on constantly default appearances would be useful - such that would remain after removing the cache.
Really necessary and feels like a 5 minute fix from HA team working in similar fields myself .
Voted!
It is not only a great way to force the right dashboard to all users. There is a (cookie-)bug that once in a while resets and presents the overview dashboard for everyone.
Which is not a great way for roommates to accept home automation!
Folks,
Until this is supported natively, I would like to let you know that Custom Sidebar has a new option to set the default URL path every time that Home Assistant loads or gets refreshed. It is possible to set up a default URL for all the users and create exceptions for the admins without this option so Home Assistant will behave as per default for these users:
# Default URL path for every user
default_path: '/some/dashboard'
exceptions:
- user:
- Some Admin
- Another Admin
# ... other options
# As there is no default_path option
# Home Assistant will behave normally and open the configured dashboard
Note: You need to be aware that this option changes the default behaviour, so if you are in a dashboard and you hit the refresh button, then the default URL path will be loaded instead of the page being refreshed.
What happens is that this setting is stored in the local storage, so if this local storage gets wipe, then the overview dashboard will be the default one (together with other options like the sidebar order).
