svecpetr
(svecpetr)
1
Hi, I have problem with air condition device.
At a automation start I store
variables:
current_hvac_mode: "{{ states('climate.klimatizace_loznice') }}"
And finally at end of automation I need to restore value of HVAC_MODE that is already stored in my variable current_hvac_mode
The problem is that this code
device_id: ed7eb00713ddbf76e922498f8dc229c4
domain: climate
entity_id: 925f3671743e92433193c41edd18e7c8
type: set_hvac_mode
hvac_mode: {{ current_hvac_mode }}
cannot be saved because of error
Message malformed: value must be one of [‘auto’, ‘cool’, ‘dry’, ‘fan_only’, ‘heat’, ‘heat_cool’, ‘off’] for dictionary value @ data[‘hvac_mode’]
That is nonsense for… variable has valid value. But validator probably looks only at code… means see it as static text not dynamic value
Do you anybody see where I do mistake?
Put some quotes around it
I don’t think this will work with a device id - you need to use an entity id.
svecpetr
(svecpetr)
4
I did no know how to write it better… Here you can see printscreen from HA, detail of automation, excatly Actions part
Defined variable current_hvac_mode get heat
And finally when I want to set hvac_mode back to heat… I get error that this data malformed
svecpetr
(svecpetr)
5
If I change this line to
hvac_mode: heat
Everything would work well… But I need it change to value stored in variable not by static text
Use a Call Service Action, not a Device action.
service: climate.set_hvac_mode
hvac_mode: "{{ current_hvac_mode }}"
